Question about Nintendo Wii Console
Please help.. wii not playing
Just recently, my wii wouldnt play wii games. the game channel said "Wii System Update". but whenever i try to update it fails. i know i am connected to the internet. and it plays gamecube games just fine. i really dont want to send it in, so how do i fix it?i have tried unplugging and diconnecting everything, and still nothing.
  • hunter315 Jan 08, 2009
    no we didnt modify it or anything. it just stopped working for no reason... but thanks for your help.
    about how much does is cost to get it fixed?
  • Nicholas Capobianco
    Nicholas Capobianco May 11, 2010
    Do you have an error code that you could look up on Nintendo's Customer Service webpage?
    Problem Solver:
  • 7 Answers
Try calling nintendo for troubleshooting first there very helpful, but unfortunately at one point i had the same problem the laser had to be replaced so yes i did have to send it in..but just for comfort they are expedient on there repairs.
one last note if you tried to modify the wii in any way,such as hacks illegal downloads your just out of luck as they will not repair it
Posted on Jan 03, 2009
  • andy_1968 Jan 08, 2009
    repair was free, it was still under warranty...i think there is a warranty for one year although i bought an extra 2 year warranty in any case before the work on your wii they will e-mail you about the costs, unless your under warranty
How do you bypass the wii update to play the gmaes
The simplest thing to do is to use StartPatch, if your Wii is running System Menu 4 or higher, or StarFall if you're running System Menu 3.2. (To check your system menu version, go to you Wii Settings; the version number will be on the upper right.)
These applications can apply various modifications to your Wii, including one that will allow you to play import games and another that turns off the annoyingly repetitive system menu background music. There is also a modification that prevents the Wii from checking to see whether a game disk includes a system update. If you use StartPatch/StarFall to install this modification, you will no longer have game disks insisting on updating before you can play them.
It should be noted that these applications, since they rewrite your system flash memory, can be considered somewhat dangerous.
You can play it safer with Gecko OS, which lets you play import and update-insistent games without altering flash memory. It has been found that at least one game, Prince of Persia: The Forgotten Sands, Gecko fails on.
Jan 06, 2014 | Nintendo Video Game Consoles & Games
Portal of power wont work with my modified Wii
Not a answer but I will try to help. Who ever your got your modded Wii from they should be able to update it.
My wii won't play the new wii games.Need to know how to upgrade?It will play the older wii games.
hi there,
the best and easiest way to upgrade the firmware on your wii is to connect the wii to your internet and look for system update in the system settings and update that way. Altthough most games that need newer firmware come with the update installed on the disc, normally once you insert the disc it will tell you it need to update the system firmware in order for the game to work, so i'm not sure why this is not happening for you if your new games not playing. The only thing i can think of if it's not updating automatically is that the wii has been chipped/modded in some way, has it? If it has'nt just connect the wii to the internet you should be able to update it that way.
Hope that helps
Feb 15, 2011 | Nintendo Wii Console
Wii Console: My wii console says 'wii system update' everytime ...
I had a friend with the same issue. I just modded his wii and then he backed the games up to a hard drive and they played perfectly without an update being needed. The best place to get your wii modded is www.wiihdmods.com
May 16, 2010 | Nintendo Wii Console
Error code 32017 keeps coming up on my wii console. i can still connect to the internet on my wii and play games but whenever i put in super smash bros it requires a system update. it will begin but never...
Error Code: 32017 There appears to be an issue with updating your Wii console.
  1. Try and perform another Wii System Update on your Wii console (how to).
  2. If you attempt another Wii System Update and still receive this error code, please call 1-800-255-3700 so that we may assist you further.
Mar 03, 2010 | Nintendo Wii Console
I put in a game and the home screen says "system update".
you can download the latest Wii System Update by selecting the "Wii System Update" button from Wii System Settings menu.
hope this helps.
Aug 28, 2009 | Nintendo Wii Console
System won't play new games - system up date failed
Try updating your Wii in the Settings menu, you will have to have a Wifi connecting to do this. If you do not have WiFi in your house can update your console via a New Release Wii Game such as Mario Kart
Most new games like Mario Kart or Madworld must have the 4.0 update to be played
hope this helps you some, please rate this solution
May 04, 2009 | Nintendo Wii Console
Update failing...cant play games
sounds like the system needs repairing
Go here http://www.nintendo.com/consumer/repair/wii_repair_home.jsp?problem=DISCALLGAMES for more information on getting your system repaired
or try removing all the cables leave for about 5 minutes replace the cables and power up again, check that the internet connection is sound then try a game again
Jan 02, 2009 | Nintendo Wii Console
My Wii stopped playing some games.
Check the system menu for any system updates.
Jan 01, 2009 | Nintendo Wii Console
Disk wont load.
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
169
Nov 30, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
143 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
