Question about Kenwood KAC-629S Car Audio Amplifier
Wiring diagram for kenwood 350 watt amp - Kenwood KAC-629S Car Audio Amplifier
SOURCE: Wiring Diagram
First, try looking here: http://www.crutchfield.com/learningcenter/car/amplifiers_movie.html If that helps, be sure to leave feedback or I don't get paid. Look all over the cruchfield page and you can find guides for every type of installation.
Posted on Oct 03, 2007
  • 142 Answers
SOURCE: kenwood 350 w-2 amp wiring
you can simply take the input and connect it in parallel to the input of the second amplifier. The output of one amp will go to one speaker, and the output of the other amp will go to the other speaker.
The inputs of amplifiers are "high impedance" so putting more than one in parallel won't put any strain on the radio circuit.
Hope this helps.
Posted on Mar 27, 2008
  • 10 Answers
SOURCE: kenwood kac9152d bridge mono wiring diagram
I have owned this amp for 2 years and i have it up to my kicker L5 sub, in a 3.1 cubic foot ported and chambered box that is tuned to 33hz. the amp can be wiried for eitherrunning one sub or several subs, rms power is 500 watt @ 4ohm, 900 watt @ 2ohm, and 1600 @ 1ohm. it is a strong amp, and it puts out large and powerfull amounts of energy, the bass remote is an added touch, i had it set to 100hz on the amp at +1 on the input sensativity, i ran my sub hard producing 138.40 db on a term lab. and i only had the remote at +9/+11 for level and set to 43hz on frequency boost, if you have only one sub with single 4ohm voice coil run it on the outer sides of the speaker outputs on the amp, if you have a dual or quad voice coil, you can either lower the ohms wiring the sub in a paralelle circuit, or up the ohms by wiring the sub in a series circuit. if you have 2 or more subs, wire them left and right channel, the amp has 2 out puts because it is a dual monular amplifier, meaning you can link 2 or more amps together to wire one or multiple subs, witch makes this amp perfect if you have a 180db, @ 18hz **** , than this amp is for you!!!!!! if you need more advise on the amp or how much power it needs to run it or when the amp loads into protection mode feel free to email me @ zekk68@hotmail.com
Posted on May 22, 2009
soloxilu
  • 65 Answers
SOURCE: 920 Watt Kenwood Amp wont power on
Connect the remote wire to an accessory wire on your stereo.
Posted on Jul 08, 2009
  • 16 Answers
SOURCE: car audio amplifer blowing fuses
why are you in stereo for subs? mono all the way.
Posted on Feb 22, 2010
How do i get full power out of my kenwood kac-1520s amplifier hooked up to two 12" audiobahn 400 watt subwoofers
Your amp is under powered for those speakers (350 max. watt). Even if your subs were 2 ohm your amp will only put out 75 watts X 2 at 2 ohms, if you bridge that amp you might be asking for trouble . I'm guessing there both 4 ohm. Look around for a 2 ohm stable mono amp with more power and you won't be sorry. Ray
Apr 23, 2014 | Car Audio & Video
I have 3 Kenwood 12'inch subwoofers need to know how to wire them up to a Kenwood KAC-9105D
Follow the link and use the first diagram which illustrates wiring the subs to 2.66 ohms http://www.the12volt.com/caraudio/woofer_configurations.asp~Q~3~I~42
Remember that that amp is one ohm stable so you will not be getting the most out of that amp with that subs set up. The subs will only see 650 to 850 watts total...so each sub will only see about 215 - 275 watts a piece. Find out what the RMS wattage of your subs are each an determine if the wattage I mentioned above meets those requirements.
Sep 27, 2012 | Kenwood 12" 4-Ohm Single-Voice-Coil...
I need a wiring diagram for the jensen lxa400. Pushing 2 kenwood 6x9 (200 watt rms each) and 2 dual voice coil 12's (300 watt rms each) in a truck box. Everything is 4 ohm. Thanks, Curtis
you shouldn't need a diagram all you need is these items here.
purchase a 4gauge wiring kit
run a a power line from battery to amp with a in line fuse 6in from battery.
run a ground from car frame to amp. ( scratch paint and screw it down with an eyelet for good contact)
run a remote from radio to amp.(blue wire)
run rca's from the radio to the amp ( sub input on back of radio)
finally connect your speakers.
Mar 26, 2010 | Jensen LXA400 Car Audio Amplifier
I NEED TO KNOW HOW TO WIRE THREE 3012 THWELVES TO A 1800 WATT KENWOOD AMP
Its hard to tell what you can or cant do without knowing exactly which kenwood amp you are using. Generally speaking though most kenwood amps are stable only down to 2 ohms. you will be better off just using 2 of your 12s wired in parallel- that will give you a 2 ohm load. There is a way to use all 3 simply by wiring them in series, it will end up giving you a 12 ohm load on the amp though which will work fine but you wont ever achieve the full power that the amp can do.
Jan 17, 2010 | Kenwood Kfc-w3012 12" 2400 Watt Car Subs...
Watt size fuse do i use to connect a 350 watt stereo/bridgable amp using a 4 gauge power cord
You use the same amp fuse as on your amp, nothing larger. The fuse just keeps the wire from overheating/shorting and causing a fire.. IF you amp has a 30 amp fuse then you use a 30amp fuse off the battery
Sep 10, 2009 | Kenwood KAC-629S Car Audio Amplifier
AMP
That amplifier is only stable to 2 ohms.
You will only be able to use one Dual 4 ohm Subwoofer wired in parallel (all + to + on amp.... all - to - on amp.
This will yield a 2 ohm mono load.
It is impossible to wire (2) dual 4 ohm voicecoils to achieve a 2 ohm mono load.
If you're set on using both subwoofers - they will not be getting as much power from your amplifier with a 4 ohm load - but it is your only option.
SEE THIS LINK for the wiring diagram.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jul 02, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Subwoofer amp problems
I would suggest 16-18 gauge wire it will handle the 500 watt max u will b running
Apr 18, 2008 | Kenwood KDC-MP235 CD Player
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-629S Car Audio Amplifier Logo
62 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
