Question about Whirlpool GMC305PD Electric Single Oven
WHIRLPOOL GMC305PD E1 F2 ERROR - Whirlpool GMC305PD Electric Single Oven
4 Suggested Answers
  • 49 Answers
SOURCE: I have a Whirlpool Oven
E1 F2 means bad connection between touch pad and control board. if connections are ok it may require parts. may get very expensive.
Posted on Aug 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: My whirlpool wall oven displays E1 F2
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^^^^^
Posted on Oct 01, 2010
  • 561 Answers
SOURCE: Hi - I have a
it could be the following
Taking a Quick Look
The E1 F2 error message indicates the control board thinks the touch panel has been unplugged from the board or it cannot read the switches.
How it Works
The panels on these ovens utilizes a switching matrix to constantly monitor all the buttons for a key press. By using a matrix for switch input, many buttons can be read by the processor using very few wires. The unfortunate side of a switch matrix is if any one wire becomes damaged, an entire row of switches on the matrix will no longer be usable since they cannot be seen by the control board.
advise
getting a qualified engineer to check this touch panel and suspect touch panel maybe defective and need replacing.
I hope this was helpful
Posted on Jan 05, 2011
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
How to clear F2 E1 error on a whirlpool double oven
E1 F2 is most often due to a failed keypad. Depending on your exact model the original part may be no-longer-available. However, there are replacement membrane switches available here:
Introducing the Ledgestone Technologies Touchpad
Models: RBD305PDB10 RBD305PDB11 RBD305PDB12 RBD305PDB13 RBD305PDB14 RBD305PDB15 RBD305PDB7 RBD305PDB8 RBD305PDB9 RBD305PDQ10 RBD305PDQ11 RBD305PDQ12 RBD305PDQ13 RBD305PDQ14 RBD305PDQ15 RBD305PDQ7 RBD305PDQ8 RBD305PDQ9 RBD305PDS12 RBD305PDS14 RBD305PDS15 RBD305PDT11 RBD305PDT12 RBD305PDT13 RBD305PDT14 RBD305PDT15 RBD305PDB1 RBD305PDB2 RBD305PDB3 RBD305PDB4 RBD305PDB6 RBD305PDQ1 RBD305PDQ2 RBD305PDQ3 RBD305PDQ4
Jan 08, 2014 | Whirlpool RBD305PD Electric Double Oven
E1 F2 error code
Check the ribbon cable for connection
Mar 27, 2013 | Whirlpool RBS245PDS Electric Single Oven
E-1 & F-5 come on after about a minute when attempting to use self cleaning. the micro switches work & the solenoid has been replaced. could it be the ERC ?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Oct 21, 2011 | Whirlpool GMC305PD Electric Single Oven
Error code e1 f2
1.
Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace
keypad (also called touch pad or membrane switch). Some models incorporate
keypad in to control board as one unit. In this case, replace control board
(also called ERC or clock).
http://www.appliancepartspros.com
F2 - E1
Keypad cable unplugged
Feb 15, 2011 | Whirlpool GBS307PR Electric Single Oven
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oven door is locked after trying to clean and getting error code E1 F5
E1 F5 means your unit is having a problem with the door latch and lock assemble turn the power off for 10 min. and after turning the power back on wait another 10 min. before opening
Apr 05, 2010 | Whirlpool GMC305PD Electric Single Oven
I have a Whirlpool Oven RBS305PDS16 is having an error code E1 F2 and then it shuts off. What could be wrong?
Aug 20, 2009 | Whirlpool RBS305PD Electric Single Oven
GMC305PD
appears that it is starting up the self cleaning feature ( which runs the temp up to the max to burn off any grease etc ) and locks the door.. You may have a defective control board.. or check the self cleaning switch position to make sure that is not activated... Hope that helps..
Aug 18, 2008 | Whirlpool GMC305PD Electric Single Oven
Whirlpool GMC305PD Electric Single Oven Logo
27 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
