Question about Air Conditioning and Heat for Pontiac Torrent
Air conditioning blower stop working is it a a costly problem
It started by working and going out and coming back on now its not coming on at all
  • Tom Chichester Oct 25, 2012
    What year Pontiac Torrent?Manual or automatic air?
  • 3 Answers
NEW CARS HAVE ELECTRONIC CONTROL MOD MOUNTED ON
THE BLOWER MOTORS YES BOTH GO BAD / IF YOU ARE
HANDY WITH TOOLS THIS SHOULD COST NO MORE THAN
$200.
Posted on Jun 09, 2014
  • Pontiac Master
  • 14,406 Answers
Check your blower motor resister,it's next to blower motor.
Posted on Oct 25, 2012
2003 trailblazer blower not working
Are you saying the blower motor would run intermittently and then just stopped working? My first thought is faulty blower motor, I've seen faulty blower motors that would run intermittently. Any motor that uses brushes, you can tap on the motor to see if it will start working, that is a sign of bad motor brushes, replace the blower motor. There could be other issues?
Did you check the blower fuse, not only check the fuse, check the fuse circuit for voltage, use a test light. Check for applicable hvac trouble codes. With hvac on, check for voltage and ground at blower motor wiring connector, if both are good and no blower action, suspect the blower motor.
May 13, 2017 | Cars & Trucks
HOW DO I REPLACE AIR CONDITIONING BLOWER MOTOR IN A 1999 323CI BMW?
Before you go and tear out a blower, try to see if the blower speed controls are tightly wired . It could have come loose ,or has broken. You said the blower came on, then off, then on again. It might be the power wire that runs from the switch to the main wiring harness has gotten loose , or melted at the junction point. I had a 2000 Saturn with the same problem. I replaced everything, including the blower motor, no help. Then in frustration, I left the battery connected, and pulled the climate control unit out. As I was lifting it out, the blower started working !! Found it was a loose power wire, I fixed it by jumping the connector . Cost me $1.00 , has run with no issues for two years now.
Aug 02, 2014 | Gates 1999 BMW 323i Air Conditioning Belt...
My air condition stop working. is it a fuse on my 2007 kia rondo
if the blower is blowing air its probley not a fuse .check blower threw all settings also slowly adjust your cold to hot mixing knob also do the same for inside and out side air button, you have to find out what is working and what is not to narrow your troble shooting
Aug 03, 2010 | 2007 Kia Rondo LX V6
2000 grand marquee 4.6 l air condition
You could have the beginnings if a malfunctioning Blower Motor which is located under your passenger side footwell. Have it tested first to determine if it will run continuously. if it does than check the A/C relay next.
Jun 03, 2010 | 2000 Mercury Grand Marquis
When you turn the heat on the blower motor starts making a grinding noise
could have debris in the fan housing or the blower motor bushings or bearings are going out. take the fan out of the air conditioning case and vacuum out the air conditioning/heater core assembly case. then hook everything back up and see if this works.
Oct 12, 2009 | 2000 Chevrolet Silverado 1500
The air conditioning fan stopped working, but cool air still comes fron the vents. It stopped and about a month or more my daughter heard a clicking sound when I shut the back door. I got in the car and...
Ur a/c fan should be under your hood against the fire wall. the wall behind the motor or in the car under the passenger side of the dash. You can knock on it or you can take off the wire and make sure it gets a good connection. If that dont work replace it.
Aug 21, 2009 | Kia Spectra Cars & Trucks
Air conditioning blowing only highest setting but HOT air
Sounds like your freon has leaked out and your heater blower resistor is burned out. Deffinitly take this to the dealer.
May 20, 2009 | 2001 Honda Odyssey
Air conditioning blower stays on at all times.
Per your description, I believe you may have a blower fan relay that is stuck closed.
Remove the relay from the under-hood fuse center and see if the fan stops.
If it does stop, put the relay in slowly and see if you here the relay "click" and the fan come back on.
Let me know.
Regards,
May 07, 2009 | 2003 GMC Sierra
Air Conditioning and Heat for Pontiac Torrent Logo
208 people viewed this question
Top Pontiac Vehicle Parts & Accessories Experts
jerry emmons
Jeffrey Turcotte
Jeffrey Turcotte
Hashim Khan
Hashim Khan
Are you a Pontiac Vehicle Part and Accessory Expert? Answer questions, earn points and help others
