Question about KitchenAid Refrigerators
KichenAid model KSRJ25CNST00 side by side won't make ice. Changed solenoid still won't make ice. Unplugged 24 hours still will not make ice! Please help? lmeadows66@gmail.com
Model KSRJ25CNSTOO CHANGED SOLENOID, unplugged 24 hours still won't make ice although water dispenser works. There is a red light inside freezer, should it be staying on or flashing or should it be on at all? Please help as this is becoming expensive! lmeadows66@gmail.com
SOURCE: Kenmore water dispenser not working, side by side frig
no water come out of dispenser to glass
Posted on Aug 06, 2008
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
SOURCE: I have a Hotpoint side by side refrigerator, model
probably the water solenoid. it will be in the back lower area. follow the tubing to the vavle
Posted on Aug 08, 2009
  • 291 Answers
SOURCE: Fridgedair R134a ice maker water wont fill.
Your icemaker send the voltage to the water valve as it cycles through its ice drop. Pull your icemaker out, and test the wiring it was plugged into for continuity to the water valve, usually you will only have one colored wire that has continuity. Your white wire is usually your nuetral and as long as both wires are ok, then replace your icemaker or your icemaker module if it has one. You have a very good parts house on Oahu called Reliable Parts, Take your icemaker in if you live on Oahu, or call them with your parts number if you are on the Big Island. I worked on Oahu for 15 years. Good Luck Appliance Specialists
Posted on Dec 14, 2009
Testimonial: "Thanx very much I hoped it wasn't the whole ice maker, yet I kinda figured, but being on Oahu it's no biggy. Jeff."
My refrigerator wont work after laying it down to move it. What should I do?
I've done that before and there's no hope for it. Once you laid it down the freon got a air pocket in the compressor and it will no longer work. Guy from sears told me that laying them down ruins them.
Feb 20, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
We recently had a water supply connected to our Whirlpool refrigerator model GB2FHDXWB02. After ~ 18 hours no water has entered the ice maker? What is the problem? Can I manually initiate water going into...
Make sure you actually turn the icemaker on, there is a arm that you have to trip in side that will activate the solenoid that make water enter the ice marker. Also keep in mind that the air in the line has to work out so give it 24 hours to make it to the ice maker. You should see the hose in the back of the frig, that runs from the solenoid to the ice maker. Also check the ice maker itself to make sure it is plugged in completely. Good luck
Jan 09, 2015 | Whirlpool Refrigerators
No water to ice maker. water to door drinking side. unplugged for 3 days to make sure no ice build up also checked solenoid and its working. Any help.
Since you have the refrigerator unplugged for 3 days, its safe to say the water line wsan't frozen. When was the water filter changed? If you can't remember, it is probably time.
Apr 02, 2012 | KitchenAid Refrigerators
I have a Kenmore side by side model # 106.53609202 and its about 8 years old. About a month ago it stopped making ice. I've already replaced the water valve behind the fridge and waited 24 hours and...
OK, remove the cover on the face of the ice maker and let me know if the model look like this picture:
12_17_2011_1_36_01_am.jpgIf it looks like this model, I have the service manual for it with all the testing procedures.If it doesn't, see if you can get a model number off the unit. They make about 4 different model for this unit.
Happy Holidays!Richard
Dec 17, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
KitchenAid 25in KSRJ25CNST00 icemaker trouble. The LED light on side of freezer is blinking twice with a delay and repeats same sequence. No ice is making. Any suggestions on what to look for?
Try the reset button on the control panel. If that doesn't work, then try unpluging the refrigerator.
Also, make sure that ice tray shut off arm isn't in the up position. It should be in the unlock position one notch below the off position. This arm is used by the refrigerator from over filling the ice cube holding tray. Once the ice fills the tray. The ice in the bend will push up on the arm which
initiate the ice maker to stop making ice. As soon as you start using the ice in the bend and the arm falls below the off position. The ice maker will start making ice. GB....stewbison
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kenmore side by side - model - 253.54739304. we moved it from one house to another. it was working fine. now won't freeze or cool properly. like it is in defrost mode. compressor was not running...
if while moving it , you laid it on its side, it collected air in the lines, having it unplugged is a good idea, normally 24 hours is enough for the air to settle,, try it again after that time,
Jul 09, 2011 | Refrigerators
Water tastes fine but ice tastes bad. changed the water filter already.
Since the water goes through the same path except the line from the dual valve solenoid to ice maker, it could just be residue in the line. Suggest you dump the ice for the first 24 hours and then check it. There just isn't a lot could cause the problem you describe.
Jun 16, 2011 | Kenmore Side by Side Refrigerator
I have a Jenn-Air refrigerator #JCD2389DES. The ice maker became stuck and kept delivering ice cubes even after dispenser was released. I finally opened the freezer door and got it stopped. Now it...
Yes it could be either, BUT I would go back and make sure that everything you did to stop it the first time is undone. Is everything setted correctly? Is the switches in the right place?
Neither the solenoid or the microswitch could cause the problem you had before, so I would suspect something is not right with the ice maker itself.
Jun 16, 2011 | Jenn-Air JCD2295HES Side by Side...
Maytag Plus side by side refrigerator stops cooling. I unplugged it for 24 hours. When I plugg it back in, it works fine for about 2-3 months. Then it stops again and works fine after being unplugged for...
Take food out of the freezer, take out the racks, take off the back panel on the bottom/back ( probably 4-6 screws).. You will see a fan. If that fan has ice around it, then take it all off, chip it, hair dryer, what ever you want. Unplugging it for 24 hours is not enough for all of the ice to melt so it is probably taking a couple months to build back up. Generally this happens in a high humidity time of the year. It will probably happen again, do not freet. Just clean it again. I know one customer that had it happen two years in a row and that was about four years ago. He has had the unit (Maytag Plus side by side refrigerator) about 10 years and is just fine with it. Little inconvience, but sometimes that is the breaks in life. Good luck.... f067b6b.gif
Nov 30, 2009 | Refrigerators
Icemaker in Admiral side by side refrigerator/freezer stopped working
see if you can bleed the air trapped in the water line to the ice maker. if air is trapped, water would not be flowing and it would take only a few seconds for the solenoid to be open to let water flow.
see if you can hot wire the solenoid to let water and air out of the tube long enough to bleed the air and hopefully, the ice maker would work continuously.
tnx 4 using fixya,
drcool
Oct 08, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
