Question about Homelite Backpack Leaf Blower
Mighty lite backpack blower 26bp. once you have it started and try to put it on your back it dies and then you have to take it all off again.when you throttle it. IT DIES!!! had carbourator adjusted all the way out and then it doesn't have enough power to blow leaves off concrete driveway.we have owned it 1 year and still can't use it!!bought because it had 180mph to do massive leaves.
SOURCE: homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Posted on May 09, 2009
bulldogchief
  • 388 Answers
SOURCE: I have a UT08580 Mighty Lite backpacker blower
The Homelite part number for this spark plug is 870174001. This number crosses to Champion spark plug RCJ6Y which can be bought at any Home Depot, Lowes, Ace Hardware, etc for about $3
Posted on Oct 20, 2009
  • 89 Answers
SOURCE: how to adjust a carburetor on a Mighty Lite
if you take apart the carburator youll see a screen under the plate on one side once together turn the mixture screws in all the way till you feel it seat or tighten then back out each screw 1 to 1 and 1/2 turns then start the engine the key is to get it to idle once it idles turn the mixture screw the low side it will say l or h below the screw turn it in which clockwise till it runs smooth then back out slightly till it just starts to miss then rev up the throttle and adjust the high side which is towards the filter turn the mixture screw in till it revs to the highest point which I call the sweet spot your pretty close to what you need
Posted on Nov 08, 2009
rwvanlue
  • 486 Answers
SOURCE: My Homelite backpack leaf blower runs until tank is 1/2 full
I believe you to be correct in your diagnosis.
1) remove the fuel tank
*this will give you an idea of how lines are routed and fitted into tank
2) install a new hose through to tank fitting and make sure to retrieve the old hose & filter inside the tank, so that you can attach the filter to the new hose. The filter is weighted so that it falls to the lowest point to pick up fuel.
Posted on Nov 13, 2009
  • 6 Answers
SOURCE: mighty lite 26b leaf blower will not go full
I took the carb off (easy- two screws), rebuilt and cleaned it, removed the black "H" & "L" needle jet screws (with no screwdriver slots) with a tiny pair of needle nose pliars, 1/8 turn at a time. They are very tight. Then I cut the slots with a fine hacksaw blade and re-installed them. BEFORE you begin, MARK where the "pointer" notch is on each screw so that you know where to reset them and count the turns coming out. Also, cutting the slot 90 degrees off of the pointer mark helps.
An option would be to hold the carb body in a vise and cut the screw slots thru the aluminum guard. Be very gentle, the screws are soft steel. If I had to do it again, that's what I'd do.
Get it running and adjust the "L" at idle until it runs smooth as rich (open) as it can. Then hold the throttle wide open and open the "H" (high speed needle jet) until it runs smooth, as rich as possible. This can be a CHORE.
Remember, richer (more fuel) is better than too lean. Too lean means less lubrication and running much hotter. 80% of the cooling in gasoline engines is from the evaporative effect of the charge coming into the engine. That's why carbs ice-up well above freezing. Ask any pilot.
Posted on Jan 01, 2010
Gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Nov 27, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
My 5 year old homelite backpack blower starts and idles great but when I rev it up it dies
high speed jet pluged in carb get yourself a can of jet spray gumout with the tube take the bottom four screws out be carefull not to tair gasket clean entire serface with cleaner in all to little holes dont get this in your eyes where glasses if you have a little compressed air to dry and clean serface
put all back together and try it again
Jun 16, 2011 | Homelite Garden
I have the homelite mighty lite backpack blower. i don't have a problem starting it. The problem is when i turn the choke to 1/2 and then full running position, i strap it on my back and then this is where...
you have a dirty or blocked carb jets strip down the carb and clean out the running jet
dont poke wire into any of the jets to clean them this will distroy them!!! use car cleaner and cmprest air if you can,,good luck mike
Nov 04, 2010 | Homelite Consumer Products Backpack...
My Blower dies after about 15 min. Then it will
I think its the ignition module. To test the module put 2 spark testers inline with each other and see if it will jump both.
If you dont have 2 testers then use it till it dies and try to start immediately with a prime. If it wont start then module is suspect.
Most manufacturers have lifetime warranty on thier modules ( I am unsure about MTD) so double check before you just go out and buy one.
Jan 02, 2010 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
I have a UT08580 Mighty Lite backpacker blower with a missing spark plug, I need to know what plug goes in it.
Oct 20, 2009 | Homelite Consumer Products Backpack...
Homelite 26bp backpack won't run up to full throttle
Nov 16, 2008 | Homelite Consumer Products Backpack...
Homelite Backpack Leaf Blower Logo
59 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
