Question about Tatung Elio Photo JukeBox MP3 Player
Open Does anyone know how to open the mp3 player?, there doesnt seem to be any screws...
  • Anonymous Jun 23, 2008
    My battery needs replacement.
    How is Elio opened?
    What battery is used?
  • Rolf1 Jun 23, 2008
    I need to replace the battery. How is the player opened?
    Where can I buy a battery?
Hi.The back can be taken out (my elio crashed into the ground)and it opened itself.It has no screw, just a fittet back with a kind of glue.
Posted on Jul 13, 2007
SOURCE:
I need system files for my iRiver H10 20GB MP3 player
hard drive is probably bad -- common problem. cheapest solution is tobuy as-is h10 from ebay with a working hard drive (perhaps it has atouchpad problem), open the unit up and replace the drive.
See this forum for info on how to open the player with a torx tool and a plastic pry unit. forum
Planb - sell unit on ebay in as-is condition and use money toward a topnotch 20gb refurb unit for about $30-50 from sellers like metromania
Mar 03, 2009 | iRiver H10 MP3 Player
Cant get the music from the computer to the player
Open Windows Media Player and see if Windows Media Player will recognize the player. If not, change the USB mode to MTP mode per the manual's instructions.
Jan 03, 2009 | SanDisk Sansa e250 MP3 Player
Sony CFD-E95L disassembly
There are 11 screws that need to be removed: Bottom - 2 on both sides of the word "ATTENTION"; 2 on the outer edge at the three and nine o'clock positions; 3 under the handle; 2 in the CD player compartment; and 2 in the upper left and right corners of the cassette compartment.
Feb 04, 2008 | Sony CFD-E95 Radio/Cassette/CD Boombox
I can't find out how to open this thing!
it opens from the top take out the screw in the back use caution when seperating the back case. then take out the four screws that hold the sheild on the batery and hard drive are exsposed
Dec 07, 2007 | Philips HDD082 MP3 Player
My RCA Lyra RD1072A just doesnt play songs
The most probable cause that I see happening to people with the same item is the fact that somewhere between uses, the setup files in the device itself gets corrupted. When this happens, you're pretty much screwed. You can't access them because it won't let you, you can't format it because it won't let you, you're left with a dead mp3 player. Sorry, but you need to get a new one. The other one is trash.
Nov 09, 2007 | RCA Lyra TH1012 MP3 Player
Sony nw-e003f
i am not able to play songs in my mp3 player it is showing that there is some format error and the hardware also is not functioning properly the mp3 player is now just for storing data only pls suggest some methods to clear this problem
Sep 22, 2007 | Sony NW-E507 MP3 Player
How do I replace the Battery in my RCA RD2762A?
ON THE BACK THEIRS A BARCODE IN THE CENTER PUSH DOWN YOULL SEE A LITTLE SCREW AFTER YOU GET THE SCREW OUT PUSH UP
May 07, 2007 | RCA Lyra RD2765 MP3 Player
Broken on-off switch on Rio 600
They are Hex head screws. You need a small (1.3MM or .050) Hex head bit or Allen wrench. After removing the two screws the case will split. However the problem I'm having is figuring out how to re-attach the switch. It's a very odd connection.
Apr 29, 2007 | Rio 600 MP3 Player
Scroll bar stuck scrolling down
Yes there are locks on the sides of the player so you'll need something sharp to slide along the sides it will open just be carefull.
Aug 08, 2006 | iRiver H10 MP3 Player
Display Problem
Check the battery to see if it has the original capacity if not you may need to rejuvenate it. Also try to open the unit and reattach the LCD. Good Luck.
Aug 07, 2006 | Sony NW-E105 MP3 Player
Tatung Elio Photo JukeBox MP3 Player Logo
104 people viewed this question
Top Tatung Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Tatung Audio Player and Recorder Expert? Answer questions, earn points and help others
