Question about Dometic Refrigerators
DM2652LBX, ICE FORMING IN FREZZER - Dometic Refrigerators
    Top Expert:
  • Dometic Master
  • 5,062 Answers
Check door seals
Posted on May 30, 2016
2 Suggested Answers
  • 125 Answers
SOURCE: in the frezzer ice is forming under the floor and
first remove the floor and back wall of the freezer. remove the ice from the floor and drain pan careful not to damage the evaporator and drain pan. to the right of cener on the bottom of the drain pan is the drain hole. use a turkey baster and hot water to thaw the drain, you should hear water dripping into the drain pan when thawed. install a heat probe whirlpool part number 819043. or wrap a thick piece ( about the size of a pencil lead) of copper wire around the heater located under the evaporator. make it long enough to go about 2 inches into the drain. don't let the wire touch the sides of the drain hole or touch the bottom of the tube, this will prevent the drain from freezing. i recommend using the heat probe from whirlpool but the wire will work too. hope this helps.
Posted on May 05, 2009
Have PSS25MGMBB The freezer not staying cold and forms frost on the inside of the freezer compartment wont even keep ice frozen
sounds like the defrost heater might be going out, you can order a new one at marcone.com with your model number, very easy to do. You will want to have the unit unplugged for a day or so before you do it, all frost should be gone before you start
Jun 10, 2012 | GE PSS25MGN Side by Side Refrigerator
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leaking inside freezer and forming ice in the bottom then leaks water out freezer door
you need to clean out defrost drain hole maybe have to remove back cover of frezzer i use a turkybaster with hot tap water to force hole opan
Feb 13, 2010 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
My fridge stop freezing when i turn it off and and on it comes on but it dontfreeze
nead to know more,is there ice or frost forming on the back wall of the frezzer,nead to know the mod# of the unit.
Dec 22, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
The ice melts from the ice maker forming icicles down below.
Just had this same issue repaired yesterday, the defrost element was out allowing the freezer to freeze up stopping the fan which moves the air and in turn causing the upper part of the frezzer to become warm and melt the ice. This is a common problem for the GE profile and I recommend finding a service company cheaper than GE and quit letting GE make more money off their CRAPPY appliances.
Oct 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice froming at the bottom of the refrigirator
Check that the drain is clear. If it is blocked water will back up and spill on the floor and can potentially freeze. Otherwise you may need service to install a drain heater.
Jun 13, 2009 | Sub-Zero 650 / O Bottom Freezer...
FREZZERS WORKING BUT FRIDGE ISNT
if the frezzer is full of ice you have an automatic defrost problem if not you have a frezzer fan problem
Apr 17, 2009 | Refrigerators
Bosch Frost Free Frdge Freezer Icing Up
Switch off fridge. Put a pedistal fan in front blowing into the cabinet and leave until all ice has defrosted. Locate the drain hole in the back of the freezer compartment, try to defrost ice which blockes up about the first inch or two of this pipe. If water does not run through you need to force it through with a turkey baster. This should sort your problem. ratemeplease
Mar 12, 2009 | Freezers
Keeps clicking on and off
Hello.
It sounds like your condenser fan might not be working, and causing your compressor to over heat. When you turn it down, the thermostat isn't demanding as much run time so the compressor isn't on as much, thus not overheating. Take off the back panel near the floor and see if it is turning or not. Also make sure the condenser coils underneath the frig are clean. If not them vacuum them out.
When it comes to the ice issue, you will need to be more specific. Where is the ice forming? And is it ice or frost?
Dec 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
61 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
