My Hotpoint WF360 is stuck on TEST. It finishes running through all the lights and comes back to the program I want but every time I push start, it runs the test again. I have switched it off and tried to cancel it all to no avail. Please help!
  • john443 Jan 02, 2009
    Thanks that has worked for me :)
    Genius:
  • 3,422 Answers
HI,
Hotpoint washing machine shows test in display
Symptoms: Hotpoint washing machine just keeps running on its own and won't accept a program
This is caused when the demo mode is accidentally switched on. Instead of using a combination of two keys that need two hands to press, Some Hotpoint washing machines use two buttons next to each other to put the washing machine into demo mode. Even a leg leaning against the start and cancel buttons while reaching over the washing machine can turn on the demo (test) mode. To turn it off and get the washing machine working again, switch the washing machine on, then press and hold the centre line between the start and cancel buttons so that you are pressing them both in simultaneously. After a few moments you should see "d_OFF"
Sometimes this works first time. Sometimes it needs repeated attempts. If you are having trouble, try waiting until it's finished the spin section of the demo and catch it before it starts again.
and from http://www.hotpoint-wf840.utvinternet.com/
What if your machine seems to be stuck in a Test mode and wont wash? Stop the "TEST" cycle by holding down the "START/CANCEL" Button.
("Test" should disappear off the display)
Then hold down "START/CANCEL" & "ON/OFF" at the same time for a few seconds.
The message "d:Off" should appear in the display. Everything should work now
Posted on Jan 02, 2009
    Master:
  • 416 Answers
Hotpoints are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see ‘D:end’ (or similar message). Now try setting up a wash again
Good Luck
  • Washing Mach... Master
  • 19,396 Answers
Hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see ‘ a message.
Please help! It turns on, command light is flashing green, no turn off, doesnt move if i dont put water in manually
Failures, which occurred during the program will store and indicate for customer by flashing start LED (light-emitting diode). Appliances which have no program sequence or no 7-segment display can't exatcly show the failure. On these appliances the failure can only be found by starting the test program.
The passive test program shows the stored failure. If there is no failure the passive test program runs normal.
1. Switch off the appliance
2. Push start button and hold it
3. Choose position 1 of the "turning knob" turning right side (program 1).
4. Finish pushing the start button when the start LED flashes.
5. Failure indication
6. Repair the failure
7. Solve the failure by pushing the start button for longer than 3 sec.
8. Start the passive test program again. If there is no failure detected, test all LED's and after that choose program 1.
9. Finish the passive test program by pushing the start button for shorter than 3 sec.
Thank's to your description of failure I will check all hydroulic inlet water circuit and electrical component in "inlet water" phase (electrical valve, flow meter (if exist), OWI, VWI, wiring, CB...etc)
Dado
May 30, 2015 | Whirlpool Dishwashers
What's your question?I have washing matching hotpoint Aquarius wf360 with erorr code F-01
Motor triac problem. The triac would be in the unit that controls the motor speed.
May 04, 2015 | Hotpoint Washing Machines
Hotpoint aquarius program won't start
Try this. Unplug unit. While unplugged, hold in power button for about 10 seconds. Release plug back in. See if that has reset the control module. Works on some other makes. Can't hurt to try.
Mar 10, 2015 | Hotpoint WML540P 60cm Washer Front...
Hotpoint WF360 Stuck on test
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 02, 2009 | Washing Machines
Test on display cant use washer
turn the machine on while you press the start and on buttons at the same time until dOFF appears.
Dec 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint wf860
the applionce is in demmo mode and running a test cycle so you need to cancle the cycle first by holding the start reset button until all the screen iluminates(88:88) now you need to disable the demo mode by holding the start cancle and the on off buttons together until you see D OFF in some cases you may need to hold the button to the top left of the screen and the start and on off buttons but this will sort it
Feb 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error message
Hotpoint’s are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see ‘D:end’ (or similar message)."
Nov 03, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarious wf620
funny my machine does the same, i have had 2 answers one says to hold both the on off button and start button till it comes out of test mode? well something like that, (didn't work) and another tells me its just the board thats faulty, I do believe myself this can be reset by the right test equipment from Hotpoint (Hotpoint not helpful and i have a Hotpoint engineer as a neighbour), its also most embarrassing as i am a recently retired appliance engineer myself of 20 years, i have also been told its a conspiracy to get an engineer to call out to reset it and charge for doing so (being a computer control machine (not sure myself, these things don't happen - do they) Ps if you get told a cure and it works tell me please
Sep 18, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD645
If you by accident press the start button and the cancel button at the same time it puts the washer into demo mode.To switch it off press both buttons at the same time and hold until dEND is displayed. Sometimes you have to keep trying but it will work, it did with mine ok.
Sep 09, 2006 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
156 people viewed this question
Top Washing Machines Experts
