How to retune a sanyo ce32ld17-b television
Lost stations after digital switchover and can not retune to new channels
  • 11 Answers
SOURCE: Digital tuning
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
Posted on Nov 04, 2007
Obertelli
  • 3006 Answers
SOURCE: since digital switchover yesturday loss of digital channels
It may well be your aerial despite the success with your DVD recorder.
Digital signals are very much weaker than analogue ones, and when multiple devices share a single aerial you can get this kind of problem. You also lose about 60% of the signal at each point in your aerial cable where there are signal splitters.
There are a number of possible solutions:-
First, look at every bit of coaxial cable you have between the aerial and each appliance. Check especially at the aerial end for corrosion or poor shielding/installation and especially for evidence of rain water penetration. If the aerial is on the roof then it will cost almost as much to get the aerial inspected as it will to have it replaced, so skip to the next option. But otherwise, check along every bit of the cable for any cuts or splits in the insulation and properly remake every junction or joint if there are any doubts about them. If the cable is in poor condition then consider option three instead.
The second is to try to see if you get a better digital signal from another transmitter, this will involve trying different aerial positions so is impractical if your aerial is roof mounted but is worth trying if it's in the loft instead. It doesn't always follow that your best digital signal will be from the transmitter which you used for analogue transmissions.
Thirdly, if you're still using the same aerial as you have done for years then it's worth upgrading to one optimised for digital reception. When doing this it's foolish not to replace the cabling as well as you need it to be as good as possible. With analogue, many installers got away with using cheaper cable intended only for very short cable runs from the wall socket to the tv.
The fourth option is the budget option but can work as well as the third option: fit an additional analogue style aerials and run a separate cable down to each appliance. If these are fitted in the loft and you have the space, then there's no aesthetic or planning concerns. Normally the extra cables can run partway down through the house alongside existing cables, but for best signal quality keep them separate and ensure that the cable runs as as short as possible.
One further thing which you may want to try before all else: connect your digital box directly to the aerial cable which currently feeds your dvd recorder. Leave all other tv devices disconnected from the aerial. If the box retunes correctly then it's definitely a supply of signal issue as outlined above and if not then you should add the exact make and model of your digibox as a comment to this answer as there are a large number of earlier digibox models which cannot retune correctly due to evolving standards.
Posted on Jul 02, 2009
  • 20 Answers
SOURCE: Cannot get tv to scan digital stations. I have a
test test 18:30
test test test 18:31s rthsr thsty 3456234
Posted on Jul 07, 2009
SOURCE: Lost BBC channels on retune for digital Switchover - why?
I had the same problem,
you have to revert your freeview box to it origional factory settings, then rescan for channels.
hope this works.
Posted on Sep 28, 2009
SOURCE: Retuning digital TV
You need to use the (what looks like a large sattellite) button to retune your tv.
Some Samsung tv's let you access the button but other models have a "D MENU" button on the remote. Press this button, then scroll down to the icon that looks like a large sattellite. Then scroll across and click on "Auto Store" this will then go through all the available channels
Posted on Sep 30, 2009
JVC LT22HD32J DIGITAL TV WONT HOLD CHANNELS AFTER RETUNE
It's October 2012 and I have a problem with my exact same model of JVC TV which has worked fine since i bought it in January. In fact it has worked the best out of the four that we have in the house working off the same aerial until 4 days ago. I tried retuneing and then the problem expanded to more channels. I tried to reset to factory options and then do a retune but lost all the channels. I have again reset and retuned and I'm back with channels that I can only tune into for between 4 and 15 seconds before the screen goes blank. None of the other televisions are affected. Digital UK website show no works to transmitters in our area and JVC are impossible to contact. Their site sends one around in circles in a most frustrating and unhelpful way. I will not be buying JVC again. Any help offered would be gratefully accepted!
Apr 14, 2012 | Televison & Video
Need to retune channels on digital tv after switchover
try to perform an autotuning function instead of tuning manually.in autosearch mode it saves the selected channels so even after switching off when you swtch on you do not need to retune again
Sep 21, 2011 | Samsung Televison & Video
Im trying to retune after the digital switchover but have lost lots of channels. i cant seem to find anywhere on the internet to get help!!!!
You should have lost ALL of the channels. but for some reason in Va Beach, Hampton Roads,
there is 1 station. its a religous channel. That TV is obsolete now.
Sorry...
Aug 29, 2011 | Bush DVD142RC 14 in. TV/DVD Combo
HOW DO I RETUNE AFTER DIGITAL SWITCHOVER
Free PDF Instruction Manual at the link below shows how retune on Page 28.
You can do this at any time but after Digital Switchover you'll lose all Analogue Channels.
http://service.us.panasonic.com/OPERMANPDF/TH37PX60U.pdf
Jun 24, 2011 | Panasonic TH-37PX60U 37 in. Plasma HDTV
I have a Daewoo DSL22V1WCD combined tv/dvd with built in freeview, our area is in the grasp of the digital switchover - everything I look at says I need to retune the tv - but this tv has various "sources"...
Press the DTV menu button (<<)
Press the Down arrow until you reach Settings
Press OK
Press the Down arrow until you reach Installation
Press OK
Press the Down arrow until you reach First Time Installation
Press OK
Aug 04, 2010 | Daewoo Televison & Video
Digital switchover
I also have the Sony IDTV KD-28DX4OU Digital TV.After the digital switchover I lost BBC1 and BBC2 despite retuning three times.
I contacted Digital switchover people (useless) and they passed the buck to Sony.I contacted Sony and they said they cannot fix the problem and that I should get a digital set top box. So the £650 I spent on integrated Digital TV has been wasted.If like me your cheesed off with this then I suggest you complain here
Sony United Kingdom Limited
Customer Information Centre (CSG)
Jays Close
Basingstoke
RG22 4SB
I have
Sep 30, 2009 | Sony FD Trinitron KV-28FQ75 28" TV
No BBC 1 or 2 after digital switchover.
I have the same box and re-tuned mine with the same results as you.However i discovered that the NEW BBC channels were on the channel guide list starting at channel 800
May 07, 2009 | Televison & Video
Retuning digital TV
Mar 26, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
I have no owners manula and need to retune the channels.
You can obtain a Sanyo version by visiting http://www.sanyo-service.com/
The link is currently very slow but I have used it successfully on many occasions.
Nov 16, 2008 | Sanyo DS27820 27" TV
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
