Question about Samsung TXN2771HF 27" TV
No Picture, No Sound...Please Help
I just moved my tv from one room to the next and my tv doesn't work. it makes the power up sound, but no picture or sound. the red led light (next to the power button) stays on all the time. the led light use to turn green. any help would be great.
  • Anonymous Jan 30, 2008
    unplugged tv prior to wind storm-now does not come on - unplugged and wait 15 min. still wont power up-
    Novelist:
  • 192 Answers
The most common problem this set has is the Horizontal Output shorting, usually caused by the High Voltage transformer drawing to much current. Whether it's the high voltage circuit or the power supply, having a tech look at this set would not be cost effective. Start looking at the newer technology. Hope this helped.
Posted on May 13, 2007
SOURCE:
I have a Samsung flat screen TV and I have sound but no picture it's a black screen can somebody please help me it's been 2 days now since I've been able to see TV
Hope I am wrong but having sound and no picture, sounds like you have blown the picture screen.
Is it against a wall or similar and if so is there room at the back for air to circulate as this is where it cools the TV.
It can also just go with a power surge to.
Regards Craig
Feb 09, 2018 | Samsung Televison & Video
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
I have Sony tv kdl50xbr4 , had sound no picture.the tv had to turn on,off several times to have the picture!any help please
Dont know how much you like to tinker but or if you know someone. A TV has different circuit boards. One for power one for picture, one for sound, one for tuning. Power board works everything, picture board goes to to the tube, sound board connects to the speaker. Probably gettin kinda complicated all else fails have it repaired or upgrade.
Hope you find a solution that works best
Feb 04, 2015 | Sony Televison & Video
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
52 inch Toshiba rear projection no picture has sound
You have bad solder connections in the deflection circuit. Call a good TV tech unless you know what you are doing. You could get an electrical shock from a charged capacitor.
Jul 06, 2009 | Toshiba 57H81 57" Rear Projection...
No picture or sound
Check the power supply circuit for dry electrolythic capacitors (assuming that occasionaly it works)
Best of luck
Jun 25, 2009 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
NO PICTURE OR SOUND
It seem that the OSD still working but the screen is black. try to resolder it first because many old tv has cold solder problems.
May 31, 2009 | Apex Digital AT2008 20" TV
TV no pictuew
I have a sony trinitron kv35s40 and the problem is picture cuts off after a minute or so. We moved it to another room (it's really heavy 36") and it started with the problem.We live upstairs and can't bring it to a repair shop without a lot of effort.Please help What can it be?
May 26, 2008 | Sony KV-27S20 27" TV
No picture or sound
hi guys! i have a tn61x81 and the probleme with this tv is when i plug the tv the tv try to open but shut down y try to push the power botom it's make no difference the light near the power botom is flashing no power no image no sound noting. i think it's the power suply but i'm not realy shure. if aneyone can help me it will be realy apreciate.
Oct 29, 2007 | Toshiba TN61X81 61" Rear Projection...
Samsung TXN2771HF 27" TV Logo
165 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
