Question about Konica Minolta Bizhub 362 Copier
Error code c4101 - Konica Minolta Bizhub 362 Copier
I repaired the polygon motor just by putting oil in it, so I didn't have to replace any part. Try it before replacing parts !
Posted on Jul 13, 2013
  • Konica Minolta Expert
  • 158 Answers
This is a polygon mirror motor failure replace the laser unit. to reset the error code open then close the front door while the machine is turned on if the error code comes back the parts will probably have to be replaced
Posted on Mar 21, 2013
I have a konica minolta 280 an there is a code c4101 . how to clear this code
The print head is bad.The print head is what houses the LASER. Its a large assemble under the image units. Open close the front door and or the right door.to reset the code. if it come back replace the print head, but also check all connectors to current print head and control board the controls it.
Jan 08, 2016 | Konica Minolta Bizhub C280 Color Copier
How do i download zinox c4101 wireless lan drivers
Zinox do not list this as a laptop of thiers.
Feb 24, 2015 | Computers & Internet
Error code c4101
Print head failure The assy. that has the machine LASER inside of it also has a motor called polygon motor very high speed 35000 plus rpm. mite hear when you turn on the machine initially . Well it causing the code. Open close front door to reset
Jan 23, 2014 | Minolta bizhub 200 All-In-One Printer
THE COPIER DISPLAYS ERROR C4101
C -4101 Polygon motor error.Change the polygon motor,if you can not reset the malfunction code.
Mar 02, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
How can I solve the problem in Konica Minolta Bizhub 282 error code C4101
You have Print Head Failure, the Print Head houses the LASER along with the LASER is a motor, your code deals with the motor, Motor can not be replaced, entire unit is, try this site they mite have it or will have to get a Konica Minolta Dealer, Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 23, 2013 | Genuine Konica Minolta Genuine Bizhub...
I have a code error c4101 in minolta 350 bizhub
Does the machine come to ready state? and if it does, does the code blow as soon as an original in placed in the df or the start button is pressed?
Make sure you have 2 ribbon cables and one connector running through back of machine from PH unit. Also make sure you have the correct ph unit installed.
Here this is straight from Konica ...
C4101 code at power up.
Description:
Solution:
PROBABLE CAUSES:
1. Failed PWB-A (Mechanical CB).
Replace the PWB-A board (p/n 4040 0101 03).
2. No 24V DC at PJ17A, pin 5.
Replace the 3.15A fuse located on the power supply.
3. Polygon motor in the Print Head Assembly fails to turn.
Begin by checking the connections to the Print Head Assembly. Unplug and reseat all connections. If issue continues, replace the Print Head Assembly (p/n 4040-0751-00).
C-4101 (C4101) at power up.
Description:
C-4101 at power up.
Solution:
CAUSE: Failed BCRS board.
SOLUTION: Replace the BCRS (p/n 4551 2033 01 for bizhub 350 and p/n 4551 2034 01 for bizhub 200/250).
G.L.
Apr 24, 2011 | Computers & Internet
Error code c4101
Error cod C4101
Machine Konica Minolta c6500
Nov 25, 2009 | Minolta bizhub 200 All-In-One Printer
Konica Minolta Bizhub 362 Copier Logo
457 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
