Question about LG DR787T DVD Recorder
Connecting LG DVD recorder to cable box and HGTV digitally
I have an LG Dr787T and I am trying to connect it to a cable box and through an hdmi port to the TV all I can do is connect it analogically but that means disconnecting the hdmi cable connection resulting in terrible picture.
if I connect it digitally I get this error message: :your TV does not allow display of this program through the DVI input source please choose another input source.
I also have a Panasonic pt760 hometheatre/dvd connected
TV is toshiba Regza
please help .. I need everything to be connected
    Sergeant:
  • 226 Answers
Two things come to mind: copy protection and resolution settings.
The TV may not allow copy protected material to come from your LG, or the sampling frequency may be unacceptable. On page 15 of the manual it talks about 96kHz and 48kHz frequency settings. The third thing to check is the vertical resolution using the RES button on the front panel. SDTV is 480, and HDTV is anything above that. Using the HDMI is supposed to allow upconvert to 1080i max if your set can use that resolution.
tom
Posted on Jan 10, 2009
Can a sharp Aquos bd player be hooked up to a cable box using the HDMI cable
Can I ask why?
If it's only a BD player only, there is no reason for connecting it to your cable box - with HDMI or any other type of cable. It simply needs to be connected directly to your TV for playback.
If it's a Blu-ray (or DVD) recorder, it can only be connected to the cable box with HDMI if the cable box has a spare HDMI OUT port and the BD recorder has an HDMI IN port.
If you want to connect the BD player to the cable box for playback on your TV via the cable box, then the cable box would need an HDMI IN port, which it's unlikely to have.
Hope this helps. If you need further assistance, please provide model numbers of your equipment and explain why you need to connect the BD player to your cable box.
Regards, BElectric
Jul 03, 2011 | Televison & Video
G'day, I have an LG HDD/DVD recorder (model RH298H) connected to an LG plasma screen digital TV via an HDMI cable. On the TV I have crystal clear digital television (and able to tune all the digital TV...
You have probably found out now that you would need to get your digital reception by connecting a set top box to the LG, say to AV1, then select AV1 when making a recording.
Apr 17, 2011 | LG RH1999H DVD Recorder/HDD Recorder
I have a samsung dvd recorder, whats the proper way to connect for it to work, do i connect to cable box, tv
How you connect it depends on your system. You need to connect the video out of the recorder to the TV. If you want to record programs, you need to connect the cable box to the recorder's video in. (The unit doesn't have a tuner if you have the unit listed above.)
Place the IR Blaster near the set-top box IR receiver. Connect the RF cable from the wall to your set-top box and then another RF cable from the set-top box to the TV (not to the DVD recorder). Connect a composite A/V cable from the set-top box A/V (composite) out to the DVD recorder's A/V in (AV1) port. (Composite video is a three wire cable - the plugs are yellow (video) and red/white (R/L audio).)
Next you need to connect the unit to the TV. Depending on the TV, you can use an HDMI cable (best results), component video or another composite video cable (labeled AV2 AV out). If you use component video, you'll need a separate cable to carry the audio. (Component video cables have 3 RCA jacks on each end (red, blue and green). The audio cable has the red and white plugs.
You will only get a 480 (SD) signal output if you use anything other than the HDMI cable. (The progressive scan feature is not compatible with all TVs; see the manual for details.)
You can obtain the manual from http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=DVD-VR375 .
I hope this helps.
(you have an additional A/V IN connection as well as a DV In port on the front of the unit)
Sep 12, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Lg dr787t DVD recorder does not play dvd
need replaced dvd unit
Manufacturer LGE Part Number EAZ40302021 Description DECK ASSEMBLY,DVD
May 30, 2010 | LG DR787T DVD Recorder
Will not play movie - continually displays "Copyrighted Movie HDMI HDCP frail with TV "
There are several reasons for this but exactly knowing which is one isn't possible without first knowing what products you are using such as your connector, player and television.
HDCP is the acronym for high definition content protection. It is a digital signature embedded into the disc software designed to prevent copying of the disc. On certain occasions due to the hardware such as the HDMI port on the television, or the connection type, the signal will not be allowed to pass through. The HDMI port on the television may not be HDCP compliant for example. In this case if possible you can try a different HDMI input on the TV if available or use the component video input instead.
Jan 09, 2010 | LG DR787T DVD Recorder
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Connection several HGTV cables
hgtv is for Home and Garden TV...
Do you mean HDMI? The end connector looks similar to a USB cable. It is a little wider and close to USB in height.
If you mean HDMI, then you can get a mechanical switch box from MCMELECTRONICS.COM but if you mean hgtv, I don't have a clue.
There is also the DVI connector, not used to much any more, that is used for HD tv signals. It is larger and more rectangular, and you can see all the pins and receptacles.
tom
May 09, 2009 | LG DR787T DVD Recorder
How to eliminate error screen:"your tv does not allow display of this program through the dvi input source. please chose another tv input source."
"cable box to tv is hdmi cable"
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
May 06, 2009 | Televison & Video
A/V Signal Outout through Onkyo TX-SR705
Are you trying to record cable programming with your DVD recorder? If so, you might want to try using component cable as HDMI does have a copy protection circuit that might be preventing your recorder from receiving the image. Just try to connect the cable box component (RED/GREEN/BLUE) cable to your DVD recorder. If that doesn't work, then try to change everything over to component cables. HDMI is a great cable to use but it the only required to display 1080p images and the only current source that uses 1080p is a bluray player. Everything else, such as your cable box and DVD recorder is 1080i and component cables are perfect for it.
Mar 14, 2009 | Toshiba RD-XS32 DVD Recorder
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
LG DR787T DVD Recorder Logo
537 people viewed this question
Computer Repairing
Computer Repairing
