Question about Police Watches
After changing the battery in my Police Ventura watch, the 1/10 second hand now starts to sweep in the wrong place. How do I reset the start position?.
SOURCE: luminox 8152 chrono
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
Posted on Sep 12, 2008
  • 3 Answers
SOURCE: re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. ashfaque.r@googlemail.com
Posted on Jan 05, 2009
SOURCE: I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Posted on Jan 12, 2009
SOURCE: second hand on my watch now goes in 5 second intervals
Check the instruction manual if you have one. Tag-Heuer watches move in 5 second intervals to let you know the battery needs replacing. A neat feature. Now you know that you have a real Tag!
Posted on Jan 17, 2009
escapement
  • 2334 Answers
SOURCE: The second hand on my luminox 8150 does not reset to 12 o'clock
Pull out crown to the first click. Push and hold pushbutton at 2 o'clock till the seconds hand reaches desired position. Push the crown back. You may need to operate pushbutton at 4 o'clock instead of pushbuttton at 2. Try both.
Rate me, please.
Posted on Mar 23, 2009
I have a police chronograph watch about a year old if that and the chronograph dials have reset themselves at random points does anyone know why and if so is there a fix? many thanks david
hi,
all you need to do is pull the centre bezel out (to where you adjust the time) and by pressing the top button the chronograph needle will move round. Once it is the correct place simply push the centre bezel back in.
Hope this helps.
Duncan
Dec 17, 2009 | Police Watches
Cant set the second hand to move
The "second" hand on this watch is not actually a 'sweep' second hand, as on other watches.
This is a timer dial. ["Stopwatch 1/5 Second Hand"]
To start/stop this, use the top button (Button "A").
To reset this dial to 12 O'clock, use Button "B", after first stopping it with Button "A".
The "second" hand is the small dial at the 9 O'clock position.
In actuality, you 'could' start this and just not stop it...  Then it would function as a "large second hand". That would be up to the owner. (it might use more battery power though... ?)
Nov 11, 2009 | Pulsar Chronograph Watch
The seconds hand will not zero when reset
The chronograph can be reset by pulling out the crown to the first or second position and pressing the start button or top button. This will begin to move the sweep arm and you can stop it on the 12:00 or 0 position. Make sure that when you have the battery changed they do this for you.
Sep 22, 2009 | Watches
My Movado Series 800 second hand zeroes out at the 3-second spot, not at zero (12).
Sep 17, 2009 | Movado Series 800 Watch
Second hand sweeping five second increments
Yes, it is sign for time to replace the battery. Your watch is fitted with EOL (end of life) device. This device forces the integrated circuit board to move seconds hand in 2 - 5 seconds increments when the battery power level is less than necessary for smooth running of the watch movement. At the same time the timekeeping of the watch is not affected and it will still keep good time for about 2 weeks.
Rate me, please.
Apr 08, 2009 | Luminox 3402 Wrist Watch
Sweep 2nd hand operation & watch time setting on my Pulsar watch.
The larger second hand on the Pulsar PF8036 is part of the stopwatch feature. The upper button starts/stops the stopwatch feature, and the lower button operates the lap/reset function. Why they made the larger hand work only with the stopwatch instead of the smaller hand to the left is beyond me, but that's how it is designed.
Oct 09, 2007 | Watches
Kenneth Cole KC3081
if you pull the crown out to the #2 position,then push the start/stop pusheryou will move the sweep sec. hand up to the 12 o'clock position. push in crown. Don
May 22, 2007 | Kenneth Cole KC3271 Wrist Watch
Watches Logo
15 people viewed this question
Top Police Watches Experts
Ansel Alberto
Ansel Alberto
David Woodhead
Level 1 Expert
Tom Chichester
Are you a Police Watch Expert? Answer questions, earn points and help others
