Rca rtb10223 no voices just surround sound
Can hear music and most others sounds, but not the voices, the voices are very muted.
  • 48 Answers
SOURCE: No voice sound through speaker with DVD system, only music?
first check the settings on the audio menu of the dvd player. make sur it is set to 5.1 (if available) otherwise set it to stereo and your system should decode it.
assuming the second step is okay : as other dvd you play seem to work) it still may be that your unit is decoding stereo inputs just fine and 5.1 is not working properly....
so if adjusting audio settings in dvd play back menu dont work,
check that the cables to the satellite speakers are connected correctly and all plugged in soundly ( voice is high frequency,- coming from satellites - the garbled noises you hear are the base ( low freq) elements of voice which are coming from the bass box ( that the X.1 part of 5.1) and so that is obviously working. ,
Posted on Mar 08, 2008
  • 161 Answers
SOURCE: the background music is louder than the voices
in the menu there should be some type of set up for this, it will most times show you on your screen a room with all the speakers in it and ask you to hit test then it will shoot a white noise type of sound around to each speaker and ask if you heard it, there are then adjustments you can make for the front, rear, and side sperkers independent of one another.
Posted on Mar 24, 2009
cjackHD
  • 71 Answers
SOURCE: when watching a DVD, the surround sound plays all
If there is nothing at all from the center channel while watching a DVD, first try resetting the system (unplug the power cord from the sub, and the DC power cord from the media center for 30+ seconds) If a reset doesn't help this, run the "adaptIQ" setup disc again. Honestly, this is a very odd problem for that system to have. (especially since we know the center speaker works for other sources) I hope this helps.
Posted on Jun 22, 2009
  • 132 Answers
SOURCE: RCA 5.1 Surround Sound Receiver Sounds fade in and out
chk how you are hooking up the speaker polarity minus to minus and plus to plus.
Posted on Oct 17, 2009
mtatham
  • 13 Answers
SOURCE: Backround sound is fine but voices speaking are muted
I'm not sure of this system but if this was mine I would say it sounds like your playing this in a 2-Channel mode which eliminate the center channel.
you music may be set up fine, but the mode you play a dvd in may be set up for 2-channel mode. try a dolby prologic 5-channel or some other mode if you have one.
Mike
Posted on Oct 19, 2009
UBX Home Theater System
It sounds like a problem with your centre channel or speaker. The sound of Voices and on-screen, actions in the middle of the screen are played through the centre speaker. General sounds such as music in the background, off-screen events, etc. will be played through other speakers on a home theatre system. Check your connectors coming from your DVD player to your sound system. Are you using a single-cabled digital connector or one for every channel? Check your sound settings as well, i.e., Surround, AC3, Music, etc.
Jan 30, 2014 | Audio Players & Recorders
Audio problem streaming media via ROKU and RCA players. Constantly have to adjust volume to hear them talk, but then the music/sound effects blast you out.
It sounds like you're using a set of stereo speakers to play a surround sound output. I would try going in the TV menu and turning off surround sound
Dec 23, 2013 | Televison & Video
I have a RCA RTB10223 model, and my problem is I can get the surround sounds to work with a movie in, but its not working with the regular TV. What do I to get it to work?
That is because your movie is in 5.1 surround or better. Over the air and cable broadcasts are not always broudcasted with surround sound, there fore you will not always get it.
Apr 26, 2012 | RCA RTD317W Theater System
Some DVD's sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it?
" Some DVD\'s sound fine whilst others have background sounds but no voices. I do have an old model TV that has mono sound.Would that cause it? "
I wrote a short article for someone who had a similar problem a few days ago.
I will edit it for you so that it fits. Here it is.
Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO (or MIXED ) Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo(or MIXED) then the dialog will be sent to the CENTER channel output. If you have no center channel speaker you will not hear it. Thus no dialog.
NOTE: In your case for the TV that is mono, here is the solution.
1 Connect a stereo pair of RCA cables (red and white "male" connectors at each end) to the Mixed or Stereo Output of the DVD player (NOT ANY SURROUND OUTPUTS).
2 Purchase an RCA type "Y" connector that has 2 female to a single male connectors on it. Walmart about 3 dollars.
3 Plug the single male plug of the Y connector into the back of the TV set's single mono audio input.
4 Connect the stereo RCA pair from the MIXED output of the DVD player into the Y connector that is now on the back of yourTV.
5 Run your yellow Video output from the DVD into the Back of the Set's yellow input.
That should do it. The sound should be clear and correct with dialog, effects and music.
Hope this helps,
Best,
Mark
Jan 27, 2011 | Audio Players & Recorders
I can't hear the voice of songs during playing music
You might have muted the sound. So to fix your problem follow the easy steps
  • Click start
  • Go to control panel
  • Click "sound,speech and audio.devices"
  • Click the second option "Sound and audio devices"
  • If there is a tick on mute undo it then Click on OK and then click on "Apply"
Your problem would be fixed
May 21, 2010 | Advantech IPC-610-H (IPC610HP72456) PC...
Mike
Oct 18, 2009 | Audio Players & Recorders
Can't hear voice of singer on speakers, more of an echo sound
An old trick to remove vocals from a song was to rip the right channel, then the left, the combine them (since vocals are typically mixed in a third 'center' channel, though things like reverb or echo are applied to the right and/or left channels which sounds like what you are hearing).
I would play with the balance and mixer settings and see if you can get the vocals back. Also try other speakers or even headphones and see if you have the same problem.
Hope this helps!
May 28, 2009 | Bose Companion 3 Computer Speakers
Background sound too loud
Thank you, everyone! I thought maybe I was losing my mind. I can hardly watch a lot of the TV shows anymore due to the inappropriate use of music -- either it's too loud or there's just too darned much of it. Come on, TV producers! You are supposed to get better with time, not worse! Thank goodness I'm not alone.
May 30, 2008 | JVC AV-32260 32" TV
Emerson dvd player - background sound lauder than dialogue
Greetings surfjax,
If you will allow me to make an assumption, you do not have a 5.1 surround system connected to your DVD player. This is a common experience with users of a standard TV or stereo receiver if a movie is being presented in 5.1.
In a surround sound system the center channel speaker provides almost all the vocal tracks while the side channels will provide music and some background noises. You'll still be able to hear the voices in your side speakers, but it will be muted and over powered by music or sound effects.
Some DVD players allow you to "Downmix" the surround signal to stereo. You might want to look around your sound setup on the DVD player or check your owners manual.
Hope this helps.
Jon
Go Ahead. Use Us.
May 22, 2008 | Emerson EWD7003 DVD Player
Proluxe ce818
I have this DVD player, and it has surround sound connectors, and seperately L/R connectors.
Whilst the L/R should mix-down the surround sounds, it doesn't appear to and only actually play the surround sound left and right.
My solution was to plug one of the RCA leads into the "Center" of the surround output, (can leave the other in the L or R slot)
you'll then get voice, out one speaker and ambient sounds out of the other.. It sucks, but that's why this things a freebie.. it's not well designed :P
Nov 26, 2007 | GoVideo DVD-VCR Combo
44 people viewed this question
 Grubhead
Grubhead
