Stuck on stand-by bush LY2211wcw
Stuck on standby mode
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: tv has got stuck on standby mode
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 29, 2009
SOURCE: MY BUSH TELEVISION MODEL IDLCD27TV006 HAS POWER TO
Just had same problem today. Presumably you've seen the more recent solutions on other web sites regarding replacing the C330 capacitor. It appears to be an over-temperature issue. After trying to press all sorts of buttons, removing plug for a time, leaving off for a time, it just started to work again but I don't know how! The tv stands beside a radiator and this may have been on for a while and caused this problem. Will monitor situation before diving into its innards.
Posted on Dec 31, 2009
The power for my bush tv model number led26982hdt
My bush television wont turn on from standby? - Ask Me Fast
www.askmefast.com > Consumer Electronics > PlayStation > Wont
Hi my bush tele wont turn on it just keeps flashing at me standby light i ve changed the fuse .... Bush 22 inch tv dvd combi keeps restarting remote doesnt work.
22" bush tv wont turn on - The Student Room
www.thestudentroom.co.uk > ... > Sound and vision
The Student Room
Mar 12, 2012 - 12 posts - ‎7 authors
i got a new tv in january from argos and not had a problem with it until now. The problem is that it just stays on standby and wont turn on. the ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
Hello my bush 22 inch tv is messed up Say if i go on it one day it..... it wont turn on from the power botton on the back not from the control ...
Jan 10, 2016 | Bush Televison & Video
Bush a642f tv stuck in standby mode suspect power supply capacitors but all seem ok
Hi
Press and hold the menu button on the t.v (not on the remote) for about a min, this should reset the processor to unlock it.
Aug 17, 2015 | Bush Televison & Video
The screen shows no signel even though it is plugged in how do I tune it in bush tv/dvd combi ly2211wcw
By pressing the menu button on your remote all options should appear on the screen
Jun 22, 2014 | Televison & Video
Fisher CA-885 Integrated Stereo Amplifier stuck in stand-by mode
Given the heat/cold cycles of the storage area along with humidity, I would first suspect poor solder connections. This is not unusual for units of this age. A general overhaul should restore this to operation. This should be a labor only repair unless the output STK is bad. These units are known for having poor connections at the voltage regulators which cause a DC voltage offset triggering the protection circuit. The overhaul should address this as well.
Keep us posted on your progress.
Dan
Jul 06, 2010 | Audio Players & Recorders
Where can i find a user guide/manual for the bush ly2211wcw TV/DVD combi
http://linkcentre.com/electronics/Televisions/Bush-Televisions/2.php
Aug 15, 2009 | Televison & Video
CANNOT RETUNE THIS TV BUSH TV DVD COMBO LY2211WCW
Press menu button then press 7935, if like me you bought a display model it will be set to hotel mode, this hides all the menus, once accessed switch hotel mode off, job done x
Jun 11, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
107 people viewed this question
Top Televison & Video Experts
Electro Med Services...
