As my toshiba rd-98dt-k-dt got an inside fuse
I tried to switch on nothing i checked plug fuse it,s ok
2 Suggested Answers
  • 6771 Answers
SOURCE: toshiba RD-88DTKB won't switch on
Check the capacitor in the power supply board, if defective it will show a slight bulge at top, value should be around 1000uf give or take, if handy with soldering iron replace with same value and voltage rating.
Posted on Jun 06, 2012
Testimonial: "Thanks for the reply John, have not had the chance to look into it yet but will check soon, will get back to you. Thanks TB."
01 expedition headlights stuck on
Low beam ? high beam ? DRL - daytime running lamps ?
  • The headlamps are on continuously
  • Headlamp switch.
  • Circuitry.
  • Multifunction switch.
  • DRL relay 2 (if equipped).
  • DRL jumper (if equipped).
  • Headlamp relay (if equipped).
  • RAP module (if equipped).
  • Light sensor amplifier (if equipped).
  • GO to Pinpoint Test F .
F1 CHECK THE HIGH BEAM CIRCUIT FOR SHORT TO POWER
Pull CJB Fuse 16 (20A) - central junction box ,inside the vehicle ! Ignition on !
  • Do the headlamps continue to illuminate?
  • Yes GO to F2 .
    No - REINSTALL the fuse.GO to F12 .
  • F2 CHECK CIRCUIT 12 (LG/BK), 160 (DB/WH), AND 161 (DG/OG) FOR SHORT TO POWER
  • pull fuse's CJB Fuse 21 (10A) , CJB Fuse 22 (10A)
  • Yes - REPAIR circuit 12 (LG/BK), 161 (DG/OG), or 160 (DB/WH) as necessary. TEST the system for normal operation.
    No - REINSTALL the fuses. If equipped with daytime running lamps (DRL), GO to F3 .
    If not equipped with DRL, GO to F6 .
  • YOU CAN FIND WIRING DIAGRAM AT
http://www.bbbind.com/free_tsb.html Do you know how to use a wiring diagram ? Videos on youtube .
F3 CHECK CIRCUIT 13 (RD/BK) FOR SHORT TO POWER
do you know how to do this test ?
pull the
DRL Relay 2
Yes REPAIR circuit 13 (RD/BK). TEST the system for normal operation.
No GO to F4 .
No GO to F4 . F4 CHECK THE DRL RELAY 2 Carry out the relay test for the DRL relay 2; refer to Wiring Diagrams, Cell 149, Component Testing.
  • Is the relay OK?
Yes GO to F5 .
No INSTALL a new DRL relay 2. TEST the system for normal operation. F5 CHECK CIRCUIT 1032 (WH/BK) FOR SHORT TO POWER Measure the voltage between DRL relay 2 pin 2, circuit 1032 (WH/BK), harness side, and ground.
  • Is voltage present?
Yes REPAIR the circuit. TEST the system for normal operation.
No GO to F6 . F6 CHECK CIRCUIT 1033 (RD/YE) FOR SHORT TO POWER
Multifunction Switch C259
Measure the voltage between multifunction switch C259 pin 507, circuit 1033 (RD/YE), harness side, and ground.
Yes If equipped with DRL, REPAIR circuit 1033 (RD/YE). If without DRL, REPAIR circuit 13 (RD/BK), circuit 1033 (RD/YE), or DRL jumper as necessary. TEST the system for normal operation.
No If equipped with autolamps, GO to F7 . If without auto lamps, GO to F11 . F7 CHECK THE HEADLAMP RELAY Carry out the relay test for the headlamp relay; refer to Wiring Diagrams, Cell 149, Component Testing.
  • Is the relay OK?
Yes GO to F8 .
No INSTALL a new headlamp relay. TEST the system for normal operation. F8 CHECK CIRCUIT 7 (LG/YE) FOR SHORT TO POWER
Light Sensor Amplifier C216
Rap Module C257
Park Lamp Relay
Measure the voltage between headlamp relay pin 2, circuit 7 (LG/YE), harness side, and ground.
No GO to F9 . F9 CHECK THE HEADLAMPS FOR ILLUMINATION Check the headlamps for illumination.
  • Are the headlamps illuminated?
Yes GO to F10 .
No CHECK the headlamps while reconnecting the RAP module and light sensor amplifier. INSTALL a new RAP module or light sensor amplifier as necessary. TEST the system for normal operation. F10 CHECK CIRCUIT 15 (RD/YE) FOR SHORT TO POWER Measure the voltage between multifunction switch C259 pin 15, circuit 15 (RD/YE), harness side, and ground.
No GO to F11 . F11 CHECK THE MULTIFUNCTION SWITCH Carry out the multifunction switch component test; refer to Wiring Diagrams, Cell 149, Component Testing.
  • Is the multifunction switch OK?
