Question about HP Photosmart 3210 All-In-One InkJet Printer
Hp photosmart 3300 Ink System Failure 0xc18a106
SOURCE: HP photosmart C6150 all-in-one error
Been on an online chat with HP in INDIA for over an hour. Given that you would "think" the error might have to do with the inside or "ink" you would think they would have me open the machine. If there is enough room you've got to read this online chat. WORTHLESS and I will never buy another HP printer ever again. This All-in-one was 372 days old and for them to not even consider going inside but to immediately tell me to buy another one. I hope you can see all of this. If not email me at SusanVette [at] ya hoo dot com and I will share it with you. Doesn't all fit so here is their bottom line:
Sequoia: I wish to inform you that HP is providing an option to exchange this defective unit with a new released All-in-One unit.
Susan : How much?
Sequoia: Let me also explain the complete process in detail so you can pick the model that suits your requirement.
Sequoia: You can upgrade the defective printer for a upgraded printer. Under the upgrade option, you have the option of buying a upgraded printer at much lower prices.
Sequoia: It means, we will send you with the another printer with a minimal cost (which is equivalent to the service charges for repairing your defective printer) then we will take your defective printer.
Sequoia: Moreover, the shippment charges will be borne by us.
Sequoia: Would you be interested in looking at these options?
Susan : yes how much
Sequoia: We have HP Photosmart C7280 All-in-One Printer, Fax, Scanner, Copier.
Sequoia: You can use the same cartridges with this model.
Sequoia: The features of this model are:
• Built-in wireless and Ethernet connectivity
• Easy two-sided printing
Sequoia: The Actual price of this All-in-One is $299.99 *
Sequoia: However, under upgrade option HP is offering for $157.99
Susan : how do I proceed when i am ready as I want to read all the reviews on that particular model
Sequoia: I am afraid this offer is not applicable in hpshopping.com or from stores, as this offer is only applicable online from us.
Sequoia: If you would like to go ahead I shall arrange a call back for you so that you can order the printer directly from our call back team.
YADA YADA YADA... Write me at above email for full chat.
Posted on Sep 03, 2008
covertgreywo
SOURCE: Ink System Failure (Error 0xc05d1381)
Don't waste your time on the copy and paste HP solution above.
If you really want to fix your printer:
Okay, HERE IS THE ACTUAL FIX FOR THIS ERROR.
1. Disconnect your USB cable.
2. Turn off the printer.
3. Press and hold down these four buttons at the same time:
OK, Cancel, Black, Color.
4. While still holding them down hit the power button once.
5. It will Blink.
5. Hit the power button again.
6. Continue holding until you get a message on the screen.
7. Allow the printer to sequence through and there you go.
Enjoy.
Posted on May 01, 2009
SOURCE: HP Photosmart D7360 - Oxc18a0001 Ink System Failure
I had the same problem and this is how I fixed it... It is hard to get the cover off (and it's not the top cover, but the one on the right side as facing), but once you do follow the directions below.
- Turn off power and unplug from power source.
- Open right side of printer (looking at the front).
- Disconnect by pulling gently, both white flat ribbon cables off the main circuit board.
- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
- Unplug power source.
- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
- Plug in power source and turn printer on (Printer preparing occurred).
Posted on Jul 11, 2009
SOURCE: Ink System Failure HP C5180
-------solution 1---------
HP C5180
Hidden tech menu For resetting and repair, FIX UIAUX
Fixes error 0xc18a0507 error ink system fail
press <left arrow> then press <setup> button together
then press <ok>once support R0631m comes on screen
right arrow 2 times to the System configuration menu
then <ok>
then <ok> to select and ok to confirm reset error.
then <cancel> to escape ( all of witch are onscreen instructions.)
presto restart and no further error
http://www.thecomshack.com/hpc7180.htm
------------- solution 2 ----------------------------------
HP C5180 All-In-One Printer HARD RESET:
Hold down HELP + OK button and unplug printer
Hold down HELP + OK button again as you plug the printer back in.
Then power it on, if it doesn’t power on automatically.
Be Safe: keep holding the buttons until the printer turns itself off. (It took mine less than a minute.)
Now you can release the buttons and simply power it back on.
I got an error message about “improper shut down” since I unplugged it w/out powering down. After I clicked “OK” the printer was just fine and didn’t mind anymore. And now I can print.
Posted on Sep 21, 2009
  • 3 Answers
SOURCE: hp photosmart 3200 all in one ink system failure
I know this sounds crazy but I did this and others have too, it worked. Hold down four buttons at the same time ( OK, Cancel, Black , Color ) and turn the power off. Note: I figured out how to hold the 4 keys down with one hand and push the on/off switch at the same time. Once you power the printer back up is will take a few minutes to go through maintenance. Then it will “hopefully” go back to normal. I did this 2x’s. HP gives you a procedure that doesn't work! They just want to make money off fixing it every 6 months. They are in the service, repair and “ink business” not printer manufacturing.
Posted on Feb 06, 2010
Oxc19a0023 ink system failure. Called HP Tech, and he advised me to enter the Red Eye Removal, Print Photos both together, it didn't work. Then I found the same directions on Fixya.com, so have done...
Try this solution.
http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-2/
The "ink system failure" is caused by air in the ink nozzles. The clear the error you need to do a full purge of the system and the above procedure with do it.
I hope this helps, if so please rate my solution.
BuddyMc
Aug 28, 2011 | HP Photosmart C6280 Printer
Ink failure ink system failure error oxc 18a0001
The "ink system failure" error is caused by air in the ink feed tubes. We have 2 articles posted on our web site giving step by step guides to purging the air from the tubes and clearing the error. You can find the articles at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | HP Photosmart C8180 InkJet Printer
Ink system failure wont do anything
Ink system failure is a faulty printhead issue - call hp and they will have you do a cleaning. Rarely solves the issue and they will end up sending you a replacement printhead.
There support # 800-474-6836
May 11, 2009 | HP Photosmart C5380 All-In-One Laser...
Ink system failure Error: 0x05d1281
Ink system failures is a very serious problem on HP printer systems. Ifyou have this problem you should be ready to replace your printer.However there are still troubleshooting steps that you can do to try toresolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 14, 2008 | HP Photosmart C7180 All-In-One InkJet...
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
Nov 25, 2008 | Office Equipment & Supplies
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
HP Photosmart 3210 All-In-One InkJet Printer Logo
525 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
