Question about Kenwood Food Mixers
How can i remove the planetory hub from my kenwood chef a701a, I've taken the nut off and removed the top of the machine but can't find how to remove the hub?
There was a crack as I used the mixer and the beater dropped out of the shaft along with, what I believe is the nylon gear which had broken into 3. I have since identified that I might need to replace the planetory hub or maybe just the gear but until I can get the hub off I won't know. I have unscrewed most things I can see but it just doesn't seem to budge
5 Suggested Answers
SOURCE: Replacement beaters
I had an SM100 which did not work when I got it out to make cookies recently. So, I have both bowls available (large and small), beaters, dough hooks, whisks and the use and care book too! I sure will miss that mixer. Contact me at lindareagan@comcast.net
Posted on Dec 06, 2008
ricardok45
  • 135 Answers
SOURCE: Oil leak on A200
OK guys, let's try to solve your common problems first then the rest will become clearer.
The Hobart A200,,,,,,,, does not use oil! It uses grease! If you see oil, it's because the grease is separating the oil in the grease. Both machines have not been serviced for at least 5 years. That's about the lenghth of the lifetime of most greases. I recommend that you call Hobart and ask about their tech. rates. All bearings should be checked carefully for wear, as should the worm gear, seal, and the Bronze gear that it turns. The Planetary (mixing part), should be removed as well, cleaned. and inspected. Replace the seal on the planetary and on the mainshaft. Removal of all old grease is required, as it's no longer doing the job it was designed to do, will result in advanced wear, and is the actual source of your problems. The seals were designed to seal grease, not oil.
If Hobart is too pricey for you, and they are for many, try to find someone from a wholesale restaurant equip. place who has rebuilt these machines, or find a repair shop who have experience with this Hobart model. If you'd like to tackle the job yourselves, go to www.hobartservice.com. Register for free, then find the files that match your mixer model and ML # and download the parts files for it. These exploded drawings will be very helpful with your task.
Either way, these mixers need to be opened up to remove existing oil and hardened grease, especially the oil! The planetary must be removed to drain any oil out of it and to regrease it. If you can get the oil out of the mixer, a short fix would then be to simply regrease the the mixer and put it back into service, leaving the existing seals in place. Don't forget to wipe out the shiny ring on the planetary, if it too has oil in it.
There is no seal at the hub. No seals can be tightened. The oil leak underneath the mixer comes from the motor shaft seal at the transmission case where the pinion gear enters the trans., it flows down into the mixer support column and drips onto the floor or counter, again, because of the breakdown of the grease.
If you tackle the job yourself, find your local Chevron Distributor and get several tubes of the approved grease, namely, Chevron FM ALC EP NNGI 2. Chevron p/n 230204-000. If you've found this solution helpful, please rate it as fixya!
Good Luck! ricardok45
Posted on Feb 04, 2009
SOURCE: K-beater is stuck on our Kenwood Chef and we can't remove it
I couldn't remove the K-Beater as when I tried to turn it the whole mechanism turned with it. I couldn't even remove the splashguard! I was going to take it to the Kenwood factory (a few miles from home) but then I thought I'd give it one more go and this is what I did...
  1. Next to where the K-Beater attaches in the middle of the circular plate is a lug with a pointed-shape bolt on the end. Remove this with a spanner and the beater plus gear cog can be removed.
  2. Place some mole grips or wide pliers on a worktop and sit the cogged gear in to it and grip so that it won't turn.
  3. Now you should be able to remove the K-Beater!
Perhaps someone can suggest how to stop it happening again. I haven't attached anything since but will update this post if I have any other helpful tips.
Posted on Oct 31, 2011
SOURCE: Drawing of Kenwood Chef A701A
Can someone email me service manual please? S1m0nh@hotmail.com thanks in advance
Posted on Oct 20, 2012
SERVICE MANUAL FOR KENWOOD CHEF A701A
Hi Alfred. I don't have the manual but I have repaired dozens of these machines. Do you have a specific question?
May 10, 2013 | Food Mixers
I need a service manual for the Kenwood Chef A701A. Can bGR1 help please
Can I please also a have a service manual for my kenwood chef a701a mixer. e-mail is ncb06045 AT gmail DOT com DOT au
thanks
Feb 10, 2013 | Food Mixers
I need a service manual for a KENWOOD CHEF model A701A Francis Barclay. fbarclay@ihug.co.nz
Hi, Can you please send me copy of A701A service manual. My email address is bhaymes@engineer.com
Thanks
Nov 08, 2011 | Kenwood KM400 / KM410 Chef Classic Stand...
Jul 30, 2010 | Kenwood Food Mixers
Manual download for Kenwood chef A701A
there is one here...
http://web.archive.org/web/200707171...tions-A701.pdfbut the pages are in the wrong order and i think some are missing.
Mar 13, 2010 | Kenwood Food Mixers
Kenwood Chef A701A Blender needs new shaft seal
It uses a different thread = turn clockwise to undo - not the normal turn ccw to undo and the nut is attached to the 2 blades.
Jan 11, 2009 | Kenwood KM300 Chef Stand Mixer
Kenwood Chef A701A Motor
Hello graham.
yes we can supply the armature to A701
or maybe the problem is another's .. is necessary check all machine first before change the armature.
Regards
Kenwood Chef Restore
Jan 05, 2009 | Kenwood KM800 Major Classic Stand Mixer
Difference Kenwood Chef A701 and Kenwood A901
Hello.
the difference between A701A and A901 is :
high speed outlet
slow speed outlet
planetary hub is similar . A701A, A901 and KM series
A701 Different planetary hub and fit different tools.
is not same A720 and A920 A7 = A701/A
A9 = A901 and KM
In our web site Kenwood Chef Restore in Downloads section.
you can download the compatibility of the models A700, A701 , A900 and KM series .
Regards
Oct 02, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Kenwood chef
It could be a broken drive belt, this is usually located under the top cover. You may need to remove a couple of screws to get at it. Don't forget to unplug the mixer before trying this.
Mar 18, 2008 | Food Mixers
Food Mixers Logo
93 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
