Question about Sharp (BQC-XGE1000U1) Projector Lamp for XG-E1000U, XV-S95
Replacing a blown bulb.
I tried to replace the buld in my Sharp Projector with a siiliar model. The bulb did not work bt the fan did not either. Is the proper bulb associated with the fan runnung?
  • rvalivingood Jan 06, 2009
    Please email me the reset instructions for the lamp replacement. I have a BQC=XVH37U//1 lamp on hand. Will it work in this projector?
  • rvalivingood Jan 07, 2009
    Still waiting on instructions to reset the hour counter on my projector.
  • Sharp Master
  • 19,396 Answers
The model you posted is wrong, find the right model here and download the reset operation.
Posted on Jan 09, 2009
  • 827 Answers
RESETTING THE LAMP HOUR COUNTER
1. Turn the Master Power off using the red button located near the AC input
jack.
2. Hold down the “ENTER”, “ADJ!” and “ADJ"” buttons simultaneously on
the projector. While keeping them depressed, turn on the Master Power
with the switch near the AC input jack. (See diagram below)
3. The unit should power up when you do this and the lamp should light.
Look for “000H” to be displayed on the screen, which will confirm you have
reset the counter to zero.
Note: It is possible that you may have to perform these steps 4 or 5 times
before it works correctly. Also, on some models, you may have to continue to
hold the buttons and press the Power button on the front of the unit after
turning on the Master Power.
Hope this helps
Chris (ziraffa)
Posted on Jan 07, 2009
  • 1 more comment
  • chris grams
    chris grams Jan 07, 2009
    SO, it's Enter, ADJ down and Adj right:
  • chris grams
    Buy the correct bulb and install it and go through these steps, it will work :)
    Chris (ziraffa)
  • chris grams
    For your information, the unit is designed prevent the lamp from lighting when the lamp counter has been used for 1900 to 2000 hours. This is to protect the lamp module. When this occurs, you just replace the lamp module with a new one and use the above procedure to reset the counter.
    Novelist:
    Scholar:
  • 67 Answers
Just to shoot another perspective here...
Did you happen to replace the lamp door whe you changed the lamp? It won't allow the lamp to start if the door is not replaced or replaced incorrectly.
Hope this helps you...
    Sergeant:
    Champion:
  • 435 Answers
Hi, please check if any fuse has gone bad. May be thats no part is working in it.
    Sergeant:
  • 367 Answers
Here is a video on changing the lamp. VIDEO The replacement lamp can be ordered at the following: LAMP REPLACEMENT . Let me know if you still need help.
Sharp Lamp Specifications Spec Data ProductCode BQCXGE1000U1 Type Genuine Original Lamp & Housing Warranty 90 Days
Posted on Jan 06, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, check;
  • compatibility of the new lamp with the old, the electrical specs;
  • check the fan for dirt/dust accumulation, clean if necessary;
  • some models would not activate the fan if the lamp is incorrect, defective or not sensed to be connected;
  • some models would only activate the lamp when the lamp is operational;
  • a lamp timer/counter is incorporated into the projector. A reset has to be done based on prescribe key combination. Pls reference your owners manual or Sharp Service Bulletin.
Good luck and Thank you for using FixYa.
Incidentally, one other responder, Dipu007 has copied some tech tips from United Visual addressing lamp timer/counter reset.
Posted on Jan 03, 2009
  • 1,183 Answers
HI,
It is generally recomended to put the bulb in the projector that is company certified .Take the old bulb out and put the old bulb back in check , if there is movement of the fans .
For authorised parts and serice you can contact sharp
1-800-237-4277, 1-800-BE SHARP
Thanks
proton
  • Sharp Master
  • 13,433 Answers
Its recommended that you replace a bulb with the same original product as 3rd party bulbs may generate too much heat or other disfunctions.
IF the fan runs fine on the old bulb and it stops runing when you swap in the new bulb, the problem must be your new bulb.
  • 3,037 Answers
The fan won't run without the bulb in the device and the fan won't run unless it is at a certain temperature either
bestdarngood
  • Benjamin Patri
    Benjamin Patri Jan 10, 2009
    simple enough to reset the counter
    first remove the case( five screws in the back and slide top completly off carefully so u dont tear the sound cable connected at the front unplug it and set aside..... now all u do is hit the small button on the top of the motherboard with the unit plugged in. DO NOT HIT the switches just the small button!(doing so will shut down the fans and your bulb will have to cool manually which is VERY BAD FOR THE LIFE OF THE LAMP) a prompt will come up. Now go to sss choose system then lamp then hit enter where it says lamp. counter will reset.
