Question about IBM (01K7207) SCSI Controller
IBM e346 8840 Server BIOS Erased
We had a IBM e346 8840 Server and 2 RAMS were malfunctioning. When the RAM is removed its giving a message SCSI Controller not found. We tried to upgrade the Flash BIOS but it also cannot find the controller. Please help
SOURCE: IBM IntelliStation Z Pro 6221
Mayeb you need to repair the OS - In which case you will need to have SCSI Controller XP OS floppy driver obtained from IBM website.
Start up the computer booting up from the CD ROM. Then when it comes to "install thrid party devices" - press 'S' and insert the floppy with the SCSI Coontroller on it and follow the on screen instructions.
Posted on Jul 06, 2008
SOURCE: Planar PCI device does not respond or disbale by user
this is not an error message, see: http://www-304.ibm.com/systems/support/supportsite.wss/docdisplay?brandind=5000008&lndocid=MIGR-41551
Posted on Aug 18, 2008
pavlicmaster
  • 171 Answers
SOURCE: We are using IBM X226 server with 4 GB RAM &
strange. with 4gb of ram, it should be fast. try to install better version of windows like win 7. it could help you. just don't install vwindows vista cause is slow as hell. let me know if it worked
Posted on Jun 28, 2010
  • 10406 Answers
SOURCE: I have IBM eServer with
First, buy an external storage device, at least 80GB (although it's currently difficult to find any _smaller_ size!) and make a file-by-file, folder-by-folder, backup of your 73GB of "data".
Second, buy another external storage device, and do a Google-search for "drive image freeware".
Pick one of those applications, and do a "image" backup to this second external storage device.
Third, disconnect the 3 "old" drives, carefully label them, and set them aside.
Fourth, connect the 3 "new" drives, delete the old RAID-5 array definition,
and create a new RAID-5 array definition.
Fifth, do an "image restore" from the second external storage device to the new array.
If you have any problems, all you need to do to "back-out" is to:
* disconnect the "new" drives
* reconnect the "old" drives
* delete the "new" array definition
* redefine the "old" array definition
and you're back to the "old" configuration.
Posted on Dec 07, 2010
  • 143 Answers
SOURCE: I have IBM Server x3400
Welcome to Fixya
The problem is with the raid controller . Either the controller is faulty or it is due to dust or happen some shake. To rectify this issue do the following
1: Switch off the server 2: Remove the Raid controller from the server and clean the dust . ( Please Don't touch with hand just blow air ) 3: Clean the Controller slot 4: Refix the Controller and power on the server . 5: Check whether the controller is booting or not . 6: If you gets same problem then replace the controller
Thanks
Posted on Mar 05, 2011
Planar fault IBM 3550 M3
Ok, That' s a motherboard issue. You would have to replace motherboard...
Workaround:
1: Set server in minimum configuration(single processor and two RAMs)
2: Remove any PCI cards added in server
3: Turn on server check for issue
If plannar fault appear, you have to replace motherboard..
Thanks
Feb 14, 2013 | IBM x3550 Server
A boot message "SCSI bios
Disable the SCSI controller in the BIOS.
Aug 30, 2011 | HP Compaq ProLiant ML350 G3 Server
How do I access the BIOS to confiure the disk controller so it sees the drives?
Welcome pqumbril, thanks for using Fix' Ya. These instructions will help you go to "BIOS screen. The first thing you want to do is"Restart the computer; once the computer begins to "Boot Up!" "Do the following, this may take some timing. "You will notice that there will be wording, a prompt, at the bottom of the screen thta read; Press F2, or Press F12, once you see this message! Press the [F2] button, this will give you the "Options" to Configure in BIOS Setup. "Please find the time to give a "Helpful Rating," thanks again, paul7of9."
Dec 09, 2010 | IBM System x3850 M2 Server - 2 x Xeon...
I have 2 512 cards installed and the computer only shows that I have only 512 installed and it should be 1 gig?? What would be the cause of this?
There could be many reasons,
1 Either the RAM slot is not working
2 or the RAM card(s) are not OK
3 or the RAMs are not compatable(not of the same specs)
Solution
1 Remove both the RAM cards, clean the metal joints in both the RAMs and the RAM slots
2 Remove power, remove all power source, remove power cables including all the battery
3 Keep presssing the power switch ON for a few mins, Do....ON... OFF, ON... OFF WITHOUT any POWER
4 Replace battery, power adaptor, power cables etc
5 Insert one of the RAMs in 1st RAM slot, power on, check if it's OK, Switch OFF, remove the RAM
6 Do the above process for the other RAM, now check if that works, use the same RAM slot
7 Now do the above two steps for the 2nd RAM slot
It will give you a rough idea of where is the issue.....either RAMs are not OK or the slots have issues or there is a compatibility issue among the RAM cards.....
Pls reply back and leave a feedback
Regards
Kris
Nov 16, 2010 | IBM ThinkPad T30 Notebook
We are using IBM X226 server with 4 GB RAM & 146 GB SCSI HDD. We are using it for ERP application . It is very slow . When HP proliant ML 110 server with 2 GB & 160 GB SATA is used in its place it...
Jun 28, 2010 | IBM xSeries 226 Server
I added NEW rams to my intel SE7505VB2 Motherboard and when i start the Server i hear beeps in the form of 4-3-1-3 with Blank Screen when i googled the beep codes for Phoenix BIOS i got: Initialize the...
it means you are traing with diffrent RAM module
this is your Sever Moduals
Memory Memory Type DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 8 GB
or go to link u will find all the details of your server
http://www.dealtime.com/xPF-Intel-Server-Board-SE7505VB2
Hope this helps you in your troubles!
If it does, be sure to give me a thumbs up.
Apr 24, 2010 | Intel Server Board SE7505VB2 Motherboard
Highest Priority Problem: HDD moved from old machine works but is physically damaged . Trying to clone/ recover using DataLifeguard and Acronis. Been trying for days and always fails although the damaged...
Are you trying to recover data from the damaged drive, or are you trying to do something else?
You're welcome to ship the drive to me andI will recover the data for you. Info@taeckertindustries.com
Nov 09, 2009 | Office Equipment & Supplies
Boot problem with IBM xseries 206 - SCSI Drive and SATA drive
Refer to user's manual how to set the boot order in BIOS.
Jul 17, 2009 | IBM eServer xSeries 206
Error beep sound on server, conf:Intel server motherboard se7520bd2 2 gb ram scsi harddrive problum:long beep sound in LSI LOGIC CARD
I don't think SCSI card give beep error codes. If you listed this item, most likely this is the problem and your MB is telling u this. Your SCSI card is most likely damaged. Try to make sure it is inserted in the pci slot properly. If it is....buy a new one. We rarely use SCSI cards any longer as most Servers have plenty of HDD space and the Hot Swappable options make them easy to replace if they get damaged.
As a tech, I would first check the Mother Board (BIOS) Beep Error codes to determine exactly what the problem is. Those beeps tell u what hardware is malfunctioning.
Jun 06, 2009 | Intel Xeon, 3.6 GHz (bx80546kg3600ep)...
SCSI Devices not detected when posting ML530 Server.....
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
Jan 30, 2009 | HP Compaq ProLiant ML530 Server
IBM (01K7207) SCSI Controller Logo
239 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
