Graphic card or Power supply?
I have an asrock alivenf6p-vsta M/B it has a generic 400w power supply. My problem is the onboard graphics can power my 22" screen at high resolution,full hardware acceleration but when I added an x1950xt I had to lower the resolution and halve the hardware acceleration just to get it to boot and 10 minutes into a game the screen goes blank but I sometimes hear the game still going. I've tried Ati's and Omega drivers. thanks
    Genius:
  • 1,061 Answers
I BELIEVE ITS THE DRIVERS.UNINSTALL ALL VIDEO DRIVERS AND INSTALL LATEST DRIVER FROM GRAPHICS CARD WEB SITE.GO INTO THE BIOS AND TURN OFF ONBOARD GRAPHICS.SHOULD BE FINE..ALSO MAKE SURE YOU HAVE CORRECT DRIVERS FOR YOUR OS.ALSO UPDATE DIRECTX.RECHECK GRAPHICS CARD CONFIG AFTER NEW INSTALL.RICHARDM69
Posted on Jan 02, 2009
What graphics cards can i use with it
Hello here is the homepage:
http://www.asrock.com/mb/overview.asp?cat=Download&Model=ALiveNF4G-DVI
The mainboard has 1 x PCI Express x16 slot, for the graphic card.
Almost all new graphic cards, has this socket type.
The old type is AGP, but it does not fit this mainboard.
I recommed to use ATI/AMD HD series.
A big graphic card also needs, a bigger power supply.
At least 500 watts.
Good luck
Feb 05, 2013 | Nvidia Asrock Alivenf4g-dvi Socket Am2...
No VGA output
Hello the drivers site is here:
http://www.asrock.com/mb/overview.asp?cat=Download&Model=G41M-VS3
The manual:
http://www.asrock.com/mb/overview.asp?cat=Manual&Model=G41M-VS3
I think you should drop the onboard graphic and install a better graphic card in the 1 x PCI Express x16 slot on the mainboard.
Check the power supply for any fault.Is it new ???
You can not use the old Power supply because it might have a 20 pin connector this asrock has a 24 pin connector.
Check also you not have used the extenal graphic power connector in the 4 pin 12 + volt on the mainboard.
Check also all your power connections.
Reply me again if you can`t find the fault.
Good luck
Nov 28, 2012 | Asrock G41MVS3 Motherboard
Modelo: ALiveNF6P-VSTA Problema: MAC address are invalid in both CMOS and Flash!
The onboard LAN chip has been fried. Disable it from the BIOS and install a separate PCI LAN card.
Feb 13, 2011 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Running windows 7 64-bit OS on asrock AM2NF3-VSTA motherboard. The graphics card is not being recognised or it hasn't got one, which would I need to make the system better.
the graphic card possibly not recognized cause its 64-bit OS try the window 7 ultimate.. or update the graphic card by manual..
my computer->device manager -> then right click the graphic card which has a question mark (?)
then right click and update it with your cd installer..
Oct 22, 2010 | Asrock AM2NF3-VSTA (4711140874470)...
Want to know that "ASRock G31M-S" is compatable with Nvidia 9500
Your new card maybe faulty or you might need a larger Power Supply Unit (PSU),, if its just started to happen...
Jul 30, 2010 | Asrock G31M-S Motherboard
Asrock alivenf6p-vsta socket am2 m/board just build my pc from new everythiong work but the monitor wont come but it works on my other pc can you help
do you have onboard video as well and a video card in?
if so place the cord into the onboard and see if it fires up properly
if so then refer to your bios to turn it off and use your video card for the video and then it should work fine.
Aug 01, 2008 | Computers & Internet
My laptop keeps shutting down for no reason
asrock alivenf6p-vsta socket am2 m/board i just built a new pc but monitor wont come on it has power but no picture can you help[
Automatic Switching off of monitor
Have you tried your card on another machine? One thing i have seen in several forums (though i have not come across it personally) is that if you run your VGA card with a PSU thats not powerful enough, the PSU may get busted but usually the graphic card due to being stressed running underpowered fails. Hence the reason why i inquired if you had tested your graphic card on another machine to see if the same symptoms occur.
If it does not happen you can then know its a problem related to the power supply, as the power supply capacitors too degrade over time, and hence they might not be giving the same power as before. Dell power supply units have been known to work well beyond there stated wattage compared to the generic systems (Some case dell 250W unit seems to run better than generic 400W units).
Dec 05, 2007 | ASUS EN7800GTX GeForce 7800 GTX, (256 MB)...
ASRock K7S41 no boot screen at all
Try plugging the monitor to the onboard video card and then enable the graphic card in cmos settings.
Dec 10, 2006 | Asrock K7S41 Motherboard
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
