Question about Cadet Manufacturing CT402 Electric Heater
Cadet ct402 won't shut off
The heater runs all the time no matter how I turn the thermostat dial
    New Friend:
    Problem Solver:
  • 16 Answers
Thermostat needs replaced or logos wire
Posted on Feb 12, 2015
My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Apr 17, 2013 | Garden
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
We have a Nordyne AC/Heater model # E2EB-012HA. My problem with the unit is that the heater will not turn off and the blower motor also won't turn off unless we switch the breaker to off. Also I...
my nordyne e2eb-012ha after running shuts off most of the time we have to reset the element breaker to get it going again. any ideas can"t find directions to how to get behind breakers thanks morris
Nov 28, 2012 | Heating & Cooling
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
Our cub cadet will run and mow for a short time then it shuts down and won't start if we let it set for awhile then it starts it done this about 4 times now it acts as if it needs the battery char
Take your battery to Oreilly's or autozone,, ask them to check the CCA (Cold Cranking Amps).. this is the true measure of battery quality... if its low, they will tell you and get a new one... see if it runs better,,, it not... you may need the assistance of a qualified professional.. ( may be a coil)..
Aug 10, 2017 | Cub Cadet Garden
My Whirlpool EL7ATRRKQ01 ALL REFRIGERATOR cools but it doesn't seem to ever shut off. No matter where I move the temperature dial, I can hear the fan going all the time. The only time it shuts off is...
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 30, 2011 | Refrigerators
I need a diagram on abaseboard heater
The common usually goes staight to the unit, and the other wire, goes through the thermostat, and the ground wire hooks directly to the chasis of the heater.
If it is a 120 Volt, the white wire should be the common, and the black runs through the thermostat.
If it is a 220 Volt, it doesn't matter which wire goes through the thermostat.
Mar 31, 2010 | Cadet Manufacturing 6F1500W Baseboard...
Cadet Manufacturing CT402 Electric Heater Logo
151 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
