Question about Dryers
FRIGIDAIRE FSEC747GES1 DRYER DRUM STOPPED
The only way i can get the drum to turn is to "crank" it to start - like a 1910 car! this is hard on my arm
  • 7 Answers
SOURCE: dryer wont start, drum hard to turn-revised
get a new drumm it might be bent if your putting stuff that weight alot in your dryer if its making a skeeking rusing soung get a new drum about 400 dollers
Posted on Dec 21, 2008
  • 659 Answers
SOURCE: FRIGIDAIRE GLEQ2152ES0 DRYER DRUM WILL NOT TURN
You need to check the motor isn't bad which is possible. All of what you have stated is possible. You are going to have to check out each and every one until you find it. But all three can cause it.
Posted on Apr 18, 2009
  • 58 Answers
SOURCE: When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
Posted on May 01, 2009
mikesagenius
  • 24 Answers
SOURCE: frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
Posted on Jun 03, 2009
  • 161 Answers
SOURCE: When Turned on, drum will not spin?
if the motor is running,your belt is the problem.if all you hear is a slight humming noise,you may have a bad motor,or something caught in blower. if the drum turns easily by hand,its probably the belt
Posted on Mar 06, 2010
Squeaking frigidaire stacking dryer
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Oct 10, 2010 | Frigidaire FEQ332E Electric Dryer
Dryer starts but drum does not turn. was fine until a sneaker got wedged between one of the fins and the chamber wall and drum stopped turning and we smelled a burning odor. after removing the sneaker we...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Oct 02, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer just hums when i start--tub does not turn.
Oct 01, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Feb 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
GLER341AS1 Frigidaire electric dryer, was grinding, now not work.
Sounds like you have two problems with your dryer, both are fairly easy fixes if you are mechanically inclined and cheaper than buying a new dryer.
1...Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley. 2..Sounds like the front seal between the drum and the door needs to be replaced
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt and front seal. You can now replace or reposition the drum seal if it has moved from its normal position. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Jan 11, 2010 | Frigidaire GLER341A Electric Dryer
My Frigidaire Dryer model # FDE336RES1 was running but with a screeching noise, now it has started to smell, the drum still turns.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 16, 2009 | Frigidaire FDE336RE Dryer
Dryer will not start, when you press start it only hums , it acts like it is stuck in pause mode
Your problem may be a broken belt, or could be a faulty motor, or the belt may have slipped off of the motor pulley or idler arm pulley.
Try this first:
Unplug your dryer, reach inside the drum and rotate the drum 1/4-1/2 turn. Plug your dryer back in and push the start button again.
Sometimes motors get dead zones in them, and this will help to move it from that zone.
If this does not help then you will need to check further.
If it is a front load machine, you can remove the front and this will expose the drum and belt, you can then remove the belt and drum and that will expose the motor, and idler arm bracket with pulley.
I hope this helps
Oct 04, 2009 | Frigidaire Dryers
Frigidaire dryer quit
sounds like the motor unless something is stuck in the blower housing such as a sock
Jul 13, 2009 | Frigidaire Dryers
Apr 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer Motor won't always start Model FSE747GES
Too much drag on the Drum. Try lubricating the rollers that the drum turns on. Check the belt tensioner pully...lubricate that as necessary. If Drum still turns very hard after this then take belt off of motor and try turning drum. If drum turns easily then replace motor.
Nov 24, 2008 | Frigidaire FDE336RE Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
