Question about Lanier 1205 Copier
HOW TO CHANGE TONER IN A LANIER LD335 COPIER?
SOURCE: Lanier 6735 Copier
Sounds like you need a new cleaning blade. It is located inside the process assy behind the drum.
Posted on Aug 10, 2007
SOURCE: lanier copier ld145 locked up, code is
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
Posted on Jul 29, 2009
cartridgecon
SOURCE: How do I reolace the toner in a lanier 7313
It was very easy. I just had not seen the machine when I posted the question. Thanks
Posted on Jan 09, 2010
  • 903 Answers
SOURCE: How do i empty a waste toner bottle on a lanier
What kind of copier is it? On many of the Lanier color copiers, the waste toner bottle is located on the lower left side inside the front door.
Turn the copier off first. Pull the big front door open and turn the bottle with the oil to the left -- the waste toner bottle is the plastic gray tank behind that. Slide it out (carefully) and dump it in a plastic trash bag, then reinsert it.
If you have a different kind of copier, please specify the model and I'll tell you how to get to the waste toner bottle.
Posted on Jul 18, 2010
santosj27
  • 263 Answers
SOURCE: I have a lanier ld122 copier/fax. It told me to
First of all check if the doors are well closed.
If everything is well closed you can have several problems:
1º Toner supply defective.
2º TD sensor defective
3º Development unit defective.
If you don't have technical training i advise you to call the provider.
Posted on Feb 28, 2011
Sc502 code number 2 tray error
Paper problem or lift problem in tray 2, remove and reload paper, cycle power. -Carl
Jan 09, 2015 | Lanier Ld345 Ld335 Copier Priter & Scanner...
How to reset fuser error code on lanier ld235?
Come into test mode, if it comes back the fuser service needed. -Carl
Oct 06, 2014 | Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper...
How can I clear the Lanier 6112 "used toner" on the display?
Open the front door, lift the clam shell open and carefully replace or empty the white used toner container. Replace and turn the blue knob clockwise a few times.
Aug 03, 2014 | Lanier Compatible Copier Toner Black For...
How to replace used toner bottle on an LD245 and where is it located on the machine?
No bottle, it is inside the transfer belt unit that hangs on the inside of the right hand door. Dump it and put it back.
Jun 24, 2014 | Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper...
Are there availability issues for parts for the Savin 8035? We have one in our office which is under a service agreement and have been told it will be 2 weeks for a part. Is that realistic? We're being...
Try going through the Ricoh website, the product code is B291. The Savin 8035e is the same as Ricoh Aficio MP 3500, Lanier LD335 and Gestetner DSm735e. Hope this helps
Jul 18, 2011 | Savin 8035e Copier
How do i empty a waste toner bottle on a lanier color copier
Feb 25, 2010 | Lanier 1205 Copier
How do I reolace the toner in a lanier 7313 copier.
Jan 07, 2010 | Lanier 1205 Copier
I have a lanier lp-138c that is giving me a black toner low message on brand new cartridges... Tried 3 different cartridges and at first they register and then to the toner low...
It could be that the black developer unit is clogged. The toner low sensor is located in the black developer unit. A trained copier tech may be needed to troubleshoot this.
Apr 14, 2009 | Lanier Office Equipment & Supplies
Lanier 6735 Copier
Aug 10, 2007 | Lanier 1205 Copier
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
