Question about BellSouth 2252BK (22 Channels) 2-Way Radio
BellSouth 2252 how to operate the transceiver
2 Suggested Answers
  • 5188 Answers
SOURCE: I can't find the manual,
The range of the BellSouth 2252 will depend on the frequency and the surrounding environment. If you get the FCC license and operate in the GMRS range, then the radios will have a maximum of a 2 mile range. The surroundings will matter: hills, buildings, etc. will shorten the range.
If you are using the FRS frequencies, your range will be significantly shorter (again depending on the surroundings). I'd guess no more than 1/2 mile line of sight.
I hope this helps.
(who uses another brands of two-way radios and the ones with a 5 mile GMRS range work over 1/2-3/4 of a mile depending on hills. The ones with a shorter range can't communicate with someone at the far end of the property. It's about 3/4 mile from the road to the back fence.)
Posted on Jul 14, 2011
Need Operating Manual
Manual for Bellsouth Gh5831BK correct? WIll look for it.
Aug 23, 2008 | BellSouth GH5831BK Cordless Telephone
How do i get i n h off of display of my radio shack htx 202
HTX-202 (190-1120) Error Codes Faxback Doc. # 15722 Your transceiver has two error code displays. Refer to the following for an explanation of each error code. Er1: INTERNAL RAM ERROR Er1 indicates the transceiver has detected an error in its battery-backed up operation memory. This is the most commonly caused by a low lithium backup battery, but can also be caused by static discharge, or a physical shock. To clear the error-- 1. Turn off the unit. 2. Press FUNCTION and CLR (the D key). 3. While holding these keys, turn unit on. This will reset unit and clear memories. If the transceiver frequently displays the error, have the battery replaced by an authorized Radio Shack service center. ER2:PLL UNLOCK ERROR Er2 indicates the transceiver's PPL section has unlocked. Have the transceiver repaired by an authorized Radio Shack service center. (/ir-07/31/95)
Nov 01, 2014 | Radio Communications
How can I program the Kenwood TM-G707 A/E transceiver to our new repeater with a REC. of 151.1225 TX of 159.015 with DPL of 172 and 134?
I believe that your transceiver requires a simple mod which involves removing a surface mount diode or resistor usually found in the front display head.This allows the device to operate out of the intended frequency band.You may Google Transceiver TM-G707 A/E Modific ations for further info.
Oct 30, 2014 | Radio Communications
I need a down load of the operating manuel for bellsouth model 2266
There are not a lot of sites relating to Bellsouth air conditioners but I have found a couple you can try contacting. Just send an email or look for "contact" on the site and explain your problem.
http://local.triangle411.com/eastern+air+conditioning+services+hvaceacs@bellsouth+net.9.55351704p.home.html
http://realpages.com/sites/calcotes/
calcotes@bellsouth.net
Aug 21, 2011 | Heating & Cooling
I can't find the manual, and I was wondering how far away you can talk on the BellSouth Walkie Talkies Model 2252?
I hope this helps.
Jul 14, 2011 | BellSouth 2252BK (22 Channels) 2-Way Radio
Locked
0000 is the universal code ,else download go to the mob. shop near u and they have some software to open it..charges r nominal 50-100 rs.
Dec 06, 2007 | Philips 2252 Twin Cordless Phone
BellSouth 2252BK (22 Channels) 2-Way Radio Logo
Top BellSouth Radio Communications Experts
ka4iup
ka4iup
BJ Russell
Are you a BellSouth Radio Communication Expert? Answer questions, earn points and help others
