Question about Sharp AR-5320 Black and White Copier
Copy Sharp AR-X180S DRIVER - Sharp AR-5320 Black and White Copier
  • 208 Answers
SOURCE: Driver for sharp ar 5316 driver for my RHEL 5 machine
You can also go to Xerox.com and select support and downloads.
Type in WCP215 it is the same driver.
Posted on Dec 20, 2007
sir fixalot
  • 146 Answers
SOURCE: Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Posted on Jan 06, 2008
SOURCE: driver sharp ar-5220
drivin paulo
Posted on Oct 10, 2008
Benimur
  • 6966 Answers
SOURCE: Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 17, 2008
  • 37 Answers
SOURCE: AR-5127 Counter Reset
Try these steps
1.Press continously #key then Interrupt key then CA key then # key
2.If the display turns off it means that you are inside the simulation but if not do again step 1.
3.Press 81 then press enter then press 1 then enter
Hope that this will help to reset .
Posted on Mar 03, 2009
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
Feb 25, 2015 | Sharp Ar-208d Duplex Copier, Printer,...
Sharp copier USB connection not recognized
WHAT OS U USE?
TRY THIS LINKS......
http://www.solvusoft.com/en/update/drivers/copier/sharp/ar-m355n/sub-models/
http://iprinterdrivers.info/download-driver-for-sharp-ar-m355n-printer.html
http://www.sharp-world.com/products/copier/downloads/index.html
AND ALWAYS U CAN GO FROM -CONTROL PANEL- TO -DEVISE MANAGER- AND FROM THERE U SEE THE PRINTER DOUBLE CLIK ON IT AND U SEE INFO OF DEVISE(PRINTER) LIKE DEV ID (DEVISE ID) COPY THE ID AND GO THERE
https://devid.info/ AND JUST PASTE AND FOUND THE DRIVERS
Oct 13, 2017 | Sharp Ar-m355n Copier Printer Scanner Fax...
I need Windows7 driver for my SHARP AR-5316
Unfortunately, Sharp does not list a specific driver for Windows 7. In most cases however, the Vista and Windows 7 drivers are interchangeable. Determine if you need the 32-bit or 64-bit driver and proceed to your product's driver download page below.
AR-5316 Windows Drivers
Apr 29, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 device driver for windows 7
5316 copier doesnt work with win7.you should use win xp
Aug 01, 2010 | Sharp AR-5320 Black and White Copier
I am using Sharp AR-5316E copier (It makes noise)
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Jan 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
On sharp AR-163 I have white lines(text mising)from top to bottom ? It happens even when you print only
if you make a copy and the copy is ok but the print copy is bad . this sounds like you might have the wrong printer driver set up.
all sharp al-ar small copiers u must have the exact driver for coper model you can get them at sharpusa.com under personal copiers
Mar 11, 2009 | Sharp AR 163 Copier
How do I instal my printer to my P.c.
YOU CAN DOWNLOAD THE DRIVER FOR YOUR SHARP COPIER ON ANY SHARP SITE.
Jan 27, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 Black and White Copier Logo
307 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
