Question about McDavid Health & Beauty
I have a bump in my arm
I was skating at the skatepark i was tring to drop in but than i fell hard when i got up i looked at my elbo and right next to it there was a bumb. This hapened like 2 weeks ago and i still have the bump. im just wondering if anyone knows what this means.
    Sergeant:
  • 462 Answers
May have chipped a bone get it checked
Posted on Dec 12, 2012
How do I fix the tonearm of my Technics SL-1950 so it doesn't keep pulling to the right when in neutral balance?
The anti-skating control adds an outward pull to the arm to compensate for the inward pull exerted on the arm when a record is being played.
Setting the anti-skating control to "0" should virtually eliminate the drift you mention when the arm is in neutral balance. Also make sure that the whole unit is level as this may also affect the arm's tendency to drift.
Dec 11, 2014 | Technics Audio Players & Recorders
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Apr 14, 2011 | Denon DP-47F Turntable
My arm slides across.dont no how to adjust counter weight.
hello george!
first of all remove any needle protectors provided, there is some "weight" on the arm (at the opposite end from the needle). Release the tonearm, you have to turn the weights untill the arm is in balance, then turn 2 and a half so that the needle will go down (2.5 grams), this is the optimum pressure for the needle (pick-up), some people will tell to do more pressure on the pick-up but this will result in higher wear down. On the other hand necessarily this is needed for environments with higher vibrations like discothekes. Be careful not to allow the needle to drop onto the mat or the turntable platter during this adjustment.
The next step is to adjust (if available) the anti-skate adjustment. Set the antiskate adjustment to the same number as the needle pressure setting (i.e. 2.5 grams would be an anti-skate setting of 2.5). If you are back cueing or scratching, then set the anti-skate setting to 0.
regards
Thank you for using FixYa! A four thumbs up rating is appreciated for answering your FREE question!
Apr 12, 2011 | Pioneer Audio Players & Recorders
Need to know what settings the anti-skate and the counterwieght on the back of the tone arm should be set to. Also when pressing start tonearm will not move at all. Can still cue it manually...
The counterwieght should be set the tracking force for the cartridge/stylus fitted. These are expressed in grams. Typical about 2 to 3 grams. If the weight has numbers on it these will match the grams. There's no right setting for the skate. Should the stylus start to skate accross the record increase the force. Start low!
On the arm movement, has the arm moved before after pushing start taking it to a record? As many turntables just don't.
Jan 01, 2011 | Technics SL-1200MK2 Turntable
Counterweight on my technics 1200 wont catch to screw on. Threads inside the weight look fine but there seems to be a small "bump" on the under back side of the tone arm. This "bump" doesnt stick out as...
It doesn't screw on, it pushes on....
"With the tonearm locked in place, put the anti‐skate
dial on "0" and push the counterweight onto the rear of
the tonearm. Make sure that the numbers face to the
front of the turntable. Turn the weight until you feel it
"click" into place.
Unlock the tonearm from the rest, and move it
toward the middle, about one inch from the edge of the
platter. Hold the arm off the surface with your right
hand on the finger lift. Begin turning the counterweight
one way or the other, until the arm seems to just
"float".
As seen in the picture, the arm, when properly
floating, will not face up nor down.. it will stay
with the platter. It may take a few tries to get
correct. Lock the tonearm back on it's rest.
Holding the rear, silver, section of the counterweight
with one hand, use your other hand to turn JUST the
number ring. It doesn't matter which direction you turn
it, but you will want "0" to face up when you are done.
Using just one hand, turn the entire counterweight
(the silver part) COUNTERCLOCKWISE until the
recommended tracking force is achieved. New
cartridges will tell what the ideal number is. As a rule of
thumb, however, most "hi‐fi" cartridges track between
1 and 2 grams, while most DJ cartridges track between
3 and 5 grams.
Set the anti‐skate dial to coincide with the tracking
force... in other words, if the tracking force is 2 grams,
set the anti‐skate dial to "2". The exception is for DJ's
who scratch and back‐cue. Your anti‐skate must be left
on "0". "
Feb 16, 2010 | Technics SL-1200MK2 Turntable
How to adjust automatic anti skating system on a PE 2015 record changer? Had to replace magnetic cartridge and needle by an other system, and the arm pulls too much towards the external side of turntable....
Elektrotanya for electronics experts search for the word processing that will change to GET MANUAL after a while you have a manual but there should be a tool neccesay for the arm or Tone arm geometry knowledge or almost there was a tool for the novice user there delivered with the turntable because the error angle setting for the needle special if you replace the complete element with needle
Jun 11, 2017 | Audio Players & Recorders
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Nissan 4004 se-r sentra making squeaking noise from front end
Need to help me out more,
What kind of squeaking - how fast - turning left or right - how hard.
Does it go away under any special conditions ie wet, hot, cool etc
Applying brakes make a difference
When hitting bumps or speed bumps
Give me a little more
Aug 01, 2008 | 2002 Nissan Sentra
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Marantz TT221 turntable anti-skating problem
Hi, sounds more like tje stylus tip is gone and therefore the needle isn't holding to the grooves rather than a tracking weight or anti skate problem. Styluscity@gmail.com
Mar 27, 2008 | Marantz Reference TT-15S1 Turntable
Health & Beauty Logo
48 people viewed this question
Top McDavid Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a McDavid Health and Beauty Expert? Answer questions, earn points and help others