Yes INSTALL a new headlamp switch; REFER to Lamp Switch-Headlamp . TEST the system for normal operation.
No INSTALL a new multifunction switch; REFER to Section 211-05 . TEST the system for normal operation. F12 CHECK CIRCUIT 632 (GY/OG) FOR SHORT TO POWER
Measure the voltage between multifunction switch C259 pin 12, circuit 632 (GY/OG), harness side, and ground.
Jan 21, 2017 | Cars & Trucks
My lg wd 1433 Rd won't turn on it beeps when plug in then it does nothing at all
The beep sound indicates to me that the fuse is ok and that power is reaching the main control board, but that it is faulty.
Have the main board checked out, you may need to replace it.
Apr 17, 2016 | LG Washing Machines
My 2003 Mercury mountaineer low beams won't come on
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
Pinpoint Test B: The Low Beams Are Inoperative
Normal Operation
The headlamp switch sends power through circuit 13 (RD/BK)/15 (RD/YE) to the daytime running lamps relay, then to BJB fuses 42 (10A) (RH headlamp) and 43 (10A) (LH headlamp) through circuit 13 (RD/BK). After passing through the fuses, voltage is then carried through circuits 161 (DG/OG) (RH headlamp) and 160 (DB/WH) (LH headlamp) to the low beam headlamps. Circuit 1205 (BK) is the ground circuit for the headlamps.
Possible Causes
  • Circuit 13 (RD/BK)/15 (RD/YE) open
  • Circuit 697 (BN) open
  • Circuit 196 (DB/OG) open
  • Circuit 1205 (BK) open
  • Circuit 632 (GY/OG) open
  • Circuit 12 (LG/BK) open
  • Daytime running lamps relay
PINPOINT TEST B: THE LOW BEAMS ARE INOPERATIVE Test Step Result / Action to Take B1 CHECK CIRCUIT 196 (DB/OG) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Headlamp Switch C205a.
  • Place the headlamp switch in the headlamps ON position.
  • Place the multifunction switch in the low beam position.
  • Measure the voltage between the headlamp switch C205a-8, circuit 196 (DB/OG), harness side and ground.
  • Is the voltage greater than 10 volts?
Yes
GO to B2 .
No
REPAIR the circuit. TEST the system for normal operation. B2 CHECK THE HEADLAMP SWITCH
  • Carry out the headlamp switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Is the headlamp switch ok?
Yes
GO to B3 .
No
INSTALL a new headlamp switch. REFER to Headlamp Switch in this section. TEST system for normal operation. B3 CHECK CIRCUIT 13 (RD/BK)/15 (RD/YE) FOR AN OPEN
  • Disconnect: Multifunction Switch C202c.
  • Measure the resistance between headlamp switch C205a-9, circuit 13 (RD/BK) and the DRL relay:
    • (early build) pin 3, circuit 15 (RD/YE)
    • (late build) pin 5, circuit 15 (RD/YE)
  • Is the resistance less than 5 ohms?
Yes
CARRY OUT the multifunction switch component test. If the switch tests OK, INSTALL a new multifunction switch. REFER to Section 211-00 . TEST the system for normal operation.
No
  • Battery junction box (BJB) fuse(s):
    • 16 (15A)
    • 22 (20A)
    • 42 (10A)
    • 43 (10A)
    • 46 (20A)
  • High beam relay
  • Circuitry
Sep 10, 2015 | Mercury Cars & Trucks
Toshiba problems
The alimentation main stage of your Toshiba is dead. Fix it in a technical service.
Aug 04, 2014 | Toshiba Televison & Video
Toshiba RD-88DTKB won't switch on
Jun 05, 2012 | Toshiba Televison & Video
Yamaha rx-v563 just stoped working no power no displayed nothing have removed plug and tried other power points still nothing help
Check the internal fuse inside the unit. If it goes again, after replacement, get back in touch with us. If OK check the transformer and the power switch.
Mar 01, 2010 | Yamaha RX-V563 Receiver
2004 ford f150 no headlights
In the central fuse panel (one inside the vehicle) check fuses 23 for left headlamp and 25 for right (10 amp fuses) for power with the headlamp switch on.You should have power accross these fuses with the headlamp switch on. If u do not have power check fuse 6 (15 amp). If this fuse is good then check for power to pin 7 RD/YE wire at the multifuction switch, if this is good then check for power on pin 6 RD/BK,if u do not have power here then multifunction switch is your problem.
Jan 12, 2009 | 2004 Ford F150
Toshiba RD 85-DT dr-2 error code
Hold the easy nav button and the number 2 down for a few seconds then try using the remote.Hope this works for you too.
Nov 28, 2008 | Toshiba D-R2 DVD Recorder
No power
the problem is the power section Hot and Cold area. maybe you have defective fusibul resistors or in the oscillation circuit thats why your tv cant turn on automatically.
Sep 26, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
