Question about Procom ML300TBA Heater
Can't get propane heater to lite
I have tried different hoses, conectors and regulator to avail. the pilot lite barely has a flame, will not lite enough to get flame for the heater
  • 3 Answers
Not enough information to solve the problem correctly but I'll take a guess at it......
This heater requires a 100lb propane tank (approx. 25gal) with 1/2" or larger piping to deliver the correct volume of gas to the heater. If you are using a smaller tank (like a 10gal) or the piping is not the correct size you will not get enough gas to the heater to light the pilot. Also you should have a regulator set at 11" to 14" of water column installed between the tank and the heater. If the tank is connected directly to the heater you may have damaged the internal regulator in the heater.
Posted on Feb 18, 2009
  • Procom Master
  • 3,150 Answers
Blocked pilot injector clean out pilot should work then
Posted on Jan 02, 2009
Coleman heater model 5445c700 propane camp heater wont light. It did work fine. When I hold the knob in the light position you can hear gas but it barely ignites then goes out. I've tried new gas and...
If you're using a 20lb propane tank (Gas Grill Tank), that may be the problem. Turn off the propane tank at the tank valve and disconnect it from the tank. Wait 5 minutes and reattach the heater hose to the tank. Turn the propane tank valve on very,very slowly until it's all the way open. Try lighting your heater now. If the pilot flame height returned to normal, that was the problem.
FYI - The Thermocouple has nothing to do with the length of the pilot flame. It's a safety feature that stops the gas if the pilot flame goes out for any reason.
Hope that solves your problem. Please let me know.
Feb 07, 2011 | Coleman Heating & Cooling
Pilot light too big, how do we adjust pilot light on a Vanguard KV1800?
There is no adjustment for a Pilot Flame's Length on a Vent-free Gas Appliance. However, if you're using Natural Gas and it's a Natural Gas Heater, the normal length of the pilot flame is 2 to 2 1/2".
If it's a Propane Gas Heater and the pilot flame is as long as previously stated, you probably have a pressure problem from your tank. Contact your Propane provider to have them check the pressure on their tank regulator.
Jan 31, 2011 | Vanguard Heating & Cooling
Gas doesn't seem to flow
The easy fix is a new regulator, if it is not the regulator you probably have a blockage in the pilot assembly. You have to take the head apart ot find and clear the blockage. If you are not comfortable with this, hire a service tech.
Jul 04, 2009 | Endless Summer 2009 Open Flame Patio...
Propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Feb 15, 2009 | Mr. Heater Mr Heater Portable Buddy...
Pilot wont stay lite
You either have a bad thermocouple or you need to reset the burner control.
Jan 29, 2009 | Coleman Propane Forced Air Heater...
I have a propane reddi heater and I can't get it to stay on after I light it, it won't stay on. Is there something that needs to be cleaned or replaced
Generally speaking a propane heater stays lite because the pilot stays lite. The pilot flame touches a thermocouple which produces a current which keeps the main valve open. Pilot goes out or you have a bad thermocouple or the pilot is slightly clogged (reduced heat to thermocouple) or maybe the thermocouple is not touching the flame enough. Most times when a propane heater goes out the problem is somewhere in that neighborhood. Thermocouple - pilot. I have always had luck carefully taking those parts off, cleaning, and reassembling, but check the position of the thermocouple first. Looks like a small brass rod which sticks into the flame. This is a safety mechanism to prevent the flame being blown out and leaving the gas on. Good luck
Jan 16, 2009 | Heating & Cooling
Can not get the bricks to light on my empire corcho
I have the same htr in Mich. & have worked on gas htrs.for many years.
Does the flame go out when you let go of the button to lite it?
If it does, then the thermocouple is bad.
If the flame stays on, but goes out when you turn the dial,
the gas regulator is bad.
Probably a little more expensive to buy new then to fix it.
Nov 20, 2008 | Reddy Heater RLP100 Portable Forced Air...
Pilot does not lite
I took mine to a local repairman. He fixed it.
Sep 25, 2008 | Procom (CGL100MZ) Infra-Red Heater
Heating & Cooling Logo
259 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
