Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint washing machine wf840 wont turn on no lights
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
Posted on May 30, 2009
57 varieties
  • 1653 Answers
SOURCE: Hotpoint WF840 W machine still full of water error code F 05.
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
  • 193 Answers
SOURCE: i have a hotpoint washing machine WF840 which is
f09 i s a communication problem between mother board and controls.Before replacing board, I would suggest unplugging unit and re-terminating each connecter going to board
Posted on Nov 01, 2009
  • 662 Answers
SOURCE: i have a hotpoint wf840 everytime i enter a wash
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
Posted on Jun 08, 2010
  • 86 Answers
SOURCE: I have a hotpoint wf840 washing machine (6 years
F08 means you have a heater fault and in this case because the water isnt getting hot the program wont advance. Check out the heater and related wiring. If you dont already know the heater is at the rear of the machine. For more information about error codes go to www.selfix-uk.co.uk
Posted on Jan 31, 2011
Hotpoint wf840 fault (F-02) please help do u know what tis means?
try checking motor - module connections -brush - tacho on the motor
Nov 04, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
I have a hotpoint wf840 washing machine (6 years old) and the wash program will not complete the drum turns but will not advance to the end or spin and on the front facia it states f-08 what does tis mean
Jan 31, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
I have a hotpoint wf840 everytime i enter a wash cycle it just says test and performs a spin cycle whilst test still comes up on the screen is there anything i can do other than buy a new washing machine
May 05, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint wf840 displays h20 all the time
This is indicating a problem with the water supply to the washer.
Check inllet hose/s, make sure they are not kinked or restricted , make sure tap/s are fully turned on.
Make sure water presure is o/k.
Mar 18, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
WF840 is flashing H20 what is the problem
machine cant take in water, if you hear a quiet hum when a programme is started that will be the inlet valve opening, check the inlet hose isnt kinked, the water tap is on, on the isolator tap sometimes the little handles snap and you cant turn it on or off, remove the handle (littlwe screw on top) and turn it with a small spanner
Jun 09, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima super silent w f 840 shows fault 03
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima
the code on my hitpoint wf840 this code keep flashing f-01 i dont what this means could you help me please.
Feb 13, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Washing machine
Do you have your hot and cold water turned on? Is there enough water pressure? Are there any kinks in the hose? Check also the inlets (with the hoses off), for any clogs or blockage into the washer
Dec 18, 2007 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Ultima WF860 Front Load Washer Logo
15 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
