Question about Toshiba Televison & Video
Tv showing service not running
Batteries changed in remote only partial working so unable retune
5 Suggested Answers
  • 8457 Answers
SOURCE: On both my Samsung digital recorder and my DM Tech
Re enter the codes,or take the remotes aparts take some rubbing alchahol clean the circuits board and the rubbers films liners.
Posted on Dec 14, 2009
  • 378 Answers
SOURCE: I have a brand new
press "0000" on remote
Posted on Apr 03, 2011
jdvillanueva
  • 2098 Answers
SOURCE: I have a RCportable tv
First confirm if the remote control emitted an infrared after an installation of the batteries by pointing it directly to your cellphone camera, while pressing any button key in the remote control, you will see the flash of the infrared emitter through the camera indication that the remote is working fine. If you can't see a flash then this is an indication that the remote is not functioning. Watch the video below for more info.
Remote Control Testing
If you've confirmed that the remote is not working, you must check if the newly installed battery is fully charged(tried another battery as much as possible). If the battery is not the issue, the remote must be take apart to check for bad solder joints most especially in the battery terminal and in the leg of the infrared emitter. Check also the battery terminal of the remote for corrosion.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 27, 2011
bugoy31
  • 1238 Answers
SOURCE: my auto retune has gone from my set up menu on regza c3030
you have to call aservice
Posted on Jul 23, 2012
Screen keeps changing colors and will not show picture
hi is it flashing red blue green, if so the tv is in screen burn mode, just press menu on the remote retune the tv, what is the model number of the tv you may need to go into the service menu turn screen burn mode off, thanks
shaun
Feb 25, 2017 | Televison & Video
TV will not change or show channels
You don't say whether you have had it working at that location before. When you move a TV between houses, it is necessary to retune your channels. Would recommend returning to first time installation.
If you haven't moved it recently there are other reasons why this might happen. 1) There is damage to your aerial caused by weather, 2) A power surge or loss of power to the memory battery on your video board has wiped the frequency information from the memory [the memory battery is like a watch battery that keeps a small amount of power going through the system to it can keep your settings when unplugged], 3) The internal tuner board for your TV has packed in.
If '1' is the case, obviously you need your aerial fixed; if '2' is the case you need to retune again [you'll know if the battery is dead if you have to retune every time you turn on the TV]; if '3' is the case you either need a replacement AV board or someone to solder a replacement tuner board to it.
Jun 17, 2013 | Philips Phillips 40 in. LCD HDTV
Why doesnt my inferred pickup work on my goodmans gtvl19w17hdf.
Have you replaced the remote control batterys?
If you have and need to verify if they are working, you need a digital camera and a dark room. Turn on the digital camera and then point your remote at the lens and press any button. if the remote is transmitting the LCD screen on the camera should show it flashing.
If you see that then you know your remote is operating next go to your tv and try to access the menu and retune the tv.
Apr 17, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Samsung flatscreen wont turn on but red light is on showing power ..my son used sleep timer last night
with tv in standby press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu DO NOT CHANGE ANY SETTINGS
look at list you will see reset
ONLY USE DOWN NAVAGATION KEY until RESET is highlighted
then PRESS RIGHT NAVAGATION KEY the tv will reset
PRESS STANDBY TO EXIT
the tv will need retuneing after
hope this helps
Dec 19, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
The "menu" on my remote control is not working - unable to retune
You can re-tune manually or purchase a universal remote. I'd recommend any kind of harmony remote. If you buy a cheap one, nobody will guarantee that it's compatible... in other words, you'll be wasting money little by little. Save yourself the heartache and buy a harmony remote... cheapest is a 525 and they work brilliantly.
Oct 06, 2009 | RCA 3-Device Universal Remote with...
Unable to retune in tv programmes. dvd part of tv
make sure your aerial is connected and if connected its not broken
Sep 15, 2009 | Televison & Video
Nec chromvision tv (no remote) unable to tune
Just buy any Logitech Harmony universal remote control
Jul 30, 2009 | Televison & Video
RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Dec 29, 2007 | RCA 27F634T TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
