Question about Boss AUDIO SYSTEMS BV9455 Car DVD Player
Vedio my dvd has sound but shoes onthing on screen
You need to ground the brake marked wire
Posted on Mar 12, 2009
I lost my sound mixer on my screen how to restore
  1. Right click on the taskbar
  2. Select Properties
  3. Click the Customize... button under Notification area
  4. Click on Turn system icons on or off
  5. Make sure Volume Behaviors is On
  6. The volume mixer should be present in the notification area now
Sep 22, 2011 | Computers & Internet
Volume on tv adjusts automaticly
is the volume of your tv adjust automatic with a volume indicator on the screen appear?if that the case clean the volume controls on the mainboard with a contact cleaner..2nd is is the volume adjust with no volume indicator on the screen?your problem might be onthe sound if section.adjust the sound IF with a plastic screwdriver clockwise or counter clockwise until the soun stabilises..adjust the IF with a power is on.
May 17, 2010 | Televison & Video
Tv takes a while to get a pic, the sound comes on immediatel
YOUR TV HAS A SMALL PROBLEM,
TAKE IT TO W/SHOP, AND LET THEM CHECK THE FOLLOWING,
LINE TRANSFORMER,
LINE TRANSISTOR, AFTER CUTOFF.
CAPACITORS- ESPECIALLY ELECTROLITIC the wax-oil at times drys up, hence it changes capacitance
DONT FORGET ZENER DIODES, for stability of output voltages
Apr 16, 2009 | Sony Televison & Video
Screen blank when tryin to play game I cant see anything i get sound but no picture onthe screens
your battery might be low try charging your nintendo ds if this dose not work try going to a local game stop and get it looked at but they will most likely say you need to change your battery pack. hope this helps
your friend,
cutECAT333
Feb 21, 2009 | Nintendo DS Lite Console
Eror e6100 flashing
error is generic hardware error. normally some part of the infrared or display has malfunctioned.
Feb 02, 2009 | Sony Cyber-Shot DSC-P71 Digital Camera
Driver side rear brake locks up when it is wet or rainy out.
the drivers side rear brake shoes may be adjusted to tightly, so that immedatly when you step on the pedal, it locks up. try adjusting them in a bit first. Also, make sure that the wheel cyliner is the correct one, and it is not to big. i have not ever seen a proportioning valve problem on a cavalier.
Dec 12, 2008 | 2001 Chevrolet Cavalier
I TURN MY CAMERO ON. IT TURNS ON BT ONTHE SCREEN ALL I SEE IS
Sounds like a bad microchip on the camera system board. Replace the system board.
Nov 12, 2008 | Pentax Optio 60 Digital Camera
Accelevision 9520
you need to go to am fm, change from tuner to Aux, thats how it works in my limo
Mar 17, 2008 | Accele DVD9520
Picture is black and white and horizonal is running
there is a ntsc/pal botton on your remote press that and it sould go back to normal if its not onthe remote try to go in the settings and it will ce in there someware
Dec 26, 2007 | GoVideo R6640 DVD Recorder
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Boss AUDIO SYSTEMS BV9455 Car DVD Player Logo
87 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
