Central heating boiler problem
I have a vaillant 242/1e turbomax boiler thats making a strange dragging noise and it wont fire up
  • 30 Answers
This is probably a faulty diverter valve. more info needed
Posted on Mar 26, 2009
Vaillant Gas boiler/furnace not firing up
There is a thermocouple heat detecter in the pilot flame clean it 240 sand paper is ok. replace if not working.
Oct 22, 2014 | Water Heaters
I have a Vaillant ecoTech central heating boiler which has stopped working & is showing fault code F.76 Anyone know what this means please? Thanks
f76 over heat protection triggerd on heat ecxchanger , check water leval of just google vaillant fault codes
Jun 03, 2010 | Heating & Cooling
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Apr 13, 2009 | Air Purifiers
No hot water
My guess would be the unit mifired and need reset.
Mar 10, 2009 | Water Heaters
Vaillant turbomax 28 constant hot water problem.
got your fix, its a calcium buildup in the heat exchanger, and more than likely the rest of the unit, you will need to flush the unit with about 4 gallons of vinegar, you will need to recirculate it for about 20 mins through the unit, then flush with clean water, hook it back up, it might take a couple of mins for it to run properly, but it will, I have had the same problem with Rinnai on demand hot water systems, and it worked like a charm, check the filter thats inline as well, make sure it isnt plugged, clean if needed, also if you dont have a soft water system inplace, you might want to think about buying one and having it installed, that will reduce this from happening again for alot longer period of time, hope that helps
Jan 20, 2009 | Water Heaters
Clock on comi boiler
it may be the preheat setting on the boiler for the hot water circuit. do the radiators get hot when the boiler fires up with the time clock off ? if not then there is nothing to worry about if it is only on for a short time.
Jan 04, 2009 | Heating & Cooling
Heating, but no hot water on a vaillant turbomax 28 combi
the problem is the diverter valve unit, source a corgi engineer to fit new one, cost for valve approx 80 quid +fitting
Kindly
Richie
Dec 15, 2008 | Water Heaters
Hi,i have a vaillant turbomax combi boiler,the radiator side is working well but when running hot tap the boiler kicks in for about 5 seconds ,hot water starts to flow then boiler cuts out,water runs cold...
Which turbomax, as there a two different models. The more modern one, with the brass CPL diverter valve, located at the front left of the boiler, was very prone sticking & jamming, this would restrict flow through the hot water circuit in the boiler, and cause cycling. Vaillant actually modified the diverter. You can identify, if it is the old type, as there is a very small hole in the middle of the diverter on the old ones, probable no more than 1mm-2mm wide. The modfied one, is much bigger approx 5mm wide. If old type, replace as this usally sorts the problem
Nov 23, 2008 | Heating & Cooling
Heating & Cooling Logo
446 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
