Question about Kenmore Elite Oasis 27052 Top Load Washer
What is an error f51
AAt 25 minutes the washer displays error f51 and will not continue to drain and spin
SOURCE: Washer keeps giving me a "F51" error code? What do I do?
I placed a very detailed post on how to resolve this issue. If you are mechanically and electrically inclined, this will give you pretty much step by step directions. I also analyzed why this is happening. Please disconnect power before any work... There is 120V floating around inside to bite you! Good Luck, GBaxter http://worldofwashers.blogspot.com/2007/06/cabriooasis-f51-error-codes.html
Posted on Oct 08, 2007
SOURCE: Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Posted on Dec 23, 2007
SOURCE: he2 washer flashing code f51
check hose inside mine had two baby socks clogging it up
Posted on Feb 14, 2008
reg501
  • 413 Answers
SOURCE: blinking F51
This has been a troublesome issue for Whirlpool and many of Whirlpools customers. The F51 code indicates a problem with the RPS (Rotational Speed Sensor) that monitors the motor speed. This issue has been identified as relating to the the connection system between the RPS and the controller.
Whirlpool has changed the RPS connector design, providing a more reliable connection and is available as a service kit. The control has also been updated for better sensing of the RPS. Also, if you have experienced problems with certain wash loads getting tangled and knotted, there is also an update washplate intended to reduce this issue. You should contact Whirlpool for possible repair concessions related to these issues.
If you would like to get to the RPS.. Here's how:
In some cases, the F51 code can be fixed by cleaning the RPS connector. The RPS is located on the motor armature underneath the machine.
1. Tilt the machine backwards, resting the console against the wall.
2. using a disposer tool or suitable hex wrench loosen the center stator screw completely (the screw is captive and will not fall out of hole).
3. The stator contains a series of strong magnets and will take some tugging and wiggling to pull off.
4. Remove the 4 bolts that secure the armature to the tub. CAREFUL this assembly is a little heavy, support well before removing last bolt.
5. The RPS is attached to the armature. Remove and insert RPS connector (the one with 6 wires) 10 times to 'wipe' the contacts providing a cleaning action.
If I can assist you further, please let me know
reg501
The FixYa Team
Posted on Jun 21, 2008
  • 327 Answers
SOURCE: F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
Posted on May 20, 2010
Washing machine is displaying F1 what does this mean
From Lyle W.
The F1 error code indicates a water level pressure transducer signal that is out of range. Here is a link for a previous answer regarding troubleshooting and repair for the F1 error code:
Why does my Whirlpool washer model WTW6500SW1 display the fault code F1?
The F51 error code indicates that the control board is not detecting the proper signal from the RPS (Rotor Position Sensor that monitors rpm's of the motor) sensor. This could be caused by an improper water fill level, an item stuck between the stainless steel spin basket and the plastic outer tub, an item under the washer that is interfering with motor spin, a failed RPS sensor, a wiring harness problem or a failed machine control board. Replacing the control board for the F1 problem described above may resolve the F51 error code problem at the same time.
I provided extensive technical troubleshooting information in the images below that a technician would use to diagnose and repair the F51 error code. If you have advanced technical skills and can use this information, you may be able to repair the washer yourself. This information is intended for technicians. Follow electrical safety guidelines when using this information. Be sure that you unplug the washer
to disconnect electrical power before accessing internal components. Do not attempt any procedure that you are not completely confident that you can safely execute.
If you need more help, resubmit your question with additional details.
If you decide that you need a technician to service this washer, I recommend that you call the Whirlpool Customer Experience Center at 1-800-253-1301.
Aug 06, 2015 | Washing Machines
What is f51
On some machines the F51 is a slow or long drain error. Possibly a clogged filter in the drain pump or a bad pump. You did not provide enough information for me to offer any more help. I do not know the washer type, manufacturer, age, or model.
Mar 11, 2015 | Washing Machines
Washer wont spin. F51 code
the f51 error indicates that your rotor position sensor) is not registering or it is just bad. try this, remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and RPS due to the intermittent connections. after that go ahead and try to run a cycle. if you continue to receive the error then you need to replace the RPS sensor. Here is that part to order. Whirlpool W10178988 Sensor AppliancePartsPros com
Oct 05, 2014 | Maytag Bravos MTW6600T Top Load Washer
Whirlpool duet washergets a code 2 when it gets to spin cycle.wont rinse and spin
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite toploader code f51
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 25, 2009 | Kenmore Elite 45986 Front Load Washer
Keep getting error code sd or 5d and sometimes a F error on my HE 2plus washer. Is there an inexpensive solution to the problem or should we be shopping for a new washer?
Hi
The Sd or 5d indicates that excessive suds are detected by the washer during the drain or spin phases of the cycle. The washer will stop and fill with 4 liters of water and then wait for 5 minutes to allow the suds to dissipate before continuing. If the suds cannot be reduced or eliminated so that the washer cycle can continue, it may stop and display the F21 (long drain) fault code. After the suds dissipate, you can normally drain the washer and spin out the clothes using a RINSE/DRAIN & SPIN cycle. Make sure that you are using HE (High Efficiency) detergent in the appropriate amounts to prevent excessive suds in the washer. This should prevent the washer from going into this routine.
And if you still face the same error then probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Also refer to these diagrams for more details--
Kenmore Drain filter and pump link1
Kenmore Drain filter and pump link2
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Jul 13, 2009 | Kenmore HE2 Plus Front Load Washer
F51 & F72 Codes
Basket Re-engagement Failure.
F then 72 flashes when the basket check routine fails to determine if the basket is re-engaged after being disengaged.
Is the basket floating? If yes, pump out water. See Long Drain.
Does basket turn freely? If not, determine cause of friction.
May 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F51 & F72 Codes
May 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Started getting an F2 error code
I looked up the F02 code online and this is what it says:
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Hope that helps.
May 18, 2009 | Whirlpool GHW9400 Duet Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
displayed.
Possible Causes / Procedure
or kinked.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
47 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
