Question about Maytag Dryers
I have a Maytag LDG412 Gas dryer. The flame will light the first time but when is cycles the ignitor will glow but the gas valve does not open so it does not re-light.
  • 1028 Answers
SOURCE: dryer does not dry
change both coils on gas valve(the round black dohickys with wires attached)
Posted on Jul 05, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Posted on Sep 12, 2008
  • 36 Answers
SOURCE: Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Posted on Jan 02, 2009
  • 77 Answers
SOURCE: maytag gas dryer, no heat, ignitor wont glow
The machine will check all safety features first. check the overlimit by the burner. It may have a reset. If not, turn power off and check continuity (ohms). Good luck.
Posted on Apr 18, 2009
SOURCE: glow ignitor works, but no flame ignites. ohmed out gas valve coil with wires disconnected = OL is it my coil?
You have a bad flame sensor. Replace it.
Posted on Sep 18, 2009
I have a Maytag MGD5800TW Gas Dryer. It does not heat up. What should I check?
First, Remove small plastic tab on front panel of dryer lower left corner. Start the dryer on regular cycle and observe what happens through hole. You need to know if ignitor glows orange. If you do not see the ignitor glow orange, replace the ignitor. If seeing full orange of the ignitor, do you hear a clicking and see the flame light?
Leave the dryer cycling while observing. When the dryer heats to temperature the flame will shut off. If the gas valve coils are bad the next thing to happen will be that the ignitor will glow orange again, the valve will click again but the flame won't light.
If the gas valve coils prove bad, based on the observations above, follow the procedure below to replace the coils. If NOT, come back with the results of your observations.
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Remove lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right. Gas components will be on left. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
Reverse process to re-assemble.
Sep 20, 2009 | Maytag Dryers
The glow plug just lights up but no flame on my maytag mdg 5500aww
If the ignitor is glowing but the gas does not light check the flame sensor. If it is OK then the gas valve coils may have to be replaced.
Aug 12, 2009 | Dryers
Lights once then not again
Hot Surface ('Glow Bar') Ignition System glow-amin.60x20.gif (most common)
This is the most popular system currently in use and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve. What happens in this style control system is that the thermostat or electronic control supplies power to the oven ignitor and gas valve which are connected in series (one after the other). As power flows through the ignitor it heats and allows a specific amount of current to flow to the oven valve which is in the same circuit. If the oven valve senses the proper current flow, it opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it.
Jul 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag model # mdg6000bww doesn't heat up?
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Jul 18, 2009 | Maytag MDG2600BWW Gas Dryer
Gas keeps shuting down and not heating the air
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then it or the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.  If the gas ignites but the cycle stops and repeats quickly the lint filter, exhaust vent or outlet may be clogged.
Jun 03, 2009 | Maytag Dryers
Maytag gas dryer runs but does not heat
If yo smelled gas then the ignitor may not be working.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 30, 2009 | Maytag MDG2600BWW Gas Dryer
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Dryer does not heat up
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dec 13, 2008 | Maytag Dryers
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
