Question about Dryers
No heat when drying
All vents are clean
hotpoint aquarius ctd40p
reverse action condenser dryer
serial no; 707020236
when dryer is on no heat is being generated hence no clothes are being dryed
  • 3,463 Answers
You need to check the heater element and thermostats which are lolcated behhind a removeable panel at the rear of the dryer..
You will need a meter to do this. Remove one wire from each thermostat and with the meter on the ohms range, test for continuity,if the stats are o/k you will get full scale deflection on the meter., if no movement then stat faulty, you must replace both stats at the same time.
take note which stat goes where as it is important you get them the right way round.
If stats o/k then the heater element is probably faulty.Plz rate my solution.
Thanks.
PS, make sure all filters and vents are clean
Particularly the filter at the bottom left, remove it and wash it out under running water.
Posted on Jan 02, 2009
Hotpoint not drying clothes
Check the vent hose and the vent in the house for dryer lint. Excessive amounts will block airflow and the dryer senses that and shuts off the heat to prevent a fire.
Oct 14, 2014 | Hotpoint Aquarius WF000 Front Load Washer
Hi my condenser hotpoint Aquarius dryer TCL770 keeps beeping when drying ?? All filters clean ?? Do I need to look at the back by pump maybe .? Thanks
I also have the same dryer with a constant beeping while trying! Did as suggestion 4 and then took the back off, cleaned the heater matrix and thermostats, checked the rear draining pipes...so far so good!
Sep 15, 2014 | Hotpoint Dryers
Hotpoint Aquarius CDT00 reverse action tumble dryer. Spins but no heat. Empted water and cleaned filter.
I have exactly the same problem, I am searching desperately for a solution. I really dont wont to buy a new one!
Jan 05, 2011 | Hotpoint Dryers
I have a hotpoint aquarius condenser tumble dryer
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint CTD40P tumble dryer only runs cold.
hello check the heat sensors first good luck
shaun
Aug 04, 2009 | Dryers
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius TDL30 tumble dryer timer not advancing
fmw76:
This could be a timer issue or a thermostat.
If you are using a timed dry it would be timer .
If you are using an auto dry cycle it would possibly be a thermostat.
woodychoppers
Nov 01, 2008 | Dryers
Drier Motor
Disconnect the vent at the back of the dryer and dry a load unvented to make sure you don't have a clog in the vent line too the outside causing an air flow restriction, if still not drying check and make sure the blower wheel that circulates the heat inside the dryer isn't broken.
Jul 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
149 people viewed this question
Top Dryers Experts
