Question about Hitachi Televison & Video
We have a new model LE29H306 or LE29HE16 television, which has suddenly stopped working. We changed the channel from one HD station to another and the television went black. When we checked the setu
We are connected to a motorola DVR which also is our cable box.
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Posted on Mar 10, 2008
SOURCE: Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
Posted on May 30, 2008
SOURCE: No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Posted on Jan 06, 2009
SOURCE: Dynex 32" 720 LCD HDTV - no channel listing after run auto scan?
Excuse me but the other answers are written by people who have not actually confronted the problem and are just guessing. They are all wrong. Here's the answer:
If your TV is expecting a TV input, it will keep searching for at least one TV channel on cable or antenna. If you only have a DVD player plugged in, for example, or if your cable is hooked up wrong, so there's no video signal on it, the TV will keep searching forever. (This is an unforgivable design flaw, by the way. But then, it was a cheap TV, wasn't it?)
To solve the problem, look at your remote control. You will find input buttons. Mine are small, along the top, right under the "power" button. Try pressing "video" for example, instead of TV. That stops the TV from hunting for TV channels.
Have a merry Christmas. Enjoy your new TV. Watch it in moderation and eat fruit and vegetables every day.
Posted on Dec 25, 2009
dandre10
  • 63 Answers
SOURCE: How do you connect a Nintendo 64 game station with
connect the AV cable to the red white and yellow input outlets on the tv and press input on your remote you have to be on video 1, 2, or 3 to play the nintendo 64
Posted on Jan 05, 2010
Antenna not working anymore?
talk with a tv technician as to the capabilities of the tv set but you may need a better outdoor antenna if the signal has changed from am to digital or fm in your viewing area
Jan 20, 2016 | Westinghouse Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
TV is working beautifully then the screen goes dark for 3-15 seconds and then the image reappears in beautiful HD. The TV is two years old and otherwise works perfectly
Technology changes at a high rate of speed, as we all know. And High Definition (HD) has come a long way in a very short period. Since your television still works perfectly otherwise, I don't think that it's a problem with the set itself. It may only be a victim of technology.
Does this only happen with High Def channels? Does it happen every time you change to another HD channel? If you answer 'yes' to either of these, it is most likely due to the television's processing capabilities. Because of the high amount of data that is required to deliver HD content, manufacturers have found creative (but not necessarily convenient) ways of dealing with the processing issues (blank screen delay for example). Since the audio and video signals for any given television station (either HD or regular) are transmitted separately, the television has to process that data internally so that you get the picture and sound aligned properly when you are watching it. HD broadcasts are much more demanding than regular stations requiring manufacturers to constantly improve this processing speed with every new model. On some televisions, the channel remains blank for a few seconds to allow the television to configure all of the information so it looks good when it's ready, which could explain the delay you are describing. At the time your television was manufactured, this may have been the best technology your manufacturer had to offer. On my personal flat panel, I get the picture and sound right away, but I have to wait about 15 seconds for the sound to catch up to the picture which I think is more annoying than being forced to look at a blank screen. But that's just me.
Hope this information was helpful.
Mar 19, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
Radio tuner stopped working
replace Bad Circuit Dsp Pcb the rca part number is #265973
Jan 13, 2009 | RCA RTD258 System
Can not get hd channels on my new tv..
First of all, digital/HD signals are broadcast at UHF frequencies. You need to know if you have an UHF antenna and, if you do, that it is pointed to the TV stations broadcasting HD.
Second, since most TV's have a setup mode that automatically searches for channels that are able to be received, go to that "Setup" menu on your TV and start the auto search. It will list both analog and digital stations. Note that the analog channel may be, for instance, Channel 39 but the digital channel will be Channel 39-1. Tune to the "dash 1" channel.
Dec 30, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Samsung HP-S4253 black screen, with sound
Its the broadcasting company and there "new technology" Have had an over the air box to get local HD channels and lost my PBS station, turned out to be a new signal incompatibility. The same is with my HP-S4253. Must not have the latest SW to process the new signals
Feb 19, 2008 | Samsung HP-S4253 Television
Can't advance channels with remote
Hey Guys and Gals I have the solution to your problem. Your channel memory on the remote has been forgotten. Simply navigate through your menu on the remote and rediscover the channels and your issue should be solved. I had the same issue it just took me a little time to figure it out.
BTW if you are hooking up your TV with a direct cable connection in the back without a box, and you go to the menu and do a search for air/cable channels it will even find the channels in between the regular broadcast stations (i.e. between 2 and 3 there is 2.1. which is channel 2 HD and so on for the regular stations that broadcast HD channels). Cheers and good luck the Sharp Aquos is an awesome TV!
Regards,
Jeff the Sofa King :)
Feb 05, 2008 | Televison & Video
Televison & Video Logo
169 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
