Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Ihave a vanguard 20 hp v twin on my snapper mower you turn the key and get like a kluk sounds like its coming from starter
    Sergeant:
  • 406 Answers
Does it do it every time? First try and turn your engine by hand counter clockwise and try to start..sometimes the engine stops on a compression stroke and Is Under too much pressure for the initial start,..happened to my cub cadet laast week...,,if it turns and still gets a click...test or charge your battery..if it is ok you either have a bad solenoid or starter...first find the solenoid and croosing the two big post..it should spin the engine..if it spins it is your solenoid if not the starter is bad...not a hard job for either...both can be purchased at your local mower place...giid luck
Posted on Nov 08, 2014
gill73115
  • 6 Answers
SOURCE: Engine appears to run normaly until PTO is
Check you float in the carb I had one a few years back and it was partualy plugged cleaned it out and everthing worked fine. Also is the PTO binding up or bearings going bad putting an excessive load on the motor.
Posted on Jul 08, 2009
  • 21 Answers
SOURCE: Vanguard (Briggs) 20 HP V Twin Mower Engine
pull the tank first and inspect. if u still find nothing, you might want to check your coil
Posted on Aug 22, 2009
suzukiracing
  • 200 Answers
SOURCE: I have an 18hp v twin vanguard and it is
Piston rings being wore.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
Vanny Man
  • 4 Answers
SOURCE: I have a 23 hp Briggs vanguard engine-V Twin Model
It will probally be your valve setting might be off so pull the valve covers off and try setting your valve lash
Heres the factory settings
.006 on Intake
.008 on Exhaust
Posted on Oct 26, 2010
Vanny Man
  • 4 Answers
SOURCE: 18 hp vanguard 165lbs and 180 lbs compression have
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Snapper mower 42 inch with brigg stratton vanguard 16 hp v twin engine lopes when not under load
I would start by cleaning the air filter and the spark plug, or replace both if they are old.
Aug 08, 2014 | Briggs & Stratton Garden
Mountfield 1436M will not start. Ignition light comes on when key turned but just get whirring noice
try it with booster cables from your car. If it starts then you need to either clean your battery terminals or replace the battery.
Aug 02, 2013 | Snapper 20 HP Lawn Tractor 2690578
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 23 hp Briggs vanguard engine-V Twin Model 380447/type 76-E1 code 4241. The engine is less than two mowing seasons. The engine will not turn over properly and I have used another start I have and...
.006 on Intake
.008 on Exhaust
Sep 05, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
I have a Craftsman 21 hp, 42" riding mower ~ 10 years old...when trying to start it, it just makes a loud metal noise like the gears are stripped. I'm going to try to remove the starter tonight...will I...
depends on the engine, briggs L-head opposed twins can be viewed by removing the sheet metal head cover near the starter, changing its starter is fun, as one of the bolts is under the flywheel, it can be changed without flywheel removal, with patience. Briggs Vanguard and Intek twins starters are easier to remove, the intek cowling has to be removed to see anything with starter in place but the starter can be removed with the cowling in place, the Vanguard has a few sheet metal covers that must be removed. If you've got a Kohler, starter removal is usually pretty straightforward, take the starter to a local repair shop for a comparison or test if you are unable to determine what's wrong. A decent shop will at least inspect it and show you what a known good starter drive looks like.
Jun 03, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Aug 22, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
126 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Bill Boyd
Daryl Gleaton
obsteiner
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
