Question about Whirlpool LER5636P Electric Dryer
Dryer not working well
Dryer takes longer to dry than in past. bottom one-half of coils not on. Bad switch? Bad coils?
    Sergeant:
  • 311 Answers
Wp only as one coil if hot then its working.99 out of 100 will be house venting.dry load with out vent[you wont hurt a thing]if still bad the air out put should be strong ,you may need to clean out all dryer air ways.you can do it .God bless tom
Posted on Jan 02, 2009
The drying cycle on my dishwasher is no longer working.
The dryer uses the coil in the bottom of the tub to heat up the air in the tub and speed drying time. The coil is like the same item that is used in a stove. The issue could be that coil is burned out. The easiest way to check that is to get a meter that measures ohms. Take the dishwasher out of the counter installation and make sure it is drained. Lay it on its side and look for the connections on the bottom that have wires going to the coil. Test the resistance on the coil using the meter.
Mar 10, 2015 | Siemens 24 in. SL84A305UC Built-in...
Gew9868kq0 not drying
Hi it could be that one of your heater element coils blown or a faulty thermostat
May 28, 2012 | Whirlpool GEW9868K Electric Dryer
My dryer is not drying my clothes completely. I have to set it to time dry for at least 120 minutes to get a load of clothes to dry. I can feel that the dry is warm .I usually dry my clothes on optimum dry...
Your dryer has a double set of heating elements
1 side of the coils is probably broken and you are getting half the heat.
This is making the dryer take longer to dry them clothes.
Air restrictions in the dryer and vent can cause the heater control to shut down quickly also.
If you have a bad breaker the power will sometimes work and sometimes not.
If all of these are good you might have a problem with the timer.
Most of the GE timers have leaf switches in the that get a burr on the contacts. The come apart simple enough.
I have more HERE
Apr 01, 2011 | GE DWSR463EGWW Electric Dryer
GE DSXH43EAWW dryer stopped working mid cycle
unplug it,take it apart and check it out,you could have snapped the belt,there's a belt switch so if the belt breaks the dryer won't start,or if you haven't taken the dryer apart and cleaned it out and also the vent line you could have popped one of the t-stats,only way to tell is by checking them with a meter.the dyer should be cleaned out once a year ,if not the air can't move freely and one of the t-stats will pop as a safety,the dryer will run to hot and take out the thermal fuse or the high limit t-stat,if it's been taking longer to dry the clothes or if you see lint stuck to the bottom of the dryer door these are signs of bad air movement and the dryer and vent line needs to be cleaned out.
Dec 30, 2017 | GE DSXH43EAWW Electric Dryer
It take 4 cycle to v dry towels or jeans then
Remove all air restrictions and clean out the lint chute. I am supposing you have already done so. Since it does heat a little I am thinking the ignitor flame sensor and fuse are all good. So that leaves these operating coils.7942d84.jpg With a little age they get iffy. Feel the coils if one of them is very hot that is the bad one. In rare cases this flame detectoref9f9ec.jpg will work and then take fifty forevers to work again. The bi-metal gets brittle and takes longer than the norm to cool down and close for ignitor operation.
Lets review: The power comes from the closed control689f826.jpg and limit.fdc9a7a.jpg
the ignitor hogs all the juice and gets screaming hot till the flame detect opens and kills power to the ignitor. This frees up juice for those pesky inter-mittant coils to energize. Any of the above componets are wank and she don't dry right.ffc3f7f.jpg
Dec 18, 2009 | Estate TGDX640JQ Gas Dryer
It runs but no there is no hot air
the first thing you want to make sure is that the igniter is working, remove the orfice on the front of the dryer, an start the dryer cycle, it should glow if it doesn't then you have a bad igniter, if the igniter glows an you have no heat (at all) you want to check the thermalfuse onthe dryer, check for continuity with a voltage tester it it beeps means is ok , if it doesn't pass current replace it,
if you get partial heat only then it would look into the coils, the 2 coils are inside on the front of the unit. coils are replace for the most when your dryer takes a longer cycle meaning it takes longer to dry or finishes an clothing still damp.
good luck.
May 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Only half of the heating element works
i looked up your model andfound it to need part number 3401338, this is the heater, i cannot see howe only 1/2 of the coil is going to light, its either on and all lights or its gone bad in which case its never gonna glow, its one filament like a lightbulb as long as the filament is good its alll good. too long to dry or extendedd dry times is most likely an issue with a blocked/clogged vent hose
Dec 09, 2008 | Whirlpool Dryers
Hi, My Indesit WIDL 102 is faulty. It washes OK, But does not dry at all. I dont think it heats up during the drying time, but the drum does turn round. Is there a thermal reset switch on the inside...
I don't know your dryer model, but I assume it is electric. Electric dryers have a heater coil like a toaster which eventually wears out and doesn't get hot anymore. This is typical and is likely the case especially if your dryer is old or has been used alot. Has the dryer been taking longer and longer to dry before it lost all heat? If so, I bet it is the heater coil.
Feb 28, 2008 | Dryers
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
