Question about Whirlpool Microwave Ovens
How many cubic feet is my MH6150XHQ - 1 Microwave?
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave timer counts down but doesn't turn on when started
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so with a one-year guarantee.
Posted on Aug 30, 2009
SOURCE: we have an mh6150xhq-1 microwave. It rotates, the
In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one
Posted on Jan 27, 2010
  • 8909 Answers
SOURCE: When I open the door of my microwave oven
You may have a faulty door interlock switch. Check the switches.
Posted on Jan 01, 2011
  • 3 Answers
SOURCE: I have a Hamilton Beach
Assuming its the same as my Hamilton Beach, you first enter the cooking time, but don't press start yet, instead press power, then a number button 1 - 9 for the power level 1 for 10%, 2 for 20% etc. THEN press start as normal
Posted on Jan 08, 2011
woobie dog
  • 1273 Answers
SOURCE: We have the GE JVM130H
Hi, W/D here.
Here's an easy way to calculate your cubic feet: measure and multiply (in inches) the width X depth X height, then divide by 1728. This will give you cubic feet.
For example, if a microwave measured 18" wide X 18" deep X 12" high, it would be 3888 cubic inches; divided by 1728 (cubic inches in one cubic foot) = 2.25 cu.ft.
Best regards, --W/D--
Please take a moment to rate this solution. Thanks. --W/D--
Posted on Mar 19, 2011
What is cubic feet is MW1030WA microwave oven
1.1 cubic feet.
You can find the cubic footage of a microwave by measuring (in feet) the length x width x height of the inside of the cooking cavity.
If you have other questions, please feel free to contact me directly (see below). . - William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 19, 2017 | Microwave Ovens
What is the cubic feet
cubic feet is the measure of volume. one cubic foot is 1x1x1 foot. the size of the microwave varies with MAKE and MODEL. but is normally in the range of 1 to 3 cubic feet
Oct 25, 2015 | Microwave Ovens
I'm trying to convert a over the range frigidaire microwave that is 30" by 15.5" by 15" into cubic feet.
generally speaking you buy and OTR microwave by width, i.e., 30" wide is the standard width of all most all OTR . so any 30' wide microwave will fit. when talking about cubic feet, they usually are talking about the interior capacity of the microwave. but if you really want to know cubic feet of above dimensions, then multiply all three together and divide by 1728. (4.036 cuft)
Aug 29, 2015 | Frigidaire Microwave Ovens
15x14x9=how many cubic feet?
Square feet is calculated L x W so 10x10 would be 100 sq. feet, Cubic feet is calculated by L x W x H so 15 x 14 x 9 = 1890 cubic feet
Feb 22, 2015 | Microwave Ovens
WHAT IS THE CUBIC FEET OF JVM1339WB-002 GE MICROWAVE SPACE SAVER?
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple.
Follow these steps.
Open the door of your microwave and measure the length, width and height in inches of the interior cavity.
Multiply the length by the width by the height using a calculator to get the total in cubic inches.
Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters
Hope that helps
Sep 12, 2014 | General Electric Microwave Ovens
Convert cubic inches to cubic feet
Since there are 12 inches in a foot, there are 12x12x12 or 1728 cubic inches in a cubic foot.
Dividing 1404.4921 by 1728 gives about 0.8128 cubic feet.
Mar 16, 2014 | Microwave Ovens
What is cubic square feet
Cubic square feet is determined by multiplying length (depth) X width
X height. Example= 2X2X2 = 8 cubic feet. A typical countertop microwave is going to be 1.1 to 1.6 cubic feet of oven capacity.
Feb 15, 2014 | Hotpoint RVM1435 Microwave Oven
We have the GE JVM130H 001 microwave. I am trying to figure out what is the cubic feet capacity of this microwave. Can anyone tell me?
Hi, W/D here.
Mar 19, 2011 | Microwave Ovens
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Jun 03, 2008 | GE JE1540 Microwave Oven
Microwave Ovens Logo
517 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
