Question about Toto Aquia II Dual Flush Toilet
Slow close toilet seat lid that closes too fast
5 Suggested Answers
  • 2692 Answers
SOURCE: My slow close toilet seat
If the hinge is plastic spray silicone lub on it,down into the hinge.
If it ias brass, put light weight oil like( 3in1) down into the hinge.
Wipe off excess
Posted on Jan 20, 2009
kachbibi1
  • 979 Answers
SOURCE: How to tighten the hinges on a slow close toilet seat?
You don't want to overtighten since you could crack the porcelain. Are your rubber washers in good shape? This will help. You should be able to do this w/out doing any damage.
Posted on Jan 28, 2009
heatman101
  • 43501 Answers
SOURCE: The toilet see is not
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Posted on Aug 29, 2010
charlesharun
  • 174 Answers
SOURCE: toto toilet seat, cover closes fine the
Apparently, the rubber bands the hold the joints together are worn out.That happens after a while of the devices been installed.
Repair procedures
1. Requires parts to be acquired from retail. e.g. Lowes Home improvement center
2. Types of parts required depends on the extend to the damage,
3. The hinge joint bands when acquired would require installation by plumbing expert
4. The entire seat cover acquired would require expert installation too
5. The type of parts acquired would require moretechnical expertise than some kind of parts
retailers where to find restroom equipement listed below
lowes home improvement centers
Home depot
Wal mart
Home tile and fixture stores
Important notes
1. contact a plumber for expert consultation
a. evaluation of the extent to damage
b. recommendation of what to acquire to replace
c.contact plumber when parts have been acquired for installation.
look up plumbing services
1. on the yellow pages on telephone for possible services closest to tour area of residence
1. perform an online search for plumbing services
2. Several options available to acquire professional plumbing expertise and acquiring parts for the same purpose
Posted on Dec 02, 2010
Soft close toilet seat
Mine is a Bemis and does the same thing. Seat drops and lids does a slow close! Are you going to takes yours back for a new one?
Jan 18, 2014 | Home
My slow close toilet seat now slams shut. Are there any adjustments I can make to correct this problem?
WOW! Slow-close toilet seats. What will "they" think of next, to pick your pocket?
Slow-open mechanisms such as cassette players and top-loading DVD players use a special type of grease to achieve that effect.
The screen on the laptops uses a friction mechanism based on a "clutch-spring" with enough holding power to keep the display in the position selected.
This "clutch-spring" is factory adjusted so it neither slips under the weight of the laptop screen, nor is so tight that extra force is required to close the laptop.
These things do wear out, and as a rule are not user serviceable.
Can you adjust it? Good question!
Can you adjust it so it works? Ahah!
My rule of thumb: If it's already broken, how much more broken can it get?
Therefore, my conclusion is that the toilet seat's slow-close mechanism is factory set at the point where it will neither slam down nor stop half-way, but glide down gently until it's closed.
An interesting added feature would be for the toilet to recognise who's about to use it, and for what, select the seat position be it up or down, and then regulate the water volume needed to flush.
Also, it could flush itself once the lid is fully closed, to avoid or minimize the dreaded "toilet flush mist". arrrghhh!!!
Jul 04, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
QUIET CLOSE TOILET SEAT COVER CLOSES VERY, VERY SLOWLY. HOW CAN I CORRECT THIS TO CLOSE FASTER>
There is no adjustment for a slow close/quiet close seat. It would defest the manufacturers intent.
May 20, 2010 | Kohler Toilet Seat - Elongated Front Quiet...
I have a Jika Mio soft close seat with a loose hinge which I cannot reach due to closeness of pan to wall!!
The top lid of my soft close toilet seat slams shut.How do I adjust Jiko Mio close coupled toilet.
Mar 27, 2010 | Villeroy & Boch Home
Slow closing toilet seat not working
It needs a new air shock on it. You might be able to take the old one apart and fix it but replacement would be best.
Feb 11, 2009 | Kohler Toilet Seat - Elongated Front Quiet...
Dec 22, 2008 | Toto Aquia II Dual Flush Toilet
Toto Aquia II Dual Flush Toilet Logo
464 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
