Question about Swingline ® LightTouch Heavy-Duty Stapler, 120 Sheet Capacity, Black/Gray
How to unjam the swingline 90002 heavyduty stapler
I cannot unhinge the end where staples are to be inserted, nor unhinge at the front where the arrows indicate to open and to close.
SOURCE: instructions on how to load a swingline heavy duty
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
Posted on Aug 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: instructions on a swingline stapler electric model
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 07, 2010
  • 10 Answers
SOURCE: We have a swingline model
1. Make sure you have the correct staples for the machine. The type appears to be:
Swingline 50050 Cartridge Staples, Chisel Point, 1/2"" Crown, 3/16"" Leg, 5000 Per Box High-quality Swingline cartridge
2. Check the cartridge to make sure there are no visible jams.
3. Contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
Posted on May 04, 2011
SOURCE: We have a Swingline 690
I had the same problem with my 690. This is what worked for me.. I simply pulled out the staples from the cartridge a little further than the suggested tear-off point, and the machine was able to start working. Hope this helps!
Posted on May 10, 2011
johnedpatton
SOURCE: What does it mean when a red light if flashing on
Time to change the batteries
Posted on Sep 23, 2011
How do I reload staplers?
There are two basic designs of staplers. The most common type is the Swingline or Stanley Bowstitch types. At the business end of the stapler there is a small catch that you need to pull rearward and the front staple head will drop down. Inside, you will see a metal bar and a spring. Pull the spring back towards the rear of the stapler and insert a full clip of staples appropriate for your stapler. Release the spring slowly so the metal tab pushes against the staples... should be pointed tips down. Put the stapler on a firm surface and press it as you would when stapling something. The two parts of the stapler head will join back together again.
Apr 02, 2015 | Office Equipment & Supplies
Swingline Optima 45 Stapler - cannot slide tray back in stapler, no staples jamming
Sometimes the rectangular insert where the staples sit on, gets dislodged. On the underside of channel insert is a spring and when correctly seated is in between the tabs of the bottom piece. If the insert isn't in between the tabs, it sits too high and makes it difficult to open and close the staple tray. The staples will jam.
Jun 13, 2014 | Swingline Optima Electric Stapler 45 Sheet...
My staples are stapling backwards.
Take your staples out of your stapler and reinsert new ones.
Try that and see if it makes any difference.
May 07, 2014 | Swingline 74729 747 Business Full Strip...
900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Mar 27, 2013 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
Just bought and tried to load my Swingline Smart Touch low force stapler. Don't know how to get it opened
I have one of these models. Just push the gray lock mechanism at the end of the stapler and the loading magazine will pop out. The chrome plated magazine opens towrds the front....it slides forward and backwards.
Jun 17, 2011 | Office Equipment & Supplies
The back plastic part of my stapler the one the pushes the staples in need to be replace (light green color) the rest is black Model #90002
Hello. The stapler is manufactured by Swingline. Here is the link to their contact page.
http://www.acco.com/contactus.aspx
If this helps, please rank it a four-thumbs up. Thank You.
Mar 28, 2011 | Measuring Tools & Sensors
An office dummy put regular staples in the Swingline 660HD stapler which is now jammed. I can't figure out how to open the stapler to get access to the staple tray. I can't pull them out with a large...
There's a rectangular opening at the front end of the stapler. You can insert a rod that fits in the opening, and push the staples back out if they're not hopelessly jammed in-place.
Feb 04, 2011 | Office Equipment & Supplies
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Swingline ® LightTouch Heavy-Duty Stapler, 120 Sheet Capacity, Black/Gray Logo
180 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Andrew Taylor
Andrew Taylor
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
