Question about Plumbing
My Moen 7700 drips from the faucets. what needs to be done?
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
motor1258
  • 6674 Answers
SOURCE: how do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
Posted on Jan 22, 2010
motor1258
  • 6674 Answers
SOURCE: We have a Moen 87315C kitchen faucet and it is
If it's leaking at sprayer, and not the base where connected to hose, try this. Buy a bottle or jug of CLR. (calcium, lime, rust ) from hardware store, and pour enough in a bowl that will submerse sprayer in it. When you go to bed, or out for a few hours, turn off both taps (obviously) and relieve all pressure as well from sprayer. Now wrap an elastic around the handle of the sprayer so that lever is depressed, and submerse it in the bowl of CLR, and let it work overnight or at least for a few hours. Next Day, or Later, remove elastic from sprayer, and try it a few times and see if leak has stopped. Quite often you get calcium build up on internal washer/seal, and this will clean it off. If no CLR, you can try vinegar as well, but I find CLR better. If it appears better but not stopped completely, give it another treatment.
Posted on Apr 13, 2010
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
SOURCE: moen 7700 leaking at base of faucet. how do you
you need to pull the spout off.
Posted on Oct 27, 2010
Moen 7700 is leaking around the base of the handle. What do I replace?
part 6 for 30 bucks, possibly 7 as well for another 30 bucks!
The only part you probably need is the o-ring for 50 cents. Big stores like Home Depot will give you those for nothing, So strip it and take the two parts in to show them. Home Depot then claim as a warranty repair.
Moen 7700 Chrome Single Handle Faucet Parts
Jun 21, 2017 | Moen Plumbing
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Moen 7700 kitchen facet started dripping...help?
    Dismantel the entire faucet and clean. Probably grime or dirth buildup if it has a rotating shutoff
    Jan 25, 2015 | Moen Plumbing
    Moen 7700 cartridge replacement
    This is the exploded view. The cartridge is available at any hardware store.
    http://www.moen.com/shared/docs/instruction-sheets/ins111a.pdf
    Jul 08, 2014 | Moen Monticello Single-Handle Kitchen...
    What do i need to do to get a better water flow from my moen kitchen faucet #7700. when you turn on and wash hands it sprays water all over counter-
    Sounds like your spray head on the faucet needs replacing. They do plug up with rust and corrosion every so often. You can take it off and try to clean it but be very careful it may still spray when you put it back together.
    Jun 07, 2014 | Moen Monticello Single-Handle Kitchen...
    Fix a dripping single handel moen faucet
    you can go on line with the make
    Nov 11, 2013 | Moen Plumbing
    The spout on my Moen 7700 kitchen faucet is very "stiff". Do I need to get plumbers grease into it to loosen? If so, how? I've tried dropping the nuts under the unit beneath the sink and am still
    you need to remove the moen cartridge. first, remove handle. at the top of stem, there is a U shaped retainer clip. it hard to see,use a small knife blade to catch the closed side of clip and slide clip out. once clip is removed, you should be able to pull cartridge out with a twist and pull motion. if it wont come out,that way dont pull to the point where you brake cartridge. that means replacing faucet. in extreme cases, you ca buy a moen stem puller for about $15. once stem i out simply coat with stem grease and replace cartridge. when replacing retaining clip, keep a pushing in pressure on end of stem to allow clip to slide into place. it iseasier to do than it sounds
    Dec 02, 2012 | Plumbing
    Moen 7700 leaking at base of faucet. how do you get to o-rings
    Here's a link to show you how to get the spout off using "strap wrenches" The allow you to get the nut off at the base of the faucet spout without harming the chrome finish.
    http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
    There is also a video at the bottom of the blog post showing how I did it.
    Oct 17, 2010 | Moen Monticello Single-Handle Kitchen...
    How do I fix a dripping MOEN T4572 lavatory faucet
    No charge.
    Jan 18, 2010 | Moen Monticello Single-Handle Kitchen...
    Plumbing Logo
    32 people viewed this question
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
