Question about Euro-Pro 9130 Sewing Machine
How to correct a needle jam on Euro-Pro 9130C sewing machine
I can't get the needle unjammed and there is no mechanical solution
4 Suggested Answers
  • 68 Answers
SOURCE: The dog feed stuck in the downward position.
When you set the switch for the feed dogs to be in the up position, turn the handwheel 1 complete revolution and they should come up.
Posted on Feb 25, 2010
kapishtech
  • 2272 Answers
SOURCE: Euro-Pro, Model 9130C sewing machine keeps on
Your bobbin case may have a bit of thread stuck in it. you should also clean the lint out from under the feed dogs. just unscrew the face plate and use a little soft brush, .Also check the foot pedal cable movement.Is the cable got over tight or pulled .if yes then make it bit loose then recheck. Keep updated.Thanks.
Posted on Sep 23, 2010
Tally Girl
  • 1122 Answers
SOURCE: need to locate a source of blue tipped sewing
Schmetz make a blue coated needle, usually best for denim fabrics as the coating aids the needle in slipping between tightly woven fibres such as denim. It may also be called a Denim needle.
But you shouldn't need to use that needle for most fabrics, just the most appropriate sized needle and either sharp point for wovens or ball point for knits. Perhaps get a mixed pack of both sharps and ball points to start with.
Try this website if you want to shop for needles on line, http://www.sewingpartsonline.com/sewing-machine-needles.aspx they carry a wide range of types, sizes and brands. Klasse and Schmetz are both high quality needle brands. You want the 130/705H system of needles for your domestic sewing machine. These are the norm for 99% of domestic sewing machines.
There are other needle systems for industrial machines (round tops) and EL705 for overlockers, these are extra long but identical shank design at the top. So just make sure you get the regular needles 130/705H.
In terms of what size to use, here is good reference guide on sewing machine needles.
http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/Needle-Sizes.--94.htm
The important thing is to change the needle for each new project, ie about 4-6 sewing hours, as a blunt needle will never give good results. If you always start with a new one, and its the right sized needle for the fabric you are sewing, then you should ensure best possible stitching results from your machine.
If the needle is too big, it will leave holes in the fabric, too small and it will break. If you use a sharp point on stretch fabrics, you'll get skipped stitches. If you sew a lycra knit with a ballpoint and it still skips, then change to a "Stretch" needle, this will also be blue coated ballpoint and helps with skipping and needle deflection.
Then there is twin needles, twin stretch needles, winged needles and leather needles, all for special techniques. Never worth trying to scrimp on needles, I have probably have in excess of 40 packs of different sizes and types in my sewing cabinet.
Hope this helps you out.
and they sho
Posted on Nov 02, 2011
My euro pro EP382 problem: needle goes down & then it locks up. When I free it there is an extra thread with the bobbib thread that comes up. What can I do to fix this?
Euro Pro Sewing Machine - YouTube
? 0:59
https://www.youtube.com/watch?v=QndkRbDfM2w
Jan 20, 2009 - Uploaded by simplysoldstore
Euro Pro Sewing Machine. ... on piece on top then runs downthe right side of long and around the bottom up ...
EURO-PRO 380 INSTRUCTION MANUAL Pdf Download.
www.manualslib.com > ... > Euro-Pro Manuals > Sewing Machine > 380
Sewing Machine Euro-Pro Dressmaker 998B Owner's Manual ... take-up lever Palanca tensora de hilo Presser Foot Prensstela Needle plate ... Drop Feed Control / Control De Gota A. Push feed dog lever down to drop feed dog below needle plate for darning, embroidery and button sewing. .... This manual also for: Ep382 ...
Euro Pro Mechanical 30 Stitch Sewing Machine - Overstock ...
www.overstock.com > ... > Sewing Machines
Overstock.com
Rating: 4.4 - ‎5 votes - ‎$119.99 - ‎Out of stock
Shop for Euro Pro Mechanical 30 Stitch Sewing Machine. ... I can sew in the middle of the night and not worry about waking anyone up, it is so quiet, and it sews ...
Amazon.com: Distinctive Even Feed Walking Sewing ...
Jan 05, 2016 | Sewing Machines
Why won't this machine work
Bobbin case might be jammed in an odd position or thread is locking mechanism and wont move hence "the buzzing" sound
May 11, 2012 | Euro-Pro 9130 Sewing Machine
Consew Zig Zag CN2053R-1 needle bar is jammed
sometimes when a machine jams, the machine jumps time
taking it to a sewing machine shop to be serviced would be a good idea
Apr 30, 2012 | Sewing Machines
I was sewing, turned the machine off to pin something, and when I turned it back on, it jammed in the bobbin area. It will only stitch one stitch and then jams. I have taken it apart over 30 times, and...
have you tried changing the needle-
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
check the thread take up lever-if the thread come off the thread take up lever that will jam the machine up--I've had it happen to me
Sep 13, 2011 | Euro-Pro Shark 9110 Sewing Machine
How to thread euro pro 380a sewing machine lost mannel
My needle will not pick up my bobbin? I have tryed everthing! my bobbin was placed in the holder right. my needle is in the EP correctly! not sure if my Thread is correct in my machine. but I have read the manual and still cant get the needle to pic up. Can some one help me out on this! Euro-PRo 380A
Dec 16, 2010 | Euro-Pro Denim Sewlution 380 Mechanical...
Feb 19, 2010 | Euro-Pro 9105 Computerized Sewing Machine
How do I keep bobbing thread from bunching on model 375?
upper part of machine not threaded correctly - no needle tension = bunching underneath
Apr 22, 2009 | Euro-Pro 373 Mechanical Sewing Machine
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Euro-Pro 9130 Sewing Machine Logo
44 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
