Hotpoint WF360 Stuck on test
Wont run any cycles, just keeps running a test cycle every time I restart it.
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
My hotpoint dryer will not stay running unless the start button is held down
What you can do without any tools or experience...
Ok... Let's first assume you have made sure there is nothing keeping the door from closing completely. The start circuit overrides the door switch momentarily to initiate the run circuit.
A malfunctioning door switch is possible but they are simple and built for many cycles. The timer could not be in a "RUN" position. Reposition it to "TIMED " cycle of a reasonable length for the load.
Check the closing of the door and the contact with the door-switch is not obstructed in any way.
Retry the start button....
If it still will not run on it's own, it will require internal testing. I would have to recommend a qualified repair Tech be called.
Dec 09, 2015 | Hotpoint Dryers
WF220 Hotpoint - burning smell + wash cycle stalls?
The burning smell is coming from motor. Also your clutch is bad where you are hearing the rattle/grinding.
Dec 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Drum will not empty water
sounds like its not going thru the complete spin cycle and empty could the timer control switch its all intergrated in one all the the different application s the cycles goes thru all report back to the timer control switch and when the cycle is complete the timer goes to the next cycle i f the timer is defective it well keep on going reguardless and go to the next cycle unfortunately the cost will run around 250.00 for the part good luck
Aug 10, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Hot point wmlt80, dail clicking and turning, cycle wont start,
Yes, I work for GE what you need to do is to resent the appliance. Something should had happened with the computer of the washer. Just unplugged the machine for 40 seconds. You can unplugged or turn off the circuit breaker for 40 second and plugged back in. Select a normal cycle and let it run.
Jan 15, 2009 | Hotpoint WMTL80 Top Load Washer
Test on display cant use washer
turn the machine on while you press the start and on buttons at the same time until dOFF appears.
Dec 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint WT540 problem
You have to check your pump, probably clogged
May 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Ultima WF 840
try unplugging from wall hold down start button for a few seconds leave unplugged for 10-15 mins reconnect and ckif problem still there may be control bd problem ..first call the sales person you bought if from ..some washer have a demo mode for floor display use may be a way to back out of it
May 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD129 Wash programme stuck
i am having the same problem with my widl126 washer.
ant help?
Apr 30, 2008 | Washing Machines
Hotpoint WD860 problem
washer wf860 showing f07 error. why
Mar 04, 2008 | Hotpoint Washing Machines
Hotpoint Aquarius WD645
If you by accident press the start button and the cancel button at the same time it puts the washer into demo mode.To switch it off press both buttons at the same time and hold until dEND is displayed. Sometimes you have to keep trying but it will work, it did with mine ok.
Sep 09, 2006 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
