Question about Audiovox Vehicle Parts & Accessories
My model APS-997C audiovox transmitter won't activate the alarm system
Remote won't activate the alarm
jpk528
  • 95 Answers
SOURCE: prestige platinum by audiovox need to replace the remote for it
if you need a remote you can buy one from audiovox.com and also you can download the installation manual and user manual in which that will tell you how to program the new remote for the remote start.
Posted on Feb 16, 2009
  • 152 Answers
SOURCE: Reconnect remote starter
Those devices, when operating properly, are commonly not disconnected, but you could attempt to find the power lead and the in-line fuse to make those re-connections, also check the battery(s) in the remote. If the disconnection is more in-depth then you should acquire the installation and owners manual from Audiovox, so as to troubleshoot and maybe discover what else is disconnected.
Good luck...
Posted on Feb 23, 2009
rteemon
  • 578 Answers
SOURCE: Transmitter no signal
check you setting or rest and start programming over
Posted on Jul 01, 2009
  • 151 Answers
SOURCE: I have an Audiovox Car APS95BT3 Transmitter with 3
here is a link that should help you.
http://audiovox2.info/docs/voxx_mob/man/APS95BT3_DOC_TPG.PDF
Posted on Dec 28, 2009
  • 5370 Answers
SOURCE: I need a new remote
Yes you can get this remote from the link mentioned below:--- Click this link directly:--- http://www.autotechs.com/items/item1042.htm ------------ Also click this link directly,This is near to identical remote to your remote:--- http://www.autotechs.com/items/item1154.htm ---------- Check out both the links and order your required remote.This will help.Thanks.Helpmech.
Posted on Dec 23, 2010
How do unlock my sentry electonic safe?
Hello, If you don't have the combination you will have to write sentry cust service with the model and serial number to get the combination. Here is their number you can call: (800) 828-1438
Jun 01, 2014 | Audiovox APS20B Prestige Programmable...
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
Tip
How to program Chrysler Remote Transmitter
A Chrysler Transponder Key once programmed into a one car cannot be programmed to work any other car.
The transponder code identification is learned by the Sentry Key Immobilizer Module during programming. The Sentry Key Immobilizer Module sends the "Secret Code" to the transponder key and is retained by the transponder key during programming. After programming of the transponder key identification to the Sentry Key Immobilizer Module and the Secret Code is exchanged, the Sentry Key Immobilizer Module will ask for the transponder identification and the Secret Code every time the key is turned to ON or START.
No Emergency "Start" procedures for Chrysler vehicles.
Chrysler Key Operation and Programming
Model: 300 Year: 2005 - 2008
Model: 300C Year: 2005 - 2007
Remote alarm / central locking
System Operation
  • Pressing key LOCK button activates alarm and central locking.
  • Pressing key UNLOCK button once deactivates alarm system and unlocks driver's door.
  • Pressing key UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors and trunk.
  • Pressing trunk lid button twice opens trunk lid.
  • System will automatically lock all doors when vehicle is driven above 15 mph.
  • Additional functions can be set to respond to the transmitter.
Programming
When
  • Key transmitter added or replaced.
How
  • Key transmitter is programmed during immobilizer programming procedure.
Immobilizer
System Operation
  • Immobilizer warning lamp illuminates for approximately 3 seconds.
Programming
When
  • Keys added or replaced.
How:
NOTE: Two programmed key transmitters must be available for the following procedure to operate. If none available key transmitters can only be programmed using diagnostic equipment.
  • Insert first programmed key into ignition switch.
  • Switch ignition ON for at least 3 seconds but no longer than 15 seconds.
  • Turn ignition OFF and remove key.
  • Withing 15 seconds insert second programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will flash.
  • Turn ignition OFF and remove second programmed key.
  • Within 60 seconds insert non programmed key into ignition switch and turn ignition ON.
  • After 10 seconds an acoustic signal will be heard and immobilizer warning lamp will illuminate for 3 seconds.
  • Remove Key.
Check operation of programmed key transmitter.
Repeat procedure for additional key transmitters if required.
Model: 300M Year: 1999 - 2003
Model: Concorde Year: 1998 - 2003
Model: LHS Year: 1998 - 2001
Model: PT Cruiser Year: 2000 - 2005
System Operation
  • Pressing remote transmitter UNLOCK button once deactivates alarm system and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds deactivates alarm system and unlocks all doors.