    Sergeant:
    Novelist:
  • 326 Answers
The bulb has to be replaced with the same model number and not with the similar ones.such things wont solve the problem.use the exact bulb and it will solve the problem.
    President:
  • 2,110 Answers
Most Sharp projectors require you to perform a reset procedure once you have installed a new lamp. This resets the lamp hour counter so it properly keeps track of the lamp hours for the new lamp. To insure the lamp hour counter will be correct, Sharp built-in a function to disable the lamp until this counter has been reset. The reset procedure can be found in the owner's manual on most models. If you have misplaced the manual or the reset procedure is not in it, contact us and we will e-mail you the procedure. Note: If you have performed the procedure and it doesn't seem to have worked, don't give up yet. On some models, the reset procedure sometimes needs to be preformed several times before it works. No one seems to know why, so just be persistent.
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
HELP!>After replacing a new bulb, I turn it on and 3 seconds later it said Fan Locked and turns off. Any ideas? Thanks
Hi sir
firstly try to clear the induction of color wheel,
if it still happen same hint, perhaps the fan was failure.
hope i can help you.
regards,
Jack
wanminjun@gmail.com
professional whole saler and retailer for below products:
most of brand projector spare parts: lens, color wheel, bulb, mother board, etc. match for Benq,sharp, optoma, samung,dell, etc.
HP server, router, switch,
computer motehr board, hard disk. DELL, IBM, ASCUS, Hp etc
Nov 10, 2011 | Optoma HD65 DLP Projector
Replaced bulb in Sharp XG-E1200U, the red power light comes on, when I turn the switch on nothing happens.
When the XG-E1200U shows the standby light but does not power on, it usually means several of the 100uf 16 Volt surface mount capacitors have dried up on the main board. Recommend replacing all of these for continued reliability.
Sep 03, 2010 | Sharp (BQCXGE1200U1) Projector Lamp for...
Replaced the projector lamp 3 weeks ago. Reset
If the lamp is working it should be fairly obvious but stand to one side of the lens and see whether there is any light coming from the projector. If there is you know that it's an input problem. If there isn't either a fuse has gone, the bulb has blown or the filters might need cleaning. If the bulb has blown it's probably because you handled the bulb. It's vital not to touch these bulbs with your fingers. If you do wipe it with methylated spirits.
Aug 21, 2009 | Sharp Office Equipment & Supplies
Projector shut down after replacing the bulb and wont turn on now
are any of the leds on the top of the projector lit? if so, which ones? red or green?
Apr 09, 2009 | Sharp Notevision PG-B10S Multimedia...
Lamp won't turn on.
I have a sharp xr10x ..........the problem lies in the bulb it needs a warmer temprature for the gas to expand in the bulb to fire and light up... hold a hair dryer up to the side of it fo a while and then fire it up still holding the haidryer up to it till it starts it may take a couple tries... ( this is a fix if your having a no buld startup problem and you know your bulb is still good) THIS IS THE FIX IF**** the lights will blink green for a while then one red and one green then will (shut off at both red) and not restart***
i had the same problem and thought id have to get a new bulb but this is the fix....
Nov 23, 2008 | Sharp (AN-XR10LP) Projector Lamp for XR10X
250V T6.3AH Slow Blo Fuse
Depending upon the way in which the lamp finally smoked, it is not unusual for the feeder fuse to blow. Replace the fuse and try the projector. As long as you haev a new lamp, it should work OK.
Dan
Sep 11, 2008 | NEC VT670 Multimedia Projector
Projector- Sharp XR-20X won't start up
I have a xr10x same setup allaround the problem lies in the bulb it needs a warmer temprature for the gas to expand in the bulb to fire and light up... hold a hair dryer up to the side of it fo a while and then fire it up still holding the haidryer up to it till it starts it may take a couple tries... ( this is a fix if your having a no buld startup problem and you know your bulb is still good) THIS IS THE FIX IF**** the lights will blink green for a while then one red and one green then will s(hut off at both red) and not restart***
i had the same problem and thought id have to get a new buld but this is the fix....
Dec 15, 2007 | Office Equipment & Supplies
Its not the lc-sb20 but the lc-nb3e
Hi there
This sounds like a common Ballast ( lamp's power supply ) problem.
Only way to rectify this is by replacing the faulty Ballast.
Sep 08, 2007 | Eiki LC-SB20 Projector Multimedia...
63 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
