Question about HP PhotoSmart InkJet Printer
HP Photosmart Printer C310 not printing red color
The magenta and yellow print on the test page just fine but there is not a red square. Shouldn't there be a red and black test squares on the test print page? I have cleaned the printer heads and reset printer to factory defaults. The red color in the images come out a yellow color.
  • 66 Answers
SOURCE: HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Rgds
S88
Posted on Jan 02, 2009
leroyal
  • 2120 Answers
SOURCE: new tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Posted on Jan 22, 2009
sgoswami
  • 114 Answers
SOURCE: HP 6000 Won't print with yellow cartridge
Try this :
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Regards
Soumajit
Posted on Mar 12, 2010
  • 1218 Answers
SOURCE: Photosmart C7180 - light magenta and magenta not
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Posted on Dec 23, 2010
jim4984
  • 797 Answers
SOURCE: Printer has new ink cartridges, no apparent
The print heads are probably clogged :^(
Has the printer been unused for some time? Does the printer show that the cartridges are full?
Does the printer show any errors? It could be that he waste reservoir is full (or thinks it is full) I would suspect that it would report an error though.
If the printer was not used for a while, the ink could be dried on the print heads. Print heads are kind a like paint spray cans. You can try cleaning the print head nozzles with alcohol and or water. The best way to do this is to put a moist (you do not want liquid to drip into the system though) cloth or paper towel under the nozzles. Make sure the printer is unplugged though so any liquid does not fry the electronics. Make sure the printer is completely dry before plugging in again.
Hope this helps, Jim
Posted on Feb 10, 2011
Why does the 2550n printer not printing fully in the left column
Is the print quality poor on left side for all colors? You may have one bad cartridge. Create a paint document with Yellow, Magenta and Cyan squares on the left side and see if one color prints better than the others. You can also gently shake the cartridges to redistribute toner.
Sep 08, 2014 | HP Color LaserJet 2550n printer + HP Color...
My HP Photosmart 3210 Printer does not Print Red.
WELL IT'S 5 DEC 2012, THIS HP 3210 QUIT MAGENTA'S.
WENT TO TOOLS TO CHECK LEVELS, NO YELLOW, GOT NEW CARTRIDGE, TEST SHOWED NO MAGENTA'S. REMOVED RIGHT SIDE COVER (GENTLY) AND REMOVED ALL TEN CABLES AND REINSERTED CAREFULLY. TESTED AGAIN, AND HAD LINES ONLY ON BOTH LIGHT AND DARK MAGENTA'S,
RAN CLEAN HEADS, SIX TIMES AND ALIGN PRINTER ONCE.
PICTURE GOT BETTER AND BETTER FINAL TEST DIAGNOSTIC PAGE PERFECT ALL SOLIDS. GOOD LUCK KEEP GOING
Jun 08, 2012 | HP Photosmart 3210 Printer
I am printing in red but output is yellow
Check the ink levels- it sounds like your Magenta is out- HP deskjets use CMYK to mix the colors- C = Cyan, M= Magenta, Y = yellow, K = intensity (black). Red is usually a blend of Magenta + Yellow- so if you don't have magenta ink in your printer, when you try to print out something in red- it will come out yellow
Jul 01, 2011 | HP Deskjet D2360 InkJet Printer
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
Printing problems
try to clean the noozle of you catridge..... then try again...... or try to shake it
Sep 01, 2009 | HP PhotoSmart 7960 InkJet Printer
Printer printing out wrong color. i have cleaned the cartridges several times, checked to make certain tape is off. How do I configure the printer to allow me to have access to the printer service to...
Print a test page. if that is ok, then it could be the color profile you have selected. Also, you can make your own test pattern of Yellow, magenta, and cyan. (use mspaint and make 3 colored bars, a black bar, and a white background). Print that, and see if all 3 colors and black are printing. If one color is not printing (ie, yellow for example) then there is an issue with that printer head on that cartridge. If you are recycling the carts, then that cart needs replaced.
Aug 28, 2009 | HP Photosmart C3180 All-In-One InkJet...
I have a HP Photosmart C5200 - pages are printing pink and red streaks in pictures
the print head for magenta and cyan (might be also Yellow) is dirty. you can try to clean it with warm water, or replace a new print head.
Jul 31, 2009 | HP PhotoSmart InkJet Printer
Green tint when printing
Hi, did you tried to calibrate your colors but on the printer? The printer decides which color it's gonna print, regardless to the color on the screen. He's gonna try most of the time to print the closest color he can make. We call this WYSINWYG. What You See Is Not What You Get. You should have a tool with the HP printing software. Otherwise i guess you can print a test page to check the colors. Make sure each color Cyan/magenta/yellow and black print corectly on the test page. Usally on HP printers you have to hold the Go button 5-10 sec and it's gonna print the test page but refer to your manual if you are not sure how to do this. Could also be a problem with your print heads, check if there is a procedure in the manual to clean those.
Jun 05, 2009 | HP PhotoSmart 7760 InkJet Printer
HP c3180 color printing problems
I would definitely start by printing a self-test page. With your model press and hold the Cancel button and then press the Start Color Copy button and then release both buttons. When this page comes out you should be able to identify the 4 different color sections...black, cyan, magenta and yellow. If any of these seperate areas are choppy or non-existant, you need to replace your cartridge. Here is a link that will show you examples of what you should/shouldn't see on the self-test report.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00661556&lc=en&dlc=en&cc=us&product=1146331&rule=25470&lang=en
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP PhotoSmart InkJet Printer Logo
82 people viewed this question
Seeker5211
Seeker5211
