Question about KitchenAid Microwave Ovens
Kitchen Aid Microwave/Oven Model KEMC377KB L01 microwave wont heat
Have replaced the magnetron and capacitor 2 times and has gone out again.....
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave problems after HV capacitor replacement???
The rectifier diode could indeed be bad. But first I would want to know what value (in uF) the old one was and what is the value of the new one? If they're too far off, the difference in the capacitive reactance could throw off the "tuning" of the circuit. The uF value of the capacitor is optimized in relation to the other components used in the system. Of course, you'd also want to be sure your new cap is at or slightly above the working voltage rating of the old one, too.
Posted on Jan 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile JE1660GB01 magnetron failure?
It pass the resistance tests and still be bad, and I suspect it is.
I would also suggest that you check the high voltage diode to be sure it's not shorted.
If the filament voltage and high voltage are both present at the magnetron terminals, and not loaded down, but there is no heat, then it's the magnetron.
As a pro with over 20 years of expereince, I have always measured the high votlage, but I will never recommend it to a non-professional. Without the right equipment and procedure, you and your equipment can be "fried". No kidding.
Here are some good links to safety & troubleshooting:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Microwave oven magnetron blown or faulty
You can e-mail the spare parts manager with your model number here: JHB023@seartec.co.za
Posted on Aug 10, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool microwave/oven combo- model #RM288PXS
That would be a problem with your control board. It probably needs a few capacitors and a relay replaced and minor circuit board repair.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
P.S. (to Guest: Please make a new post with your model number. I think your problem is different.)
Posted on Nov 08, 2008
SOURCE: GE microwave replacement magnetron
I also have a HotPoint (GE) Spacesaver Microwave Oven (MWO)that we got at Home Depot about 3 yrs ago. The magnetron quit yesterday and I found out online that this is a common occurance with GE MWO's. I found this string and thought I would attempt to have GE send me a magnetron to replace the defective original part.
I called Customer Relations (1 800-386-1215) and spoke with Nikita. I informed her nicely that I was aware that this is a common problem with GE MWO's and that I am a Union Electrician who would like to perform this repair myself. I simply needed the replacement part. She was very understanding and asked for the model and serial number and after a few minutes she supplied me with an order confirm #.
The part should arrive in a few days via FedEx and we will be back into space age cooking and also our appliances will still match. Thanks to all who posted to this string and clued me in (You have saved me a C note!).
David in Omaha
Posted on Jan 14, 2009
I have kitchen aid microwave modelkcms185jss starts runs fine but does not heat food at all.
Does not heat food means a problem on magnetron tube and fuse blown in high voltage area. Have it replaced and it will heat again.
I hope I answer your problem.
Mar 30, 2011 | KitchenAid KCMS185J Microwave Oven
My GE microwave model #JVM1640WB microwave stopped heating and is making a humming noise. Everything else about it is fine. Light, keypad, turntable, all work normally. Just no heat. How do I...
Hello, installing is quite straight forward if you know what youre doing. BUT, be very careful of the voltage in the capacitor even when its off,it is lethal! When you change the magnetron it is advisable that you also change the diodes. Again make sure that the capacitor is fully discharged, by switching the microwave off, unplugging it, and discharging the capacitor with an insulated screwdriver, it will be noisy. Next unsolder the old diodes and fit the new ones(check their polarity). Replace the magnetron and when all looks good,switch it on. If it works, good, if not there could be a power supply problem. 9 times out of 10 its the magnetron. Good luck.
Mar 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave has quit heating. everything else is working.
The problem is most likely caused by the magnetron, and there are two other parts that can be a factor, the high voltage capacitor and diode. The above mentioned work together to heat food, if the magnetron is gone you would be further ahead buying a new microwave oven
Mar 10, 2011 | Samsung MW1150WA Microwave Oven
Makes a humming noise wont heat
If its making a humming noise, that means the diode is bad and should be replaced. Once replaced the microwave will begin to heat again.
Feb 11, 2011 | Kenmore 62622 Microwave Oven
I have a kenmore sensor microwave model 565.60582990 it turns on but wont heat. what can i do to fix it?
The most common cause is the magnetron that heats the food, there are two other parts that can be a factor, the high voltage capacitor and diode. The magnetron is the most expensive, and if fixed professionally probably cheaper to replace the microwave oven.
Feb 07, 2011 | Microwave Ovens
The power is on to my Kitchen Aid microwave convection oven, but the microwave will not heat up? Any ideas as to how I can fix this?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 03, 2011 | KitchenAid KBMS1454RSS Microwave Oven
Microwave won't heat, light ,clock works the microwave just won't heat the items in it.
hELLO THERE
when a microwave quits heating but every thing else is ok normally
investigate these 4 areas
Investigate these three areas if your microwave won't heat but you hear a loud buzzing or humming noise:
microwave_diode.jpg Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
picturena.gif High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
microwave_magnetron.jpg Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Nov 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave makes a loud sound and then won't heat. About 3 years old.
It sounds like a failing magnetron. Sometimes they can be intermittent before they finally fail for good.
Chances are your oven has a 5-10 year warranty on the magnetron.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and your detailed symptoms.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Dec 12, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Whirlpool mircowave will not heat
HI, the high voltage capacitor is unstable and, it has damaged the Magnetron. you will need to replace the Magnetron. it will run you about $191.30. this will restore the heating action in your microwave unit.
May 27, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
Mvh1615
It doesnt matter how old a system was. components can be failed at any point in time. unplug the unit. carefully disassembly and visually check the diode near magnetron and capacitor, it might be broken.If seems good, check the thermostat continuity,if beeping. changage your magnetron. be careful capacitor store charges that deadly. discharge the capacitor first.
when you change mag. change the diode too.
Jul 24, 2008 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