  • Alarm / Central locking functions can be altered using remote transmitter.
Programming
When
  • Remote transmitter added or replaced.
How:
NOTE: One programmed Remote transmitters must be available for the following procedure to operate.
NOTE: Any existing remote transmitters not used during programming will become inoperative.
Using a programmed remote transmitter proceed as follows.
  • Press and hold remote transmitter UNLOCK button.
  • After holding the UNLOCK button for at least 4 seconds but no longer than 10 seconds, press remote transmitterPANIC button for at least 1 second and release both buttons.
  • Ensure acoustic signal is emitted indicating programming mode active.
  • Within 30 seconds carry out the following procedure for each remote transmitter (including previously programmed remote remote transmitter)
  • Press any button of each remote transmitter to be programmed.
  • Ensure acoustic signal is emitted after each remote transmitter operation.
  • Programming must be completed within 30 seconds.
  • Switch ignition OFF or wait 32 seconds to exit programming mode.
Ensure final acoustic signal is emitted.
Replacement remote transmitters can also be programmed using diagnostic equipment.
Immobilizer
System Operation
  • System arms after switching ignition OFF.
Programming
When
How
NOTE:Two programmed key transmitters must be available for the following procedure to operate.
  • Obtain all keys.
  • Using first programmed key turn ignition switch ON and wait 3 seconds, return to OFF position and remove key.
NOTE: First and second programmed key operations MUST be performed within 15 seconds.
  • Insert second programmed key and switch ignition ON.
  • Wait approximately 10 seconds.
  • Ensure immobilizer warning lamp begins to flash and an acoustic signal is emitted.
  • Switch ignition OFF and remove key.
  • Within 50 seconds, insert new key and switch ignition ON.
  • Ensure acoustic signal is emitted and immobilizer warning lamp remains illuminated for 3 secondsindicating programming completed.
For each additional key repeat procedure starting from the beginning.
Replacement keys can also be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Chrysler Remote Control Programming...
Is a autocommand model 21921 remote starter compatible with 2007 chevy trailblazer with factory keyless entry
go to IDATALINK.com,you can enter your car specs and buy correct interface module, door locks park lights dome lights and ignition module.i installed audiovox aps 997c remote start alarm with their module works like a champ.VERY INVOLVED INSTALL
Jan 19, 2013 | Design Tech Vehicle Parts & Accessories
I purchased a second hand vehicle equipped with what i believe is an audiovox alarm system. The alarm likes to go off at random times and i cannot figure out what is causing it. The car is a 97 vw gti vr6....
It probably needs to replaced. Audio Vox has several models that have window breakage sensors. These sensors are notoriously unreliable and do this quite often. I would replace the alarm itself.
May 14, 2011 | Audiovox Car Audio & Video
I have a Prestige APS-20B 3 Button Vehicle Alarm System installed in January 2005 in my 2005 Toyota Rav4 Plus. The Dealer was High River Toyota In High River Alberta Canada. both of my key chain...
You can purchase these remotes online and program them yourself. If you have difficulty programming the remotes come back to FIXYA for instructions. The remotes also should have a phone number on the back for ordering.
May 05, 2011 | APS20B Prestige Keyless Remote Alarm
Have a prestige remote start that was installed and only worked for one week. now the remote beeps but doesn't start or lock/unlock any doors. remote says inhibited . all doors are closed as is hood and...
If this is the Prestige 997C, there is a remote starter disable feature that can be activated through the programming switch. When it is active it will display "inhibit' on the screen. To deactivate this feature, press and hold programming switch, turn key on, off, on, off, on then off. When the hood pin switch is not making contact with the hood when closed, the screen will display inhibit. When the brake shutdown wire is active the screen will display inhibit.
Feb 27, 2011 | Prestige Remote Start
I'm looking to get the user manual for a car alarm: aps2k4sflcf.
Go to this site http://auto.manualsonline.com/manuals/mfg/audiovox/audiovox_remote_starter_product_list.html
and click on Platinum APS 686T - Audiovox Remote Car Starter Owner's Manual
and click on APS 686 - Audiovox 4 Channel Remote Car Starter Owner's Manual
Jan 16, 2011 | Prestige APS686T Remote Start and Keyless...
Vehicle Parts & Accessories Logo
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
