Question about Sennheiser PC 360 Headset
Sennheiser pc 360 mic wont work
Hi, my mic wont work for my sennheiser PC 360 headset, it was working perfectly till now, I have no idea what could be wrong... But i do know it's not muted. Is there some ways to fix this?
5 Suggested Answers
SOURCE: Sennheiser PC 30 Headset not recognized on vista
My friend...
The sollution f this problem is to downliad this firware...install it and your headphones will be redy to play!!!
http://www.senncom.com/comm/icm_eng.nsf/root/support_faqs_pcusb_ms_vista
Posted on Jan 12, 2009
  • 35 Answers
SOURCE: Sennheiser VMX100 not working with G1
make sure you oreder your bloothoth from htc and its for the g1 next time
Posted on Feb 01, 2010
drifterK
  • 4924 Answers
SOURCE: My left cup has stopped
when one of the cups stop working it is a loose wire and you have to identify the wire cut and restore the connectivity ..Usually the cut is near the entry in the headset ..or in side on the mini-speaker ..
You will have to open them up and see where the wire is interrupted
Posted on Dec 31, 2010
SOURCE: My Sennheiser PC 166 gaming
Hi melamon,
Check the sound setting of windows, there is nothing wrong with your headset.
What windows do you have is i XP, Vista or Windows7?
anyways it is almost all the same just looks different on the windows version.
On the lower right side look for the speaker icon in the lower right side where the time is, then right click on it then select playback devices.
Once you have playback devices you should see a headset icon there if the headset is already connected.
right click on the icon then select properties or configure headset check the settings, also check the settings of the headset for the mic to see if there is an option to disable or set anything regarding echo or quality on the mic settings
Message me if you may need more info for further troubleshooting
Posted on Jul 12, 2011
Hi. Suddenly the volume controls for my Sennheiser i300 headphones for iPhone have stopped working. Any ideas? Thanks in advance Paz
I thought this was another example of the proprietary world of Apple, whereas any non-Apple made or certified headphones/headsets with mic and/or volume control will not work with an iPhone or iPad (I am not sure about iPod). It took me many headsets to figure out what was going on. However, your headphones seem to be made for iPhone and sold in Apple stores. If this is the case, I will go back to any Apple store and talk with the tech people there about your situation.
Oct 23, 2014 | Sennheiser Audio Players & Recorders
Great headset till I got an Android - How to connect
To Pair the Sennheiser VMX 100 headset with your cell phone:
At the same time as you open the mic, you also need to push down on the bottom/volume-down button on the side of the earpiece and hold this down (at the same time as opening the mic) until the light flashes red and blue alternating. (Just to clarify, it is the button that has an arrow pointing toward the Sennheiser logo). If asked for a code, enter "0000" (four zeros).
This video shows the bluetooth earpiece connecting to an iPhone 4S running iOS 5.0 (not jailbroken). This is the standard way to pair these devices (and it should work for Android phones as well), but as a disclaimer:
If anything should happen to your phone or your Bluetooth earpiece, it is not my fault.
Nov 30, 2011 | Sennheiser VMX100 Bluetooth Headset...
My left cup has stopped working in my sennheiser pc 350 headset and I would like to know how to get it working again.
Dec 31, 2010 | Sennheiser Pc 350 Headset Premium Gaming...
Iphone 4 does not pair sennheiser vmx 100
To Pair the Sennheiser VMX 100 headset with your iPhone or other cell phone:
This video shows the bluetooth earpiece connecting to an iPhone 4S running iOS 5.0 (not jailbroken). This is the standard way to pair these devices, but as a disclaimer:
Nov 06, 2010 | Sennheiser VMX100 Bluetooth Headset...
Is BW 900 Sennheiser compatible with Windows 7?
according to Sennheiser, it depends on the compatibility of the usb device driver of your bluetooth adapter in Win7 (it is NOT a BW900 problem in their opinion)
as I understand it, you have therefore to by a new adapter and see whether it works with the BW900. Take the device AND your computer to the shop and have them install and pair
Sep 06, 2010 | Sennheiser BW900 Bluetooth Headset
Sennheiser MM 50 iPhone Mic & Button does not work
I had just the same problem and if you're lucky, the solution is very simple: due to the open headset-plug of the iPhone I had a lot of dust inside. Just try (carefully!) to get the dirt out of the jack with a pair of tweezers or a strong vacuum cleaner. In my case it solved the problem. Good luck!
Apr 16, 2009 | Sennheiser (MM50) Headset
Mokrophone is not working
Found the problem... What Apple has is a line-in port...it requires a pre-amp to boost the signal of your mic. A PC likely has a mic-in port.
They're different ports...very similar but they accept different levels of input. Apple likely wants you to use their built-in mic for mic use and the line-in port for line-level audio sources.
Thsi appears to be our solution... Griffin iMic / USB Audio Interface
What a pain.
Oct 20, 2007 | Sennheiser BINAURAL HEADSET :unitsize...
Mic doesnt work
Totally the same with me.. any soloutions anyone?
Dec 26, 2006 | Sennheiser PC130 Consumer Headset
Sennheiser PC 360 Headset Logo
537 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michael Vincent Cruz
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
