Question about True TBB-4G Commercial Refrigerator
My True TBB-4G cooler keeps filling with water.
True TBB-4G is filling with water inside of the storage area. So much that it must be vacumed out or it spills out of the front doors. The bottles on the bottom freeze to the cooler. The cooler is staying perfectly cold, just fills with water?
  • 10 Answers
SOURCE: I have a True GDM-26. The contents get cool
I have same problem was told condensing fan not working properly. Easy to see if this is the problem, take out guard in front of machine and put a fan blowing into it. I went to home depot and bought a tornado fan and it cools again. Now if I can only figure out if its the fan or whatever contros its speed. If anyone knows how to check please respond.
Posted on Apr 17, 2010
  • 1230 Answers
SOURCE: my true back bar cooler dosent cool it is not iceing over
If you can gain access to the compressor, you will see 2 copper lines going to the compressor. One is smaller than the other. VERY CAREFULLY lightly touch the smaller line while the unit is running. If the compressor is running, that line will be extremely hot.
Start there.
Let me know if I can be of further help.
Posted on Jun 29, 2010
  • 112 Answers
SOURCE: how do i adjust the temperature in a True TBB-4G?
If memory serves it is in the middle of the back left corner inside of the unit. Should be numbered 1-9 Generally 3 - 5 is correct setting. Higher the number colder the box. Most of my customers have theirs set on 5.
Posted on Dec 12, 2010
richroth
  • 9472 Answers
SOURCE: I have a TRUE T-SERIES
Condensers accumulate dirt and require cleaning every 30 days. Dirty condensers result in compressor failure, and condensation buildup. Also, check your door seals to make sure that they are sealing correctly. Good air flow in your True unit is critical. Be careful to load product so that it neither presses against the back wall, nor comes within four inches of the evaporator housing. Refrigerated air off the coil must circulate down the back wall.
Take a look at page 18 of this document.
Make sure the drain tube heater assembly is clear and working!
Drain Tube Heater A. Lower the evaporator cover. Disconnect the drain tube heater by removing the wire nuts at the point where the heater joins the electrical circuit of the freezer in the evaporator compartment. Check the drain tube heater with an ohmmeter. B. If the drain tube heater is defective, disconnect the drain tube from the rigid plastic drain, bend the tabs that hold the evaporator drain pan to the evaporator cover and raise the drain pan so that the flexible heater is visible, pull heater out of the plastic drain tube and replace. Connect heater to the electrical circuit in the evaporator compartment.
Posted on Jul 22, 2011
  • 157 Answers
SOURCE: We have a true upright,
Check your evaporator drain pan and the outlet for the condensate water, and make sure the drain tubing is clear. That water is supposed to drain outside the box.
Posted on Aug 30, 2011
How do you remove the evaporator cover on a Tbb-2 cooler?
PDF]True Manufacturing Company, Inc. - Fixitshop.com
https://fixitshop.com/manuals/TECHNI~1.PDF
Top Removal for TBB and TDD ... Top Removal for Various Coolers - TSSU, TWT, TUC ... End Cap Replacement-T-Series Swing Door ... GDM 2 Door Cooler IDL Light Diagnosis ... If you keep the Condenser clean you will minimize service ...
[PDF]installation - True Manufacturing
https://www.truemfg.com/assets/...Website/TDB_TBB.../tbb_english.pdf
Your TRUE cooler when properly maintained will give you many years of trouble-free service. TO LOCATE REFRIGERANT ..... Removing bracket from skid. Removingbracket from cabinet. 1. 2 .... tab holding the door cord slides out the back. ... The switch is located on the front of the evaporator housing toward the front of .
Nov 08, 2015 | True TBB-2G-S Stainless Steel Beverage...
TRUE TBB-2G Cooler is leaking water from the fan
I would guess the water is dripping from an ice ball or buildup in the coil either from an inlet side of the coil blocked by an accumulation of dirt and dust or paper or such. Second, if you leave the door open for lengths of time ice will build up, also an over heated over loaded condenser will cause ice buildup. In any case if you shut it down, let the ice melt, clean the coil, keep the door closed as much as possible and if its hot where its sitting let it have some air it should improve. Last thought, if there is a refrigerant leak in the system ice will accumulate at the end of the coil, the compressor will stay on longer than normal and this water drip is letting you know a service call is coming soon. Hope this helps and good luck.
Aug 12, 2014 | True TBB-2G Commercial Refrigerator
We have a true upright, glass front beer cooler. TBB-4-G refrigerated back bar. The bottles and cans right in the middle are icing up and forming huge blocks of ice. we have turned up the thermostat,...
Aug 30, 2011 | True TD-95-38-LT Beverage Cooler
I have a quarter inch of water in the bottom of my cooler.
check out the drain system in the very bad of the unit (inside). When obstructed it can cause the water to puddle inside the bottom. The hose is short, you can use caned air or a straw to clear this out. Don't use anything metal or sharp, you don't what to poke a hole in the tube.
Good Luck
Aug 22, 2011 | True TBB-2G-S Stainless Steel Beverage...
I have a fairly new True tbb-2gs which is on a dedicated 120V/15A circuit...has had problems in past with condenser cycling. That problem went away after unplugging and replugging the cooler back into the...
You have to verify that the compressor is running. Don't assume that it is just because the fan is running. the compressor may not be running. If compressor is running, good possibility that it is low on refrigerant. Most common and obvious.
Aug 18, 2017 | True TBB-2G-S Stainless Steel Beverage...
Ice build up and leakage in unit
The condensate drain line is clogged. Defrost it by pouring warm water and baking soda down the tube located bottom of pan under blower. Repeat until water flows easily
Apr 30, 2011 | True TBB-2G-S Stainless Steel Beverage...
My true back bar cooler dosent cool it is not iceing over
Start there.
May 27, 2010 | True TD-65-24 Commercial Refrigerator
How do i adjust the temperature in a True TBB-4G? It's too cold. Where is the thermostat?
Aug 13, 2009 | True TBB-4G Commercial Refrigerator
True TBB-24GAL 48" wide unit turns on and shuts down real loud
THE COMPRESSOR IS DAMAGED INTERNAL JUST USE TLL IT DIES OR REPLACE NOW IT PROBABLY HAD A 5 YR WARRANTY ON COMPRESSOR
Jun 18, 2009 | True TBB-24GAL-60 Stainless Steel Beverage...
True TBB-2 Cooler issue
BY to I take it yu mean top area inside cooler. If that is the case and yu are sure the drain is clear it could possibly be one of the following.
1: rusted/ corrodid evaporator drain pan
2: coil in cooler partially frozen
Jun 28, 2008 | True TBB-2 Beverage Cooler
True TBB-4G Commercial Refrigerator Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
